Figure Building and Painting sig, 2024
A more specific group build
Let’s build and paint something cool together. September 1 to December 31
:D :D :D
Apologies a lot of my work on the video so I didn’t get accused of lifting someone’s work from the internet
Re: Figure Building and Painting sig, 2024
I introduce this sig early with the hopes of having some more building participation
There is plenty of time to get something organized to build and it is WIDE open as to your subject
This could be a really interactive sig as this is not my forté and would love to see other’s methods
I'm all in! :th:
Count me in on this one.... so many figures, so little time....
Maybe
Possibly - I'll have to see what I can find figure-wise as there are none in the stash. :)
    Count me in - I have a fairly involved project in mind for this with 4x75mm figures and a lot of scenery if I can figure it all out...
    The closing date will be sometime in 2026 right?
    WordenB
    Post by WordenB »
    I'll have a go, I have some figures to do for a diorama and a group build will hopefully give me the kick I need to get them done.
    Oh boy ! this is a tempting one ! I've been wanted for a while now to try my hand at something like that on the fantasy world type... but boy I'm so out of money with my 2 vacations ! One of two done, the next one is next week :crazy: :lol:
    I'll think about it and see if I can find one pretty cheap or see with my brother if he can print me something.
    Garion77 wrote: Tue Jul 23, 2024 5:57 pm Oh boy ! this is a tempting one ! I've been wanted for a while now to try my hand at something like that on the fantasy world type... but boy I'm so out of money with my 2 vacations ! One of two done, the next one is next week :crazy: :lol:
    Sounds like a plan :D
    Ummm... I might have bought a couple more figures for this... :naughty:
    Might have found an "interesting" subject :)
      RangerNeil wrote: Sat Jul 27, 2024 2:50 pm Might have found an "interesting" subject :)
      Awesome!!!
      Tomcat64 wrote: Sat Jul 27, 2024 11:00 am Ummm... I might have bought a couple more figures for this... :naughty:
      Definitely try the print out way
      If you need some thing I could help too
      WordenB wrote: Tue Jul 23, 2024 5:43 pm I'll have a go, I have some figures to do for a diorama and a group build will hopefully give me the kick I need to get them done.
      Yes this is exactly the purpose. Get some figures into a diorama and it comes alive !
      Good to see some participants interested
      Been thinking about options to support figures while painting them :think:
      Cork collections are good…the cork with the wood base is from tequila I believe
      Ca glue a brass rod in and drill a hole in fiber base somewhere hidden
      These broken drill handles are handy
      If they have a bit of drill left to them they can grab a figure’s base or foot
      Plus the drill shank fits into this little figure vise
      Or into cardboard holder
      Any other ideas ??? :scratch::
      If the figure doesn't have a base.
      Drilling a hole into the foot and inserting a dress makers pin works too. You can stick it into any bit of scrap foam.It doesn't have to be removed either once the painting is finished.
      Cork is so easy to knock over with the full figure, but great for heads.
      IMHO :)
      If it's a 25/28mm sized figure on a base then I'll just hold the base.
      If it's a larger set of components such as a 75mm kit or a 1/35 figure without a base for a dio then I'll normally drill a hole somewhere in a joint (or as Digger says under a foot) and then use a cocktail stick. You can generally trim the point so it'll fit snugly into the drill hole without using glue, but I'll also add a dab of PVA to hold it.
      Almost inevitably whatever I use I'll end up with an angle that's just too fiddly to get to and will hold the figure (or part) directly, just being careful to keep it to minimum.
      Ooooooooh awesome! I didn't know that one existed!!
      :banana: :banana: :banana:
      Tomcat64 wrote: Sat Aug 03, 2024 9:13 am
      Neither did I. :)
      (Its come from an auction though so I hope to gawd its all there......)
        I'll have to pass finally unfortunately, for the moment, as personals problems are getting in the way of a few things at the moment. I'll concentrate on finishing my Gloster Javelin and Camel. I'll may be jump in later on. I'll still will go to my hobby store and look at what they have to offer.
        yes this is an interesting one ! and would be quite different.
        I 've got a Tamiya 1/16 pilot in the stash. Nothing terribly exciting, but anything to trim the stash rather than buy a new one.
        digger303 wrote: Sat Aug 03, 2024 2:46 pm ...but anything to trim the stash rather than buy a new one.
        :jd: :eeek: :jd: :eeek: :jd:
        Someone call a Doctor!!! Mr Digger's not feeling well!!!!!!!!
        Tomcat64 wrote: Sat Aug 03, 2024 5:41 pm
        Very perceptive of you TC :lol: :lol: I've made appointment :thumb1: :thumb1:
        Garion77 wrote: Sat Aug 03, 2024 1:25 pm
        Going to be an easy build I think. After the last two auction purchases I thought I'd better make sure its all there.
        Good news is everything is there.
        Not so good is far from being unopened in sealed bags the assembly is about 70% complete.
