Revell paint problems
Rammit
Post by Rammit »
Has anyone had any problems using Revell paints? They constantly bubble, and clog up my airbrush so I have to dismantle it (and stab myself repeatedly with the needle), does anyone have any tips for using these paints? I can't back out of using this junk either, as I've gone through about 1/3 of my Arado with them :wall:
Tamiya 1/35 Pz.Kpfw. VI 'Tiger'
Tamiya 1/35 FV4030/4 'Challenger I'
Hobby Boss 1/48 Me-262A1a 'Schwalbe'
Radzy
Re: Revell paint problems
Post by Radzy »
Have you tried to just clean the needle without opening the airbrush?
Just take a q-tip dipped in airbrush cleaner and clean the needle. It normally helps me without requirement to dismantle all the stuff.
And if it clogs... maybe (just maybe) it's not dilluted properly? Maybe you should use some retarder to prevent paint to dry too fast and settle on needle ?
Sorry, I'm not big expert, but this is what I usually find as reason of paint clogging - paint settles on needle due to thickness of paint (at least acrlylics I use).
WIP:
My Portfolio
My YouTube Channel
It'll all be about the thinning. What are you thinning them with and to what ratio?
Twistedsniper42
Post by Twistedsniper42 »
i use 2 parts thinner to 1 part paint,well it works for me anyway.
Daimyo
Post by Daimyo »
I use Revell enamels when airbrushing too, and I use ModelMasters thinner. Everything was fine so far
ScaleModelling1105
Post by ScaleModelling1105 »
I use revel acrylics for airbrushing quite often and I get the same problem all the time. It's because the paint dries really fast in the airbrush so you just have to un-clog it. Bit annoying but there you go. If that doesn't work then I think it's because you haven't tightened (forgotten what it's called) the cap over the nozzle. SO you effectively are backflushing the paint. Hope this helps. Works every time for me.
Will Hall
ScaleModelling1105
Check out my channel:
What's on the bench:
With ulitmate thinner revell paint sprays real nice and smooth, I was really impressed with the paint, no clogs or problems at all.
keith
Post by keith »
Try distilled water and a flow enhancer
Nostalgia isn't as good as it use to be
Water is crap for thinning Revell through an airbrush. I could never get that right.
But I have recently been spraying a Revell acrylic gloss red on my Red Arrows Hawk, and using the Utilmate thinner has worked wonders. No clogging, perfect! I urge you to try it.
HamilkarBarkas
Post by HamilkarBarkas »
I work with revell acrylics and normal tap water only, it works perfectly. Most model builders i talk to don´t believe me :) I till try to cover that detailed in a video soon.
Schoof
Post by Schoof »
What revell paint do you use ?
