**Ism Friday nights live at the bench what have you been working on for Friday 4th August**
"WHAT HAVE YOU BEEN WORKING ON THIS Month?" - A NEW SEGMENT OF FRIDAY NIGHT'S ISM LIVE "AT THE BENCH" SHOW!
* Open now until 1 hour before the show on Friday, 4th August*
Paul and the live crew
Re: **Ism Friday nights live at the bench what have you been working on for Friday 4th August**
First one is the Trumpeter release of the Savoia-Marchetti SM-79 in 1/48 scale. Augmented by an Edouard "Big Ed" PE set. Painted with Tamiya, Hataka and MiG colours. Its a nice kit, clean mouldings in the main with very little flash and no visible ejector marks. PE is making it a slow build- but very enjoyable.
    Second one is an un-named make of a 90mm figure. This one is a late era Roman Legionary. Onlybthe third I've ever done - the quality of moulding and fit of parts on this one was dire, needing much redial work and filler. Probably worst was the Scutum shield - it was badly warped and so thin in places it had actually torn the surface. Its getting there slowly though. The paints used are Tamiya and Vallejo with Ultimate washes over the base. The sheild decals are from Pedinghaus and were slightly oversize (by about 2mm) so needed trimming.
      ForeverPlasticKits
      Post by ForeverPlasticKits »
      This 2 last weeks i've been working on this marvelous kit (no putty is needed) but with a lot of parts : the T-90 from Zvezda 1/35 scale. Sanding is time consuming but the plastic is soft and high quality, after the OEZ Su-25 it's a real pleasure to build this kit :
      Return to “ISM News Shows”
