Enzo Ferrari. Tamiya 1/24
Hi all, I am starting up this lovely kit. Found a bargain online so thought Id give it a shot. It is 1st class looking product of one of the world's most amazing cars.
Tamiya's base kit comes with carbon decals, metal transfers, red and orange clear parts, paint masks, mesh for intakes, clear parts for the chassis under the engine, and the doors and rear cowling open and close.
I also bought some photo etch detail up parts, and metal caps for the oil, petrol and 2 other fluid tanks, which have Ferrari engraved on them. It will be detailed up for a bit of realism, especially the big V12 engine and bay area.
Here's some pre production pics of all the bits:
These are the petrol, oil etc caps
Re: Enzo Ferrari. Tamiya 1/24
Those feul caps and the like are off the hook.
Is it the Ferrari that Tamiya isn't producing any more because of licensing problems ?
The caps are good. I didnt want them at first, being not too sure what they were, but the seller gave them to me at no cost, which was very nice of him.
Not sure, but it could be all Ferraris. Fujimi have the licence to build them at the moment, but apparently they are not too good. This one is made in 2004.
Some pics of the engine with a few wires added and some aluminium foil on the catalytic converters. The Tamiya carbon decals are very brittle and a real pita to apply, but its looking ok.
There's a lot more wires to add once the radiators are on and the engine is in the bay.
The real thing
The engine and bay are well underway, with extra wires and some carbon fibre.
Aluminium foil tape is used for the heat shielding, and has been pressed against wire mesh for the embossed effect.
Also stripped the foil from the catalytic converters, i had that wrong.
Did some work on the shocks, using springs, aluminium wire, and alu foil.
Damper fluid reservoirs
Removed plastic moulded springs
Aluminium foil
Coil spring wound from aluminium wire.
Test fit, detail painting needed
Nice scratch building skills.
Wow !
You have my attention :jd:
It's really looking great!
digger303 wrote: Sun Apr 30, 2023 1:01 pm Nice scratch building skills.
BigWall wrote: Sun Apr 30, 2023 11:19 pm It's really looking great!
Twokidsnosleep wrote: Sun Apr 30, 2023 6:04 pm Wow !
Thanks gents.
The finished shocks
PE parts for the fans on the front radiators.They were very hard to paint with a brush. Paint did not stick to the brass.
Also a bit of wire mesh under them. They are only partially glimpsed in the finished model though a hole in the front cowl.
Bit of work on the carbon decals at the rear end. Its started to get pretty crammed back there. The photos show all sorts of issues where the decals were patched up, but it's pretty invisible to the naked eye. Am painting it gloss, sanding and repainting to get it smooth and glossy like the real car..
Also stripped the paint off the p.e. fans and used a permanent marker to ink the metal. Looks much smoother. Carbon fiber decal around the radiator below the fan. They're much neater, but as you can see, there's not much to look at once the front cowl is in place.
Its a totally different level of model to the 360 Modena due to the amount of detail in the engine bay.
One day my kits will look like this.... :mrgreen:
digger303 wrote: Wed May 03, 2023 3:13 pm One day my kits will look like this.... :mrgreen:
Half arsed?
cor wrote: Mon May 08, 2023 8:44 am
Half arsed?
Better than the full monty :lol: :lol:
A little progress update. There is still a lot to do in the interior...
Johnj
Post by Johnj »
Looking really good cor. Scratch building at that size is a tough gig 👍
It's coming on a treat.
I did have that kit but i gave it away as i was all Enzo'd out. I had built the FXX and i had just finished the 1/12 Enzo plus i have another black version FXX with the scale motorsport detail set so i just couldnt find the motivation for another.
You have to display it with the doors and engine cover open ! It would be a crime to leave it all closed up !
Johnj wrote: Tue May 09, 2023 1:39 am Looking really good cor. Scratch building at that size is a tough gig 👍
Thanks John. Yes, the small scale is very tricky, but the finished thing should be a nice display.
I recently saw the wip of your big enzo. Man, that was top quality work on an amazing kit.
Seats in, seatbelts made from masking tape.
Still a lot to do...
Added these 4 silver coolant hoses. Left ones are roughened up aluminium wire, right ones are the cover off some elastic from a chocolate box. Came up ok, but at 1/24 the extra bits I'm adding are starting to get a bit fiddly for me.
