Machine works 1/4 Porsche 911 boxer engine
kpisnuts
Post by kpisnuts »
Hi all I got this today its actually a Franzis kit released under licence at a 3/4  the price of a Franzis kit, yes the instructions are not as glossy and there are no beautiful pics of the engine, and yes the box is not all luxury and flashy but the rest of the kit is exactly what you get from Franzis.
First thing I will have to deal with are those god awful carburettors.
I have masked the engine in half (as I intend to do it half see through and half not) we have a machine at work which will add a cast effect to the half that is not going to be see through. The metalizing technique I use need the parts to have a metallic appearance so to get that on the top of the pistons I use my mini lathe and just hold a file over the part whilst it's on (you could do the same with a dremel)
Re: Machine works 1/4 Porsche 911 boxer engine
Interesting work and the metal turned effect for the piston tops is going to look great.
Going to be a heck of a seam to clean up though on the same pistons.
kpisnuts
Post by kpisnuts »
So here is the next update.
Thought I would fill that crankshaft (hope that doesn't bite me later its very heavy now.
This is how they would have you assemble the pistons and con rods.
A bit of a problem getting rid of the seam lines like that.
I drilled out one half of the piston with a 4.5mm drill(same size as the gudgeon pins) so I can now glue both halves together and insert the gudgeon pin as would happen on the real thing.
Cleaned up and painted the con rods.
And all installed.
Hell of a lot of play in those pistons, could do with some piston rings (not included with the kit)
Wow that's a real engineering cluster thingy....friction won't be a issue...... :jd:
Cool model. Definitely looks like it would be fun to build
kpisnuts
Post by kpisnuts »
So here is a little update (a trial fit really)
And a trial run.
kpisnuts
Post by kpisnuts »
Hi all more work on the boxer engine (definitely have do do something with those jokes of carbs)
kpisnuts
Post by kpisnuts »
OK so this is how the carbs should look
Here is my start on them, I know loads more detail needed.
nice work. a lot to do on the carbs, but it will be worth it. That's a cool kit.
kpisnuts
Post by kpisnuts »
OK so more work on the carbs (I know they look a bit granular atm I will work on improving that.
