Whippet 1/35 by Meng
A WW1 British early light tank.
The road wheels have a tricky distribution given there is 2 different types and the instructions don't make it exactly clear.
My fault I needed all those pegs as I forgot to add the mud slides and it required me to be forceful. The other side was fine.
Front view out of focus
I've only got one track set to finish, guns to do and she's all built.
Re: Whippet 1/35 by Meng
Nice subject Sir. Look at all those flat slab sides and the bolt work. A painter's dream :pop:
Stokesy44 wrote: Sun Feb 19, 2023 5:15 pm Nice subject Sir. Look at all those flat slab sides and the bolt work. A painter's dream :pop:
At least half of those slab sides were one piece that had a line through the mold so it needed to be bent by the builder carefully and only once. Marvellous bit of engineering as they all came together with no gaps or over laps.
Might be this painters nightmare all those nooks and crannies... :lol:
Looks good Digger. Those little Whippets were quite nippy for their time and, the story goes, gave Hans Guderian the basis of his ideas on panzer warfare.
Looking forwards to seeing the paint go on!
    RangerNeil wrote: Sun Feb 19, 2023 10:47 pm Looks good Digger. Those little Whippets were quite nippy for their time and, the story goes, gave Hans Guderian the basis of his ideas on panzer warfare.
    Right now the tracks are giving me a issue. They are the click together type, which they do. However they also fall apart.
    So how do I proceed painting them, atm I have them stretched out in a straight line all glued up. With the idea when the time comes I will just apply some tet to soften them and wrap them around. Painting them before I do that is the idea I was pursuing. I can just mask where the drive sprockets work on the track. Should work unless the tet leaks through the links and stuffs up the paint.... :think:
    digger303 wrote: Sun Feb 19, 2023 11:20 pm
    Sounds a good plan. I had similar issues with an Italeri BMP-1 that had a click together system. The instruction had you make the tracks in 4 groups:
    * The ground section,
    * The return section,
    * The section that linked the two around the drive sprocket,
    * The section that linked the idler sprocket.
    Perhaps you could do something similar? Minimises the risk of the tet damaging the paint....
      Just a word of warning. If you use TET on a visible painted surface, IT WILL damage your paintwork. I'd strongly consider adding the tracks to the tank and painting afterwards. :th:
      Stokesy44 wrote: Mon Feb 20, 2023 7:37 am Just a word of warning. If you use TET on a visible painted surface, IT WILL damage your paintwork. I'd strongly consider adding the tracks to the tank and painting afterwards. :th:
      Too late already primed it.... :doh: :lol:
      Base painted too ....I'm going to come unstuck any moment :lol:
      Color has gone down very nicely :clap: :clap:
      Engine95
      Post by Engine95 »
      Certainly an interesting subject. I seem to remember seeing a video on the Whippet by David Fletcher. Quite the storied combat history. Out of curiosity, what's the livery going to look like?
      F.D.N.Y. Box 55-8087
      In Memory of Brothers in Battle
      ForeverPlasticKits
      Post by ForeverPlasticKits »
      I really prefer the Whippet than the Mark family, only missing a turret and it looks so modern! Very good build, the paint is perfect! :thumb1: :thumb2:
      Stokesy44 wrote: Mon Feb 20, 2023 6:16 pm Color has gone down very nicely :clap: :clap:
      Thanks.
      Engine95 wrote: Mon Feb 20, 2023 9:22 pm Certainly an interesting subject. I seem to remember seeing a video on the Whippet by David Fletcher. Quite the storied combat history. Out of curiosity, what's the livery going to look like?
      The red and white panels.
      ForeverPlasticKits wrote: Mon Feb 20, 2023 10:00 pm I really prefer the Whippet than the Mark family, only missing a turret and it looks so modern! Very good build, the paint is perfect! :thumb1: :thumb2:
      Thank you.I also have a Hornet to do as well sometime.
      Gary30
      Post by Gary30 »
      Lovely stuff! Brings back good memories of when I built mine a few years ago now, looking forward to seeing how this turns out :clap:
      Portfolio
      Click here
      Gary30 wrote: Tue Feb 21, 2023 9:25 am Lovely stuff! Brings back good memories of when I built mine a few years ago now, looking forward to seeing how this turns out :clap:
      Thank you.
      I have a question about those horrible tracks. Did you use the number Meng said to use or add one extra link. I found I had to really stretch the links even then I am .05mm short and if I add a extra link they are way too lose and sloppy... :wall:
      Digger, you never cease to amaze me with your selection of kit builds. Seems by the photos that you managed to fully cover the kit as you were initially concerned about the davits and crannies. Weathering this should be real fun.
      This is looking really nice so far.
      DRUMS01 wrote: Wed Feb 22, 2023 5:44 am Digger, you never cease to amaze me with your selection of kit builds. Seems by the photos that you managed to fully cover the kit as you were initially concerned about the davits and crannies. Weathering this should be real fun.
      Is that a good amazement or a :wtf: is he doing now.... :lol: :lol:
      Only the tracks causing a bit of a issue. All falling apart and now seem to be slightly short. However I've cheated with CA and the tracks don't quite close, but it's hard to pick with a casual glance. I've extra links, but using even only one extra makes it look horrible as the links are so large.
      Weathering is going to be fairly light this time. No mud, a touch of light rust, muffler and this time some oil dot fading in a restrained manner. Well that's the plan today. It will have to wait until I come back as I'm off again for 5 days. My niece is getting married 2 days to get there and 2 days to get back ...stupid I know.