        Does this still qualify for inclusion??
          Doesn't bother me as most of the work in these figures is the painting.
          RangerNeil wrote: Tue Aug 06, 2024 6:21 pm ...
          I checked with the Oracle - you're good to go on this one :)
          As digger said - you've still got to paint him up :th:
          Cheers guys. Got to admit theres a lot of scope for the painting and thus a lot of learning. :)
          But first there will be a LOT of sanding!!!!
            RangerNeil wrote: Wed Aug 07, 2024 10:52 am Cheers guys. Got to admit theres a lot of scope for the painting and thus a lot of learning. :)
            Yes, the committee met and fully endorsed your entry
            Oh yeah, you're all smiles and laughing now but if he wins the damn SIG you will not believe the backlash you Mods will be in for.
            It'll make the Battle of Helms Deep look like a punch up in a pub car park.
            Stokesy44 wrote: Wed Aug 07, 2024 5:55 pm Oh yeah, you're all smiles and laughing now but if he wins the damn SIG you will not believe the backlash you Mods will be in for.
            Nah we are pretty lay back ....until he wins :twisted:
            :lol: :lol:
            digger303 wrote: Thu Aug 08, 2024 1:56 am
            :lol: :lol:
            If you're hearing this broadcast, you ARE the resistance......
            Hah!!! Never won a damn thing in all the 67 years I've been around so nothing for any one to worry about there!! :lol: :lol:
              "Win" you say?
              To win there would need to be judging....
              So I ask... are you prepared to be judged?
              We are a week away from September 1st start
              Get your figures ready!
              You are welcome to start from a new kit OR paint an already built or partially built figure and document the painting process
              Let’s just get some participation and posting here
              Mine’s a 3D purchased Sparta figure ….a bit rough around his edges and out of scale :roll:
              I have started removing print remnants and doing some putty on his muffin top
              This video is a bit long, but a great example of diorama and figure work
              The painting of flesh/skin is IMHO one of the hardest things to replicate
              Please feel free to share interesting painting videos you may have
              Another good reference for face painting
              An oil paint video for faces
              This should be fun. I've got tons of figures laying around in my pile of shame. I'm going to be giving the "Slap Chop" method a run for its money and see how that speeds up the process.
              The Honest Wargamer did a great video on it.
              aur0ra145 wrote: Sun Aug 25, 2024 11:13 pm This should be fun. I've got tons of figures laying around in my pile of shame. I'm going to be giving the "Slap Chop" method a run for its money and see how that speeds up the process.
              Cool
              Adding yours to my video watch list
              Gonna be a delayed start for me - got an unexpected and unwanted ambulance trip to hospital yesterday with suspected heart issues. :( No idea when I'll be home. :(.
                RangerNeil wrote: Mon Aug 26, 2024 10:16 am Gonna be a delayed start for me - got an unexpected and unwanted ambulance trip to hospital yesterday with suspected heart issues. :( No idea when I'll be home. :(.
                Awe crap mate that's not a great start to the week. At least they caught it and your still going. Will you need a op ?
                Take care and may the recovery be quick and painless.
                That's not good mate, hope they get you sorted & back to the bench soon :cheers2:
                Not a video but another source of ideas & inspiration (and needless to say a bottomless well of temptation...)
                I've got a pile of boxes for the project for this one, but I've gotta get that damned spaceship finished first :bash:
                Hope you are doing ok
                The heart is no joking matter
                Yawza! Hope you get to feeling better with a quick recovery.
                aur0ra145 wrote: Fri Aug 30, 2024 5:26 pm
                Back home. Typical medics - Monday I get half a dozen stood around the bed shaking their heads talking about erratic fibulations and what sort of major surgery is needed. Tuesday it turns out the whole pack of issues were down to having one of the arteries from the heart being shrunk in dia by 50% - which was fixed by shoving a stent in there and then kept in for obbo's overnight & Weds then sent home.
                Actually feeling quite let down after all Mondays build up. :)
                But - there was fun to be had! I dozed off during the procedure (took about 30 mins), got woken up by the lady operating the scanner thingy to find the doc who performed the procedure giving me the evil eye before saying in a VERY offended tone of voice "You SNORED throughout the whole procedure". :) :lol: Then whilst waiting for a bed to be found and wheeled in (they wouldn't let me walk) I was watching the nurse cleaning up all the protective sheets. She saw me watching and asked whether it bothered me seeing that amount of blood. Her face when I replied " No. Lost more than that in one go before now" was priceless.... :lol: :lol:
                Anyways - home now and clearing the bench ready for the Figure build!!!
                  RangerNeil wrote: Fri Aug 30, 2024 10:41 pm
                  Ha ha :lol:
                  Your already for the figure build then :D
                  Glad to hear the problem was so easily fixed. Probably got a lecture on cutting down on certain foods and exercising :whistle:
                  Return to “Special Interest Group Builds (SiGs)”
