Baja Husky Motorcycle
With Herbie out of the way, I turn my sights to the motorcycle
Kit was from eBay and I had to bid a fortune for it...like $100
Stupid as this is NO Tamiya
Have built this as a kid and remeber fighting the wheel/suspension assemblies as the latter are not strong enough to support things
Something wrong with me as this is my third Revell kit in a row :shock: :wtf:
Bike is famous for Steve McQueen
Re: Baja Husky Motorcycle
Typical of me, I will deviate from the assembly instructions.
The frame and engine are glued together first, but this does not allow seam filling on the frame
So, using breakage of one of the rear supports in my favour, I can assemble the engine and frame separately and squeeze them together after.
Everything painted in metallic silver and given a clear layer
God help me, am I really gonna do this?? :crazy:
Yep
Twokidsnosleep wrote: Mon Mar 15, 2021 7:10 pm God help me, am I really gonna do this?? :crazy:
Masochism gone mad!!! :lol: :lol:
    RangerNeil wrote: Mon Mar 15, 2021 7:17 pm
    Stupidity more like
    This is harder with black rims, might have to prime them :scratch:: :think:
    Casper
    Post by Casper »
    I was only looking at this kit yesterday on tinternet :o
    its a great looking kit scott, glad to see your lacing the wheels :)
    mark :pop:
    MBB Design© Mini Bike Bench©
    Casper wrote: Mon Mar 15, 2021 8:09 pm I was only looking at this kit yesterday on tinternet :o
    mark :pop:
    Honestly, the kit is very crude, hardly worth $20
    The frame is weak and assembly difficult and poorly designed.
    I can totally see me as an early teen hating this build....but this old dog has a few tricks up his sleeve now ;)
    Half of one side done...almost screwed one up on the wrong hole but managed to recover it back out
    Not much center hub on here available to be drilled and hold the spokes :shock:
    Tedious part is making the little nibs at the rim side of the spoke
    Got down and made the other nine spokes and nubs in one go and then popped them in the other side of the hub.
    One half of the rear is done :roll:
    Basically a day monkeying around on this and watching over a recovering pup...time well spent according to me...and pup is bouncing back post surgery.
    I am pretty sure my wife thinks I did SFA all day and wasted it...oh well.
    I got the rear wheel 3/4 brass spoked and loving the look
    Ya this is going to be worthwhile :D
    Oh yes, this brings back memories :th: I built this kit as a teenager :banana: just before I built
    Airfix TM :pop: :cheers2:
    Your getting good at respoking the wheels ...marvelous.
    :th: :th: :cheers2:
    digger303 wrote: Tue Mar 16, 2021 11:09 am Your getting good at respoking the wheels ...marvelous.
    :th: :th: :cheers2:
    Ya it is gonna be cool
    Casper
    Post by Casper »
    :clap: excellent start scott, so much better and well worth the time spent. You looked very pushed for space on the smaller hub :clap:
    Casper wrote: Tue Mar 16, 2021 5:19 pm :clap: excellent start scott, so much better and well worth the time spent. You looked very pushed for space on the smaller hub :clap:
    In deed, not fun with the hub drilling
    I think the next step in the evolution of this is to make my own hubs :think:
    Kevthemodeller wrote: Tue Mar 16, 2021 9:11 am Oh yes, this brings back memories :th: I built this kit as a teenager :banana: just before I built
    Oh I like that Airfix kit...you are a bad influncer ;)
    After coming home from a work day, did two dog walks, dinner, the dishes and got the car filled with gas.....I got an hour before bed to plug away at the last side of the rear rim and got its spokes done.
    This is just all loose fit to give an idea of the looks
    I like the slight bend in the spokes for this side..necessary twist to make things overlap properly
    Twokidsnosleep wrote: Tue Mar 16, 2021 8:20 pm Oh I like that Airfix kit...you are a bad influncer ;)
    I'm trying my best ;)
    The same Christmas I got This :banana:
    Kevthemodeller wrote: Wed Mar 17, 2021 7:55 am
    Oh I like that too
    Bike kits have gone through the roof in cost :roll:
    Trying to not buy as much during these crazy times and build from the stash...ya, right :lol:
    Those wheels look sweet! Nice work!
