Tamiya 1/12 Kawasaki Ninja H2 Carbon
MrBowcat
Post by MrBowcat »
Morning All,
Pulled this one out of the stash last night.
I've already got a few after-market bits for it.
I've ordered some Zero paints candy green for the frame and some braided hose. Spent a while last night going through the instructions and marking what needs modifying with the PE parts, hope to start cutting plastic tonight. :)
Si vis pacem, para bellum
Re: Tamiya 1/12 Kawasaki Ninja H2 Carbon
:th: :banana: :th:
MrBowcat
Post by MrBowcat »
Morning all. :)
So I've made some progress on this over the last couple of days, I'm really taking my time over every part to eliminate mould lines and the AM stuff is quite challenging as it's so small. There are several bags of small pins that represent bolt heads. some are only a couple of mm long.
This part is the oil cooler, kit part on the left, AM on the right. It took a couple of hours.
Hoping to get some paint down over the weekend.
2 hrs of concentration, but it is heads above the kit blob.
:clap: :clap: :clap:
MrBowcat
Post by MrBowcat »
Yep, it's a nice part and time better spent that staring at the TV.
MrBowcat
Post by MrBowcat »
Evening all. :)
Got some paint down on the engine and frame this weekend. The engine needs some black panel liner to finish it off.
The blower in particular is a lovely piece.
But the star of the show is the frame in Zero paints Kawasaki Candy Green.
I was so pleased with it that I did the pit stand the same colour. :)
I'm now just waiting for some braided line to arrive from Spot Models so I can finish the engine off and get it installed. In the meantime I will probably make a start on the swing arm and PE chain.
looking sweet... :clap: :clap:
MrBowcat
Post by MrBowcat »
Cheers Digger. :)
Cool :th:
Don’t think I have seen this one built.
Love the green frame :mrgreen:
MrBowcat
Post by MrBowcat »
Cheers Scott. :)
That frame just glows! Very nice
MrBowcat
Post by MrBowcat »
Cheers Joe, it really is a lovely colour.
WordenB
Post by WordenB »
Beautiful work Mr B, those Hobby Design kits certainly do add that extra wow.
Lovely work.. as usual Mr. B. The bike is going to be a looker in the green and carbon; can't wait to see it. I was debating getting on of these in 1:1 scale, but at 63 I think it may be a little much for me. I'll keep the FZR1 and Harley for now, but wow that sure is a rocket.
DRUMS01 / Ben
MrBowcat
Post by MrBowcat »
Cheers guys :)
MrBowcat
Post by MrBowcat »
Afternoon all. :)
Been cleaning up the front fender/mudguard and swing arm parts the last couple of evenings and gluing everything together, so not interesting enough to post pics. So instead, here's some gratuitous engine in frame shots. :)
Man that green has a life of it's own.
Nice paint work.
MrBowcat
Post by MrBowcat »
Cheers Digger. :)
I've been browsing Aoshima Lamborghini kits, that green is screaming to go on a hypercar.
MrBowcat wrote: Wed Feb 23, 2022 2:51 pm Cheers Digger. :)
Definitely! :banana:
MrBowcat
Post by MrBowcat »
Morning all. :)
Spent about 3 hours at the bench yesterday and only have two tiny parts to show for it.
First up was a small part that goes on the top of the shock tower, made up of 16 parts, a couple of which were less than 1mm wide. Still need to do some clean up on this.
Second was the rear brake caliper frame, another 14 or so parts.
I had to stop after this as my hands were cramping up.
MrBowcat wrote: Thu Feb 24, 2022 9:04 am Morning all. :)
Understandable. Yesterday I started with 4 identical PE parts all about 1mm square. After the first 3 pinged off into the vast reaches of my cave I threw the last one in the bin....what was the point I thought if I managed to get 1 placed it would make the others more obvious I'd lost them plus there was the thought toss it a save myself the heart ache. :(
MrBowcat
Post by MrBowcat »
Good morning all. :)
Work has continued on the rear end, slowly. I started with the suspension parts, decided to paint the spring to match the frame (have I mentioned Iove this colour).
Can't see much of it once mounted to the swing arm.
Then I moved on to the cogs and chain. There's 110 pins on the chain, they give you plenty of extra although I only lost 5 or so. The pins are around 2mm diameter at the thickest part and around 3mm total length.
I still need to add links to the back of the chain, but it's taken several sessions to get to this stage. Again, working with tweezers and such small parts my hands soon start to cramp so I can only work in small sections.
Chain looks very real. Is it work able or only looks that way ?
MrBowcat
Post by MrBowcat »
Looks only. There are two plates that sandwich the pins.
Mpfiend
Post by Mpfiend »
Really nice progress on this one, and it's already been said but that green is stunning.
Do you think the trans kit is worth the money against the detail it adds to the finished model?
I toying with the idea of purchasing the trans kit for my model.
