Pitts S2A - 1:72
Pitts S2A - 1:72
I had some free time yesterday and didn't feel like finishing up the Egg Build. So I pulled a new kit off the shelf. And by new, I mean, nearly 40 years old. Also, tiny, like really small. At least it is a low part count.
The build is fairly simple, but there is no really good way to mask it up for the painting. So, I just said, screw it, and painted the whole thing red. There are no really good views of the plane, so I am unsure if some of the offsets in the parts were supposed to be there. It looks like there could be an offset from the cowl to the fuselage. I sanded it down anyway. I removed most of the seams around the front of the plane.
I did get the decals on for the most part. 40-year-old decals are not fun to work with. They did not release from the paper, I had to peel them off. I don't know if I got more than a couple off in one piece. I didn't check to see how they looked this morning. I'll post another picture when I get home. I don't think this one is going to be a showcase model.
Re: Pitts S2A - 1:72
Unfortunately, the decals didn't improve with age. Some have silvered, and some have bits of the backing paper stuck to them. I had to let them sit so long that the paper disintegrated underneath them.
I'll probably still give it a few coats of Aquagloss, but this one will probably get stuck in the back of the case or in the bottom of the bin.
For what you had to work with that's a sterling effort.
You did very well with the decals
Cool little stunt plane
