Find clubs
khaldrogo
Turkey
Find clubs
Post by khaldrogo »
Reasons you should choose shark navigator lift away NV360
Shark is probably not a strange brand for every person who uses a vacuum cleaner. It is impossible not to mention the Shark vacuum model nv360 which is extremely popular with users in the market. If you still have doubts about the quality of the machine, this article and with many Shark vacuum NV360 reviews will explain why you should buy it.
Modern design
The first thing to mention is the color of the machine. It is an elegant and gentle blue color that will surely win the hearts of many users. Plus, at 15.96 pounds, you'll easily transport the machine while cleaning. Moreover, the device has a vertical form, a strong advantage when cleaning carpets or floors.
Plus, with a 25-foot cord length and Lift-away design, you can quickly move it to clean anywhere overhead in your home.
State-of-the-art Lift-away technology
Lift-away technology seems to be a plus for every user before considering buying a vacuum cleaner. Thanks to Lift-away, users can easily carry the case with one hand and clean it gently on the stairs. And yet, you can completely lift the chance to clean the upper floor conveniently.
Strong attraction
This is the advantage that each user often puts first when choosing to buy a machine. With strong suction and flexibility to go anywhere, you can easily clean your room without spending too much effort. The machine provides excellent control when moving around furniture and other obstacles through the dynamic rotating steering wheel combined with the navigator.
HEPA filter system
Shark NV360 is one of the optimal solutions if your family has people with asthma. The HEPA filtration system and fully sealed allergen-proof technology captures 99.9% of dust and allergens and prevents them from escaping back into the air. Another special feature that we want to tell you is that this filter can be completely changed and reused after 24 hours.
The dust cup is large and easy to clean
Finally, we want to talk about the dust cup. With a size of up to 1.2L, this must be a large capacity to help you comfortably clean without worrying about being full of dust in the middle. Thus, you also save yourself the time emptying the dust when the container is full, which is too convenient.
Not only that, the dust container can be opened from the vacuum cleaner's body. It can be opened from the top or bottom by pressing the unlock button. And we recommend emptying it after each use.
Tips on using the machine
  • Do not use the machine to suck up any liquid
  • Turn off all controls before plugging or unplugging the vacuum cleaner
  • Do not use the device outdoors or on a wet background
  • Do not use without a dust cup or filter
  • Make sure that the dust cup and all filters are in place after routine maintenance
  • Do not vacuum hard or sharp objects that can damage the vacuum cleaner, such as glasses, nails, screws, or coins
  • Do not vacuum drywall, fireplace ash, or embers
Those are some tips before we end this article when you use this shark navigator lift-away or similar products.
Conclusion
Finally, we hope you will not hesitate to read the article. The choice is all yours, and we want to affirm that the Shark navigator NV360 upright vacuum is the extremely good and affordable one that you should have in your home.
Re: Find clubs
Welcome!
NoelSmith
Re: Find clubs
Post by NoelSmith »
Try contacting IPMS who have branches all over the UK.
