Tamiya Yamaha YZF-R1
MrBowcat
Post by MrBowcat »
Morning guys. :)
For my second attempt at a motorcycle I've chosen this.
I've made a start by getting the engine block cleaned up and together along with all the various bits that go with it. I also got the frame, mudguard and main body halves glued together along with all the parts from the chrome sprue. The chrome was actually really nice, unfortunately with this being an older kit (1999) there were a lot of seams to clean up so I opted to strip the chrome and will repaint.
Si vis pacem, para bellum
Re: Tamiya Yamaha YZF-R1
Another cool bike. I'm looking forward to watching it come together.
MrBowcat
Post by MrBowcat »
Cheers Joe :)
I got the first paint down yesterday. I've gone for gloss aluminium on the frame as it seems to match the boxart the best (and I'm guessing the real bike frame would be ali).
Casper
Post by Casper »
:pop: :cheers2: I had to look twice to see the frame in front of the box :) great start MrB :thumb1:
MBB Design© Mini Bike Bench©
MrBowcat
Post by MrBowcat »
Cheers mate. :)
He’s on a roll ;)
WordenB
Post by WordenB »
Nice start Mr B, that was the first (and only) bike kit I finished although working on another at the moment. Hope you enjoy making it as much as I did.
MrBowcat
Post by MrBowcat »
Cheers guys. :)
I finished building the engine and got it installed in the frame this weekend, still need to add a wash to the frame. I took some artistic licence with regards to the colour of some of the engine parts.
The beginning of something amazing
MrBowcat
Post by MrBowcat »
Cheers Digger. :)
I had a bit of an "Oh S**t" moment this morning when I was working on the rear suspension (the joys of working from home). I couldn't find the suspension spring, not sure if I lost it or it wasn't in the kit. So I made this:
Not perfect by a long shot but should do and will be tucked mostly out of sight.
Good save
I think the spring looks damn good. The whole thing is coming together nicely!
MrBowcat
Post by MrBowcat »
Cheers gents. :)
WordenB
Post by WordenB »
Beautiful work, I can't believe how quickly you progress with your builds.
MrBowcat
Post by MrBowcat »
Cheers Worden. :)
To be fair these are relatively simple kits with fewer parts. By comparison when I built the Meng Bradley M2A3 (https://www.flickr.com/photos/152154040 ... 5109833292), that took over 100 days.
Back ends on the bike. I lost a little bit of the decal on the exhaust when fitting the mounting clamp, not sure yet if I'm going to leave it or attempt a repair. The exhaust is only attached by one screw so I can remove it later if needed.
Casper
Post by Casper »
:thumb1: :clap: Great progress MrB and looking great :pop:
mark
MrBowcat
Post by MrBowcat »
Cheers Mark. :)
WordenB
Post by WordenB »
MrBowcat wrote: Wed May 12, 2021 8:56 am Cheers Worden. :)
Had a look at the Bradley, absolutely superb! Think my R1 took me about 6 weeks on and off but the VFR 750R RC30 I am doing at the moment has been on the bench since Christmas (although I have done a couple of cars in the meantime). The trouble with bikes is that I don't know one end from the other and spend hours looking up reference stuff.
MrBowcat
Post by MrBowcat »
Morning guys. :)
I've been working on the paintwork for the last few days. First up was the body panels, painted, glossed, decalled and glossed again. The kit comes with a decal for the red accent on the front fairing, but I decided to mask and paint it instead.
Then I cleaned up all the remaining parts and got them painted.
So with everything now painted it's just a case of getting it all put together. :)
Casper
Post by Casper »
looking very nice indeed MrB :clap: :clap:
MrBowcat
Post by MrBowcat »
Thanks mate. :)
MrBowcat
Post by MrBowcat »
Morning guys. :)
Started putting it together yesterday.
Front end.
Seat and fuel tank.
Then the problems started when I tried to fit the cowl.
I can only assume that the internal headlight piece that connects to the frame isn't correctly located within the cowl. There's nothing else for it, it's going to have to come apart. I've ordered some debonder from Amazon, not sure what effect this will have on the paint so might end up having to strip it all and start again. :(
That stinks. Otherwise it's looking amazing though!
Casper
Post by Casper »
I had a misalignment on my Yamaha, magnets work great on fairings MrB
Colours look very real and the front blinker lens is very well done.
:clap: :clap:
MrBowcat
Post by MrBowcat »
Cheers guys. :)
I managed to get it apart with minimal damage and have stripped the paint off the cowl and light clusters. Just priming now and will get the top coat on later.
MrBowcat
Post by MrBowcat »
Morning guys. :smiling3:
I ended up stripping and repainting the cowling and light cluster. Still not perfect but better than it was.
With that I'm calling it done. viewtopic.php?f=46&t=29449.
Casper
Post by Casper »
:clap: :clap: excellent build MrB
these bikes can be so small and fiddley to work on sometimes, a tiny misalignment can cause all kinds of problems when fitting the fairings, another wonderful bike to add to your line up :clap: :clap: :)
MrBowcat
Post by MrBowcat »
Cheers mate. :)
Superb mate, beautiful firing paint work, top draw work on the frame and other metallic parts :th: :banana:
I think these Mk1 R1's are the best looking :th:
MrBowcat
Post by MrBowcat »
Cheers Kev. :)