    BigWall wrote: Wed Mar 17, 2021 2:34 pm Those wheels look sweet! Nice work!
    :cheers2: Joe
    Moving on to the front spokes
    I got half of the front rim re-spoked after work and my chores
    I have some resin tire valves that I will add to make things look a bit more realistic
    Casper
    Post by Casper »
    Coming along nicely scott, you did an excellent job getting all those spokes on a small hub :clap:
    mark
    Man alive those wheels! :crazy:
    Awesome work :bow::
    No stopping you when your on a roll.
    :clap: :clap:
    digger303 wrote: Sat Mar 20, 2021 1:07 pm No stopping you when your on a roll.
    :clap: :clap:
    Exactly
    Once you get the proper process and make a system out of it, it gets easier...pretty much like everything
    I have cut all the nibs, openned their diameter and filed a round end on all 19 (22 actually ‘cause I will lose some)
    All the spokes are cut to length and bent at one end, filed and ready to go
    Then holes for the first nine get drilled into the rotor and the spokes inserted in order
    Then drill the other nine holes and spokes inserted from the opposite side
    Clean up and done
    Ok both wheels done but rims all still separate and obviously need prime and paint
    Casper
    Post by Casper »
    Brilliant :clap: and well worth the time spent scott :th: :clap:
    Its hard to stop once you get into a rhythm :) once you get past the drilling and prep work its very rewarding to see the spokes go in :D
    I like the way the spokes attach to the hubs on older bikes, bit like a bicycle but larger scale of course :roll: :)
    You have got me wanting to do my Bentley wheels now :think: was playing around with my second set today
    mark
    Casper wrote: Sun Mar 21, 2021 1:16 am Brilliant :clap: and well worth the time spent scott :th: :clap:
    mark
    Hitting a rhythm is exactly correct
    Get all the prep work done for the bits and then just fly at it!
    NoelSmith
    Post by NoelSmith »
    Scott, you are making a good job of those wire wheels on your Husky. I have done a few models now by replacing spokes with real wire. I think that you will agree that it is not as daunting as it seems at first glance.
    It just needs getting your head around the planning and preparation to start off with by getting wheel rims and hubs ready to take the spokes, making an assembly jig, and methodically building in each layer of spokes.
    On smaller scale models I have used plastic rod for spokes as they can be set with liquid cement when assembled into the wheel.
    Wow! Those are absolutely gorgeous!
    NoelSmith wrote: Sun Mar 21, 2021 7:27 am Scott, you are making a good job of those wife wheels on your Husky. I have done a few models now by replacing spokes with real wire. I think that you will agree that it is not as daunting as it seems at first glance.
    Indeed
    The biggest fear is f’ing up the rim beyond repair
    This is one of the alteration steps for strength
    The front forks. The post is thin plastic and wants to break so easily.
    So I am replacing it with brass tube threaded on either end and a little nut internally threaded
    This should be enough to keep the forks from snapping off
    Casper
    Post by Casper »
    :clap: great to see you chopping this up so to speak scott. love what your doing with it and make all the difference. The mod will make the fork assembly much stronger and take any rocking out (if you have any) I'm on the lookout for a Harley kit to make a custom but it can wait, I have enough on my bench as it is and need to get some projects finished. Very tempting though :)
    Happy with the forks and that I remembered the front mud guard needed to be threaded in there too. Whew
    Dry fitting motivation
    The original owner decal’d the front number plate...for some reason :scratch::
    Casper
    Post by Casper »
    8-) lovin the look, and those tyres look great. some weld lines on the frame would look cool
    Casper wrote: Sun Mar 21, 2021 8:11 pm 8-) lovin the look, and those tyres look great. some weld lines on the frame would look cool
    Interesting idea
    How would you go about it?? :think:
    Did you build that jig, or is it something you've purchased? I've never seen one like that.