Regards,
Keith
MrBowcat
Post by MrBowcat »
Cheers Keith. :)
I think the AM stuff is subjective. It does add nice detail, a lot of which won't be seen. However I always feel I get my money's worth through the extra time and skills learned/honed through using it.
Things like that chain are a mini kit in their own right. True it takes a lot of time and patience, but the satisfaction of putting it together well is enormous, and it will add to the finished build being a quite obvious part.
I won't necessarily use all of the parts though. A flat plate added to something that won't be seen is probably pointless, but again it's subjective. Someone else might get enjoyment from fitting that part.
MrBowcat wrote: Sat Mar 05, 2022 11:34 am Cheers Keith. :)
Well put.I agree and would add that there are the parts like in PE that simply fluff out the manufacturers product and are impossible for most of us to assemble or aren't better than the original part. One must make up ones own mind at the time.
Mpfiend
Post by Mpfiend »
Thanks for writing your thoughts, some of the parts in the detail kit do look to add quite a bit to the model and the extra time is well spent.
I think I will get one on order.
Regards,
Keith
Give yourself more credit. It is not just the AM parts, your paint and assembly skills really make it all come to life. I too like the green that think it would look good on just about any 2 or 4 wheel subject.
DRUMS01 / Ben
DRUMS01 wrote: Sun Mar 06, 2022 11:17 pm Give yourself more credit. It is not just the AM parts, your paint and assembly skills really make it all come to life. I too like the green that think it would look good on just about any 2 or 4 wheel subject.
DRUMS01 / Ben
:th: :th: :th: :th:
Love the chain
Lots of work but they add next level realism to the build
MrBowcat
Post by MrBowcat »
Cheers Guys. :)
MrBowcat
Post by MrBowcat »
Morning chaps. :)
I'm still waiting for my braided hose, it's now been pushed back until the beginning of April, so nothing has been put together yet. I have been pushing on getting sub-assemblies together, so here is what I've been working on.
First up was the exhaust. I used AK Extreme chrome on this and ended up with an OK'ish result. I had to paint it a couple of times as I found the paint rubbed off the edges with handling, so I eventually sealed it with a gloss coat.
I also painted and glossed some of the body panels and the tank. These still need knocking back and polishing, but not a bad finish straight out the AB.
Rear frame and air intake for the blower.
Wheels (silver bits hand painted).
And I got fed up with my Xacto knife rolling off the bench, so I made a new one that wont roll.
You might not be happy with the exhaust system color, but I think it looks really nice and the tank is bitchin.
Very very nice.
MrBowcat
Post by MrBowcat »
Cheers Digger. :)
I still have to try heat staining, so I might screw the exhaust up yet.
MrBowcat
Post by MrBowcat »
Hi Guys. :)
Long time no post. I'd found myself having a major mojo shortage so decided to come away from the bench entirely for a few weeks to recharge the batteries. It seems to have worked. :)
Got back to it by painting up a few small parts and also putting the front brake disks together. 25 PE parts per side,including multiple tiny metal pins.
Still waiting for the braided hose to come, now been put back to the end of the month. If it gets delayed again I may have top bench that idea and use the kit hose.
Thats some nice clean work. The AM cooler looks, as Digger said, so much better than the kit lump of plastic.
MrBowcat
Post by MrBowcat »
Cheers mate. :)
tg18083
Post by tg18083 »
Incredible work - can't wait to see the finished model.
MrBowcat
Post by MrBowcat »
Cheers dude. :)
I'm glad you found your mojo. The bike is looking nice
WordenB
Post by WordenB »
Beautiful work as always Mr B. Which braided hose are you waiting for?
MrBowcat
Post by MrBowcat »
Cheers guys.
Worden, some Top Studio .6, .8 and 1mm. The .8's been on back order but has finally come in so should hopefully be here soon.
I'm getting the last few bits painted now so once the hose arrives I should be able to start putting everything together. :banana:
MrBowcat wrote: Sat Apr 30, 2022 10:08 pm Cheers guys.
:banana: :banana: :banana:
WordenB
Post by WordenB »
Was hoping I might be able to help you out but unfortunately I don't have any Top Studio.
kpisnuts
Post by kpisnuts »
Looking very good
Super keep at her
This is a hard time to model as the weather improves and outside beckons
Did you 3D print your Xacto handle?? I have not seen that design
MrBowcat
Post by MrBowcat »
Cheers guys. :)
Had an email to say my orders on the way so hopefully should have that soon. In the meantime I have started on the carbon decals, will post some pics when I get further along.
Scott, I turned it on my lathe. It's made from steel hex bar recovered from a shredder.
MrBowcat wrote: Wed May 04, 2022 1:03 pm Cheers guys. :)
Now I am super jealous!!
Awesome lathe work there mate :th:
MrBowcat
Post by MrBowcat »
Cheers dude. :)