      Gary30
      Post by Gary30 »
      digger303 wrote: Tue Feb 21, 2023 12:05 pm
      Thank you.
      My memory is not what it used to be :scratch:: but I do recall the tracks being quite a wrestle to get round, so I'm pretty sure I used the number given by the instructions (My strange mind wouldn't allow me to add an extra link anyway). And the way they clip together to make them workable was so flimsy that they kept pulling apart when I was trying to install them on the tank.
      I was actually intrigued and went back to look at my build thread, 68 links per side, I said so myself here: viewtopic.php?p=319685#p319685
      Portfolio
      Click here
      Gary30 wrote: Wed Feb 22, 2023 7:39 am
      Thank you.
      I went back and reread your build thread (so good) and it was 4 yrs ago so your memory isn't as bad as you think. You got your tracks to fit, but mine must be riding up the sprockets slightly.
      It took me ages to set all 20 cable hooks in place and I was so careful not to bend any. Two days later I forgot and bent 3 :wall: :wall:.
      Very cool model and you're doing great! I'd really like to build one of these one day. Such an interesting subject
      Gloss coated, pin washed and working on the tracks at the moment having just added a light rust wash.
      Very nice work. Does it have any markings?
      Stokesy44 wrote: Tue Feb 28, 2023 7:45 am Very nice work. Does it have any markings?
      Yes I'm going to put them on tonight probably. Should have done it yesterday.
      Engine95
      Post by Engine95 »
      Looking great Digger! :cheers2:
      Engine95 wrote: Tue Feb 28, 2023 1:46 pm Looking great Digger! :cheers2:
      Here it is fella's all done. I've just been doing a bit occasionally and it kind of sneaks up on ya then you step back and say it's DONE !
      I went a little heavier on the weathering than I intended. Mainly because I didn't like it and I kept adding bits.
      Thanks for looking chaps
      I really dunno how I missed this one - sorry mate :oops:
      That's a cracking result though - I think the finished weathering looks spot on :th: :clap: :clap: :clap:
      Beautiful work again my friend ! that was built pretty fast !
      love the paint job.
      you know that here, whippets used to be the favorites cookies for kids when I was one or when my parents were ! :lol: Didn't like them but still they were quite popular. Marshmallow cream dip in chocolate
      Mpfiend
      Post by Mpfiend »
      Now that is really nice
      The weathering is just right and I really like the worn markings.
      Good job
      Regards,
      Keith
      Tomcat64 wrote: Fri Mar 10, 2023 11:06 am I really dunno how I missed this one - sorry mate :oops:
      I fly them low under the radar :lol:
      Thanks for the nice comment.
      Garion77 wrote: Fri Mar 10, 2023 11:13 am Beautiful work again my friend ! that was built pretty fast !
      love the paint job.
      Thanks for the kindness...Yes it didn't really take too long to build and it all mostly went together pretty well.
      The cookies sound a bit like snowballs. Thin biscuit base, marshmallow with a thin layer of milk chocolate.....pretty damn nice. I'm a bit like the
      cookie monster of old... :lol:
      Mpfiend wrote: Fri Mar 10, 2023 12:33 pm Now that is really nice
      Good job
      Your too kind..thank you
      MrBowcat
      Post by MrBowcat »
      Very nice, I think the weathering is spot on mate.
      Si vis pacem, para bellum
      Superb result. I dont think the weathering is overdone at all. It looks awesome. Its great that it hasnt just made the tank darker, the contrast with the insignia marking and the main hull color still look really metallic and realistic.
      I love it. :clap: :clap: :clap: :clap: :clap:
      Looks good to me mate :) In service, in the field, they used to collect a lot of muck so you may well have got the weathering off pat for active service as opposed to parade ground!!
      Well done!! :cheers2: :cheers2:
        Very nice indeed. While it may have been a short build thread, the results are wonderful.
        Are you going to build any more WW1 tanks to go with the armored cars you have?
        DRUMS01 wrote: Sat Mar 11, 2023 12:46 am Very nice indeed. While it may have been a short build thread, the results are wonderful.
        Thank you
        I'm always partial to WW1, but don't have a lot in my stash.
        Maybe 2 or 3 more tanks and 3 armoured cars from that era.
        I am painting a m114 atm and a old Tamiya Jackson, but after that I'm not sure what to build.
        ForeverPlasticKits
        It's my favorite WW1 English tank, well done digger303, it looks so realistic! :thumb1: :thumb2: :thumb2:
        smokeriderdon
        Post by smokeriderdon »
        Looks great. I have their Mark V male. Want to get this one as well. The WWI tanks intrigue me far beyond any targets that came after.
        ForeverPlasticKits wrote: Thu Aug 03, 2023 7:28 pm It's my favorite WW1 English tank, well done digger303, it looks so realistic! :thumb1: :thumb2: :thumb2:
        smokeriderdon wrote: Thu Aug 03, 2023 7:37 pm Looks great. I have their Mark V male. Want to get this one as well. The WWI tanks intrigue me far beyond any targets that came after.
        Thanks guys, I do like the old WW1 machines as they look way more interesting than the more modern stuff.
        Well you've done a cracking job mate
        Stokesy44 wrote: Fri Aug 04, 2023 8:00 am Well you've done a cracking job mate
        Thanks mate.