    Casper
    Post by Casper »
    Twokidsnosleep wrote: Sun Mar 21, 2021 8:48 pm
    Interesting idea
    There are a couple of ways people do them, I have used Vallejo masilla platica (like Tamiya putty in a tube) with a small nozzle. run a thin line along the joint just like you would with a welding rod pushing the paste as you go (I pull then push back slightly) to create little pools or use a small stick to get the same effect. It works really well and is used a lot on tanks where the plates are welded together.
    aur0ra145 wrote: Sun Mar 21, 2021 8:54 pm Did you build that jig, or is it something you've purchased? I've never seen one like that.
    It is a MacroMoto jig I got from eBay. Mine is an older version I got on clearance :D
    They are on eBay or Spotmodel
    https://www.spotmodel.com/product_info. ... s_id=55065
    Casper wrote: Sun Mar 21, 2021 9:06 pm
    Interesting idea
    Sweet. I might give that a try :think:
    Thanks!
    Casper
    Post by Casper »
    Twokidsnosleep wrote: Sun Mar 21, 2021 9:37 pm
    I have designed a bike stand and its in its final stage..I plan to manufacture and sell in the very near future ;)
    Casper
    Post by Casper »
    Thanks!
    [/quote]
    It looks great on open frame bikes matey and easy to do. You can do it with putty and a blade
    something along these lines, no pun intended :)
    please feel free to delete these posts after scott, don't want to fill your diary with unwanted photos
    mark
    Perfect, will have a look at that
    Thanks Mark
    This is what a build thread is to me....info on what I did and what others suggest so I can look back and reference at a later date
    So no worries posting in here at all mate :thumb2:
    @Casper
    Casper
    Post by Casper »
    Absolutely mate, I show where I go wrong as well as occasionally getting it right but above all enjoy what you do and the next time you will do it even better.
    I have many things I would change in older builds but its all part of the learning process, I'm not good with decals especially the older ones or Tamiya bike decals, they just split or disintegrated before my eyes :roll: The CF ones on my Yamaha were bad enough and its soul destroying to see it all go wrong after building a fantastic bike.
    Just to finish the wheel off before we go to assembly, a little tire valve.
    Used to make them, but easier if someone else has already
    Casper
    Post by Casper »
    :) Nice
    Its amazing what you can get these days. They used more material in the sprue than the valves :D these will look awesome scott
    Casper wrote: Mon Mar 22, 2021 12:51 am :) Nice
    Love to be able to 3D print out these kind of things myself by the end of the year
    That is my goal...if $ doesn’t go wonky
    Casper
    Post by Casper »
    Twokidsnosleep wrote: Mon Mar 22, 2021 1:20 am
    I would recommend getting familiar with Fusion360 mate, once you get used to the sketch and design tool keys and what they can do you will be designing your own simple parts in no time at all, its good practice and great fun. The guy on you tube I mentioned has done some great tutorials, check out his beginners guides its a great place to start. Once you become accustomed you can then consider looking for a printer. choosing a printer for your needs is also a learning curve and what kind of materials are available for home printing whether it be for hobbies or business, also the type of printer. its daunting at first but well worth doing some research before spending cash on a printer to sit in a corner till you learn how to design a part and convert and send stl files.
    Some top draw remodelling work going on here Scott, the wheels are terrific :bow:: :clap:
    Kevthemodeller wrote: Mon Mar 22, 2021 8:34 am Some top draw remodelling work going on here Scott, the wheels are terrific :bow:: :clap:
    Thanks Kev
    I am contemplating re-engineering the rear suspension bars that attach the rear wheel and shocks :think:
    They are a seriously weak connection on the kit design. But it involves connecting tubes to a threaded rod, lots of soldering and possibly some swear words. My laziness will say to leave it until I break the damn thing trying to put it together.
    But of a conundrum really :crazy:
