Eduard 1:48 MkI Spitfire “Douglas Bager”
Welcome to my YouTube channel, bear with me as I’m new to this :tongue:
Since photobucket “amended” their service I’ll be starting with slide-shows of my previous builds. Some will be split into different sections, others will be “complete” builds, when I find out which is more popular I’ll stick to that.
At present I’ve no suitable video filming device, if the channel "takes off" maybe I’ll add “how to’s” and build reviews, but that’s a little way down the line.
pop over and have a look
https://www.youtube.com/channel/UCf_k7A ... yx-PcquHjA
leave comments and suggestions and hopefully I’ll improve
best rgds
John(shortCummins)
shortCummins
Post by shortCummins »
This is my build of the Eduard 1:48 MkI Spitfire flown by F/Lt Douglas Bader June 1940
Re: Eduard 1:48 MkI Spitfire “Douglas Bager”
Top job. I like the mottled under painting and the blue tac for the colour masking. Eduard make a good product, youve done it proud.
shortCummins
cor wrote: Wed Oct 30, 2024 8:23 am Top job. I like the mottled under painting and the blue tac for the colour masking. Eduard make a good product, youve done it proud.
thanks cor
it wasn't blue tac is was "smart putty" which is similar to "Panzer putty" or "silly putty" in that you can shape it to any shape however it will eventually return to its original shape so, for example, if you leave the "mask" overnight it will "flatten" and loose its shape!
the good thing about it is that it doesn't leave any residue, I've found that blue tac does, and, as blue tac, can be used over again.
rgds
John(shortCummins)
Return to “John Cummins”