Once the air box is detailed up, it should get some extra pop.
Air box installed. Carbon decalled and metal transfer ferrari badge. It's taking shape now...
Nice.
digger303 wrote: Tue May 16, 2023 3:28 am Nice.
Thanks man.
Johnj
Post by Johnj »
You've even simulated the oygen sensors on the exhausts ! What did you do that with ? Amd how did you know where the wiring went ?
I couldnt find any detailed pictures on the web for that sort of thing
Have you got one of these things sitting on your driveway 🙈
Johnj
Post by Johnj »
Johnj wrote: Tue May 16, 2023 5:20 pm You've even simulated the oygen sensors on the exhausts ! What did you do that with ? And how did you know where the wiring went ?
Johnj
Post by Johnj »
You've even simulated the oxygen sensors on the exhausts ! What did you do that with ? And how did you know where the wiring went ?
Johnj
Post by Johnj »
Dont know what happend there. I was trying to edit a spelling mistake.
Johnj wrote: Tue May 16, 2023 5:21 pm You've even simulated the oxygen sensors on the exhausts ! What did you do that with ? And how did you know where the wiring went ?
The missus and I have matching Enzos with personalised plates installed in one of our penthouses. They look good next to the matching Bugattis. :crazy:
There are many photos of this engine online - just search 'enzo engine' in google. Here's one pic showing some internals.
I just used very thin wire painted with tamiya 'rubber' paint, and a bit of heat shrink at the exhaust end as the connector painted silver. came out ok.
Johnj
Post by Johnj »
When i was doing my own i couldnt find any decent detailed pictures although it was a few years ago now. I ended up buying a CD from scale motorsport which had around 200 pictures on it i think.
Johnj wrote: Wed May 17, 2023 4:46 am When i was doing my own i couldnt find any decent detailed pictures although it was a few years ago now. I ended up buying a CD from scale motorsport which had around 200 pictures on it i think.
That would have been very handy. I think it's fast becoming my favorite car of all time.
Johnj
Post by Johnj »
It's defo up there with me as well.
Your carbon 'fibering' is exellent. So difficult to do on something like the airbox but you have absolutley nailed it !
REALLY nice work here :th:
Thank you for posting pics of the model of your car with us peasants
:D
Twokidsnosleep wrote: Wed May 17, 2023 6:55 pm REALLY nice work here :th:
:D
:th:
Just sharing my work with the common man
Bit more work done.
Lovely shine.
digger303 wrote: Fri May 19, 2023 1:43 pm Lovely shine.
TAmiya rattle can special
Johnj
Post by Johnj »
cor wrote: Fri May 19, 2023 2:19 pm
I prefer the Tamiya rattle cans for car bodies. Get the oven on full blast and drag the spray booth into the kitchen. It'll have a shine like you know what !
Probably better to wait till the wife's out or in extreme circumstances.....pick a fight :lol:
Johnj wrote: Fri May 19, 2023 3:17 pm
Good to know, but I'll duck the fight with the missus. In the end she wins, might not be here and now......you know what I mean. :roll:
Tamiya x-22 mixed 50/50 with Mr hobby levelling thinner gives a nice gloss too.
Mpfiend
Post by Mpfiend »
Nice progress, Paint looks really good.
I find that the tamiya aerosols can take a couple of weeks to harden properly so be careful of fingerprints whilst continuing the build.
Regards,
Keith
Mpfiend wrote: Sat May 20, 2023 9:23 am Nice progress, Paint looks really good.
Thanks for tip. Might be a good reason to do the body at the start of the build, let it all dry and polish it later.
Meanwhile, in Scotland... :bash:
Heres some pic of where its at now. The photo etch parts really look good, especially the rear end with the grille and the number plate with Enzos signature. The wiper is also an etch part, looks a lot better than the plastic kit one.
:clap: :clap: :clap:
Johnj
Post by Johnj »
Looks amazing cor 👍
And yeah, never marry a kickboxer 🙈
Johnj wrote: Mon May 22, 2023 10:17 pm Looks amazing cor 👍
Where did that come from :whistle: :lol:
This is done. What a great kit by Tamiya. Comprehensive pics to follow shortly.
:clap: :clap: :clap: :clap:
Done and photographed
All finished pics here: Enzo final pics
