Miiqqula's Mirage
Miiqqula
Miiqqula's Mirage
Post by Miiqqula »
So let jump in this gb
And here is my model
And will make that french toast in desert storm :lol:
Find out today, that this kit is Heller's plastic with eduards PE, resin and decals.
So that means the build is fun :thumb1: for you guys, not me, because is first jet model for me :D
Thanks for watching
Re: Miiqqula's Mirage
Awesome for you to join in :banana:
You will do fine and I wish you the best of luck in the build :th:
Miiqqula
Post by Miiqqula »
Twokidsnosleep wrote: Tue Feb 02, 2021 10:58 pm Awesome for you to join in :banana:
Thanks m8.
What is the best stuff to wash resin parts?
Miiqqula wrote: Tue Feb 02, 2021 11:07 pm
Thanks m8.
Hmm
I did like soapy water bath first and then always wipe with IPa (isopropyl) before I paint them up (anything up for that matter)
Keep them damp or have a damp kitchen towel underneath them when sanding etc to stop breathing in the dust
Miiqqula
Post by Miiqqula »
Little update.
Working with cockpit.
First get resin seat ready for primer. I was happy that point. PE is also top notch. Bend really easy.
Then i started work with plastic, and my joy lost like fart in the wind. Its soft. Way too soft. Now i know why Heller is cr*p :think:
Now i need to wait my paint shipment.
Thanks for watching :bow::
Great to see you taking part and a nice start to the build as well :clap: :clap: :clap:
And besides, there is nothing that belongs in the desert so much as a mirage :) nice choice :th:
Great subject :pop:
Quax
Greenland
Post by Quax »
Great to have you on board Miiqqula and good luck with the kit! :thumb1:
A mess as usual...
Miiqqula
Post by Miiqqula »
Need advise here.
My paint delivery hasn't arive yet. So i started working on exhaust nozzle. Have real problem.
I can not make the etching parts stick to any plastic. I tried several glues like VMS flexy 5K pe glue, Loctite perfect pen, Hypo glue with no succes. They fall for plastic in some point, if i touch the part. So any advise?
Thanks for watching
ElCapitan
Post by ElCapitan »
Strange that it's falling off so easily. I would recommend gently scratching up the sticking surfaces with a file or sander to give the glue something to grab onto.
ElCapitan
Miiqqula
Post by Miiqqula »
ElCapitan wrote: Sat Feb 06, 2021 11:24 am Strange that it's falling off so easily. I would recommend gently scratching up the sticking surfaces with a file or sander to give the glue something to grab onto.
Yup. Never happen before. When the part falls off. Plastic is clean, like plastic refuse the glue.
Maybe brushing plastic extra thin help, and sanding pe parts. Try that next.
That is strange.
As well as scuffing up the surfaces you could also try using a little PVA (white/wood) glue and see if that'll hold the parts too.
Miiqqula
Post by Miiqqula »
Looks like extra thin method helps
Tomcat64 wrote: Sat Feb 06, 2021 12:57 pm That is strange.
Totally forget PVA :wall: I have Mig's ultra, and microscale glues. Will use PVA in very small parts. Thanks m8 :bow::
Miiqqula
Post by Miiqqula »
Pretty much no issues
Lost one seatbelt somewhere. Hunted that about two hours, but not found :bash:
Added Ammo's middle east dust pigment to the floor
Now the most nerve-wracking phase is over, and I survived it for the first time well, even though I lost one part.
Lovely work on the cockpit - the details on the instrument panel & seat really pop out.
Great job :th:
Trying priming the plastic with tet before applying the Ca. The tet gives it a good clean.
Miiqqula
Post by Miiqqula »
digger303 wrote: Thu Feb 11, 2021 12:49 pm Trying priming the plastic with tet before applying the Ca. The tet gives it a good clean.
Tet? Tamiya extra thin?
Miiqqula
Post by Miiqqula »
Tomcat64 wrote: Thu Feb 11, 2021 11:42 am Lovely work on the cockpit - the details on the instrument panel & seat really pop out.
Great job :th:
Thanks! Still the lost seatbelt annoying me. :doh:
So it is most likely closed cockpit :think:
Miiqqula wrote: Thu Feb 11, 2021 1:00 pm
Yep.....let us know how you go
Any of the brands that have a extra thin cement or quick drying should work too.
Miiqqula
Post by Miiqqula »
digger303 wrote: Thu Feb 11, 2021 2:05 pm
I allready done that, and it seems help a little. The plastic is so soft, like a bucket plastic. Never seen this type of plastic in kits before.
I need to be extra careful when touch pe parts. So that means no weathering in exhaust nozzle. :violin:
Miiqqula wrote: Thu Feb 11, 2021 1:02 pm
Great job :th:
Could you try to replicate the missing belt with a thin length of masking tape? :think:
Miiqqula
Post by Miiqqula »
Tomcat64 wrote: Fri Feb 12, 2021 11:12 am
Great job :th:
I found it in today. Allready glued yesterday rear canopy part in fuselage. I think i still can put the seatbelt part in where it belong. :thumb1:
Miiqqula
Post by Miiqqula »
Hello my modelling friends.
I have a sad news in build, and my modelling hobby also.
i got a brain stroke about six weeks ago, and got out of the hospital last week. Naturally, most of my time has gone into rehabilitation. Permanent damage is not yet known, but at the moment the right hand and foot are not working as before.
So because of this, this model is not completed, and anyway, the whole hobby may end
However, I will try to visit here when my time and well-being allow it.
Stay healthy and safe!!
Thank you for watching
Miiqqula wrote: Wed May 26, 2021 1:49 am Hello my modelling friends.
Shiit that's bloody awful and horrible. How old are you ?
I'v seen people who have had strokes and over time they do get better. Not fixed , but a huge improvement. I can only encourage you not to stop modeling it helps brain to eye co-ordination and control. Actually you being a modeler is a big step towards your own rehab. The models might not be as good as before, but like before they will get better as will you I believe.
digger303 wrote: Wed May 26, 2021 5:23 am
Digger has it perfectly. Never give up - adapt and overcome. Keep the models simple at first then progress as your use of the right hand improves. Talk to your physiotherapist and see if they can help you "grow" the use of your left hand to compensate in the mean time. I am certain you will be back building in time.
    So sorry to hear this! I agree with our friends above, keep modeling to work on your hand/eye coordination.
    I found a quote while having my own physical struggle earlier this year. It really helped me a lot. Hopefully you will find some inspiration in it as well.
    "You don't know how strong you are until all you have left is to be strong."
    I wish you nothing but the best as you work thru recovering.
    We're all here so come and visit. If you ever need to chat, feel free to send me a PM.
    I'm so sorry to hear your news mate and wish you all the best for the future and recovery.
    The other guys have already said it but even if you're not modelling yourself please stop by and let us know how you're doing.
