Suyata Fokker Dr.I
Suyata Fokker Dr.I
Looks like the Red Baron will have two entries (so far). I am building the Suyata version with the figure.
For an egg kit, there is quite a bit of plastic in the box. It is all molded very well and, in some places, pre-painted.
It also comes with two fuselage shells to show the interior cage.
I don't care for translucent parts that aren't supposed to be so. I will use the regular part, because the plastic feels better and I don't want any paint to react differently. The problem is that the white band they have pre-painted is very thick so I sanded it down and finished with a Ultimate buffer.
The tailpiece is also pre-painted, but it won't cause a problem because of how it is separated from the plane. I feared the tail breaking off, so I used a thin scribing tool and removed it myself.
I have cleaned up the the wing parts and will prime in Stynylrez pink.
Reason: Darn, I linked the wrong image in the last picture...
Re: Suyata Fokker Dr.I
This is an awesome version with much class...much like you :th:
Mine is a funkengrooven Fokker for a yahoo like me :D
Fun build! I did this one a few years ago and it was a joy to assemble.
I ran into a bit of a snag yesterday. I glued up the wing halves in preparation for priming and found a couple of issues. I sanded down the sprue gates too aggressively before assembly, and when I joined the two halves, the edges no longer lined up correctly. I am experimenting with a UV-reactive auto-body filler. The first use is promising. The second issue is the trailing edge of the wings doesn't close up precisely. Since the scalloped edge is a prominent feature, I needed to correct it. I glued up the wings with Revell Contacta as I felt it was a better cement for two flat surfaces. I used many clamps for a good bond. I then used a small drum sander on my Foredom rotary tool and sanded the scalloped edges. Once they were roughed in, I cleaned up the edges with sanding sponges and a coat of Tamiya Quick Drying Extra Thin. They now look like a single piece of plastic!
smokeriderdon
Post by smokeriderdon »
OK, this is definitely a much more advanced egg kit! Look forward to seeing your work on it. :)
The UV test was a mixed bag. I bought a tube of UV putty last year and just now used it.
Colad Fast Curing System Fine UV Putty 915011 https://a.co/d/6ciJWhg
It works great, but the tube was 80% hardened when I opened it for the first time.
Didn't know UV Putty was a thing. Very cool! Does suck that it was mostly hardened though.
aur0ra145 wrote: Fri Mar 08, 2024 1:35 am Didn't know UV Putty was a thing. Very cool! Does suck that it was mostly hardened though.
The product page states that it has a 12-month shelf life. I used it about 11 months after I bought it. What I don't know is how long it sat in Amazon's warehouse before they shipped it to me. It is a significant amount in the tube for $20, so it may be worthwhile to try again. It sure was nice to sand a seam less than a minute after applying the putty!
I have been doing a little more work on my egg plane. The first update is a dud. I wanted to drill out the heat shield on the Spandau machine guns. My hands are not steady enough and the holes are too rough. I have found a 3D file and will print some better guns.
I got the engine painted up. I actually decided to use the kit paint on the main engine halves but painted the other parts in assorted lacquers.
I primed the wood parts using a "light flesh" primer from Stynylrez.
I then used a "Grainer" brush and streaked on some Vallejo Air Mahogany.
I finished them off with some Tamiya Clear Orange.
As par for the course, I forgot the prop. :bash:
Excellent work :banana:
Twokidsnosleep wrote: Wed Mar 06, 2024 11:43 pm This is an awesome version with much class...much like you :th:
A pair of Fokkers from a pair of ........ ;)
Engine looks nice. Will be plenty visible on the Fokker too.
WordenB
Post by WordenB »
Very nice Matthew, it looks like quite a serious kit.
Thanks for the comments!
I did some detail painting and simple weathering on the wooden parts.
The inner frame was painted up and detailed with some smaller kit parts. Not much of this will be visible, though.
The engine got some weathering and was mounted to the inner frame. I also went back and painted the prop temporarily installed on the engine.
One thing to note is that the parts fit VERY tightly. If you paint them, you will also have to scrape off paint to get the pieces to fit.
Nice work. Looks great.
Simply excellent Matthew
Really like the wood effects you are getting
Engine looks fantastic :banana:
This is looking incredible! Very well done on the engine. :th:
I couldn’t move forward until I got the guns attached. My printer decided to quit working so a new one got ordered. I now have machine guns to paint!
Here is one of them (it may look familiar).
Twokidsnosleep wrote: Sun Mar 17, 2024 2:31 am Simply excellent Matthew
Word for word, that was what I was going to post. Beautiful wood effects (struts and prop) and that engine looks the absolute nuts! :clap: :clap: :clap:
Many thanks. I do like the way the wooden parts turned out. Keep an eye for a post about the techniques!
I got all of the red parts primed in Ultimate pink.
Pro Tip #1. If you are running low on primer you can use Pepto Bismol.
Pro Tip #2. I often lie for comedic effect.
I used Ferrari Red from Vallejo as the main color. I tried Pro Acryl for the white band, I like the coverage (one coat).
bfrd wrote: Mon Mar 25, 2024 2:13 am I used Ferrari Red from Vallejo as the main color. I tried Pro Acryl for the white band, I like the coverage (one coat).
Looking great!
Wait until the decals go on and then she really comes alive
I haven't gotten to the decals yet, but I have the base construction done.
I will attach the vertical stabilizer after I decal it.
Looking good. Never seen pink primer before!
Getting closer...
Looking good! :cheers2:
Return to “Build Threads”
