Hosting Change
The latest forum news and anouncements
Hosting Change
I am switching hosts for our server. I am currently unable to address the issues we are experiencing. I was planning to roll this change out a little more slowly, with as little impact as possible, but I think it is prudent to just try to get it done as quickly as possible.
A few notes about the change in hosts. The actual server will be approximately twice as powerful as the one we are on now. However, the biggest change is the structure of the hosting agreement. Instead of a simple hosting plan, I have set up a virtual private server. A VPS allows me to control all aspects of the server. An example of a change that I could make is increasing the number of concurrent database sessions (the error you have all been seeing). We are also changing our DNS provider to Cloudflare. While there may be occasional headaches associated with this move, in the long run, it will be far better for the site. By using Cloudflare as the DNS host, I can prevent connection floods before they ever reach the server. We will also be utilizing their CDN network, meaning that certain site elements will be sourced from a server closer to each individual user rather than always being served from the host. This should be seen as faster load times.
Along with the server change will be a name/address change. As many of you know, there is also a Facebook group called International Scale Modeller. Due to changes in management, these two sites are no longer connected in any way (other than the name). I have decided (with the admin team's consent) to change the site's name to "Global Scale Modeller." I am sure you recognize that this is quite a small change. The core identity of the site @Lee created remains the same, and it isn't going to change. While some existing links may temporarily not work, I will make sure they redirect properly. There will be a larger effort to rebrand the entire site, but initially, it will just be a name and a temporary logo change.
Ok, all of that is great, but what is actually happening when?
Later today (US Central), I will be modifying the forum to make it read-only. Existing Posts will still be visible, but new posts or edits will no longer be possible. I want to avoid turning off the forum if at all possible. This will allow me to start the backup processes without the danger of new data being created. Once the appropriate backups are created, I will begin transferring the data over to the new host and bring up the new site. When the new site is up, I will take down the old one and set up the redirect links. If something goes wrong (accidents do happen), the existing site can easily be brought back up, and we try again the next day.
The biggest caveat to all of this is the bot activity. If I can't block them long enough to complete the backup, I will have to turn the site off completely. Just know that if you can't see anything but the Maintenance Notification, I did everything I could to prevent it.
Re: Hosting Change
Roger all that Matthew, I'll wait until tomorrow before up loading anything, or could you/would it be best to wait for you to tell us?
Thanks again for all you're doing. :th:
Re: Hosting Change
Thank you Matthew for handling all of this.
I only do teefs
Re: Hosting Change
There should be a banner saying that we are in a read-only state. Once we enter read-only mode, it will either revert to normal (no banner) as International Scale Modeller or redirect to the new site, Global Scale Modeller. Either way, the site itself should let you know. The best case is you come back tomorrow and see GSM. If it is still ISM, I had to revert or stop the process. I will also make a post either way.
Re: Hosting Change
Thanks for taking this on Matthew - hope all goes well :cheers2:
Re: Hosting Change
Tomcat64 wrote: Wed Mar 04, 2026 9:42 pm Image
Move the entire website to a different host and modify it to our new logo,Hal
Well thing seem pretty normal around here at GSM
Re: Hosting Change
Seems to be working fine this morning :banana: well done Matthew :th: :cheers2:
Re: Hosting Change
:bash:
Ok, I found a snag. Email was not working. I have setup a new email service and am waiting on confirmation. Until then no notification emails will go out. Unfortunately, no email confirmations for new users will go out either.
Re: Hosting Change
Good work on looking after this site we all get so much from. Before this I never thought of what goes on in the background. I appreciate your work, which I imagine is headache inducing at times.
Return to “Forum News”
