From paper rolls to Steel Rolls
tiking
Post by tiking »
This little quick 'how-to', is for a future project I am planning a 1:24 scale diorama, which is going to involve some major scratch building and many detail objects. So stay tuned. If you know me than you know how I always like to find a cheap method of making things. It may not be the most perfect method, but the end results looks amazing. Within my own eyes, at least.
My methods used here are:
1. A cashier paper roll, which I sprayed the entire roll with Citadel black Chaos, my absolute best black spray primer on the market for modeling. I personally think so.
2. I brushed a mixture of light, dark rust, white, black, and grey pigments until I was satisfied with how it looked.
3. Then I took some odorless thinner and dabbed it on the entire roll covering every part of it. A tip is to not soak up the pigments too much. I went against this tip, only when I wanted a 'caked-up rusted' look, as in one of the photos. Let it dry.
4. After the thinner had almost dried up completely, I sprayed on a dull coat on the entire surface.
...and Voila!
Charles King
Be different; build different
Re: From paper rolls to Steel Rolls
tiking wrote: Wed Nov 23, 2022 8:56 pm This little quick 'how-to', is for a future project I am planning a 1:24 scale diorama, which is going to involve some major scratch building and many detail objects. So stay tuned. If you know me than you know how I always like to find a cheap method of making things. It may not be the most perfect method, but the end results looks amazing. Within my own eyes, at least.
Then I took some oderless thinner and dabbed it on the entire roll covering every part of it. A tip is to not soak up the pigments too much. I went against this tip, only when I wanted a 'caked-up rusted' look, as in one of the photos. Let it dry.
...and Voila!
Looks great and very realistic. Thanks for the tip
:clap: :clap: :clap:
ForeverPlasticKits
Post by ForeverPlasticKits »
Amazing!! :banana: :clap: :clap: :clap:
tiking
Post by tiking »
Glad to help guys.
Charles King
KalebB
Post by KalebB »
Crazy how that came out, looks very good
tiking
Post by tiking »
Thanks Kale.
Charles King
