Meng KV-2 Heavy Tank
Here is my entry!
Re: Meng KV-2 Heavy Tank
:banana: :banana: :banana:
Another one where the original design means you can't tell if its a real kit or an Egg kit :lol: :lol:
I got the wheels done, and test fitted. The poly caps do not hold the drive wheels on straight so these may get glued on.
After that I drilled out some of the parts that should be hollow.
I glued a few of the bits onto the main deck.
I hope to get a bit more done later this evening.
I got most of the construction done. Paint next.
God that thing looks top heavy...like the average female in Las Vegas :think:
Twokidsnosleep wrote: Mon Apr 06, 2026 11:21 pm God that thing looks top heavy...like the average female in Las Vegas :think:
Dare we ask exactly how you know this??? :twisted:
    It took me a while to get to painting since I had to clean a path to my spray booth!
    I now have everything in Mr. Surfacer 1500 Black.
    I will need to pick out a green from the shelf and try some modulation.
    I got the base paint down. I went for visual interest instead of realism, so some parts are steel where they should be green.
    I used a military green with a drop or two of yellow for the base paint. I then lightened with more yellow for a 1st highlight. After that I lightened again with light gray.
    I used a reddish brown for the tracks.
    Nicely done.
    I got almost all of the decals on. To be fair, they were all on at some point. I looked down and found that one of them was missing. I found it a couple of hours later, 3 rooms away. :scratch::
    Next up will be aging them with some green paint.
    bfrd wrote: Tue Apr 14, 2026 2:29 pm I got almost all of the decals on. To be fair, they were all on at some point. I looked down and found that one of them was missing. I found it a couple of hours later, 3 rooms away. :scratch::
    Your lucky to have found it, I'm always losing stuff. Still haven't found the decals for my Pibber although I did find a missing road wheel from a build 3yrs ago :shock: :lol:
    I had a productive day. The first pictures are from the aging step. I used a sponge and the green paint with a little yellow. I didn't mix it up perfectly so there is some modulation. I dabbed most of the paint off then went over the decals.
    Next, I mixed up some Red Brown with a bit of Nato Black and did some chipping.
    I then went in with a fine brush and painted some Nato Black in some of the larger chipped areas. Over that I added some Enamel Rust effects.
    I have a lot to learn with the technique, but for my first real try at layered chipping I think it looks great.
    I added a coat of Testors Dull Cote and then added a dark pin wash.
    I am calling this one done. I’ll post finals with the big boy camera tomorrow.
    :clap: :clap: :clap:
    Excellent job!! :cheers2: :cheers2:
      Return to “Build Page”
