Magnifying visor
Magnifying visor
Good morning all
Does anyone use a magnifier visor when modelling? I'm finding I have to take my glasses off more and more when working on detail stuff as my minimum focal distance through my glasses means I cant view small parts close up while wearing them.
Any advice would be much appreciated.
Thanks
Stokesy
Re: Magnifying visor
Stokesy44 wrote: Tue Apr 14, 2026 10:18 am Good morning all
Thanks
Stokesy
I do and I wear my glasses whilst wearing the visor.
I have the original USA manufactured product which is expensive and when I did I could only afford to buy it with 1 lens. After sometime they became
inadequate, I needed a higher resolution and so I searched and came across a cheaper version made in China of course. It came with 4 different lenses,after much internal debate I bought them and never regretted it. The lenses were great and the head gear was not quite as good. The original has a leather cushion around the forehead area while the knock off has synthetic material and it's biggest draw back being the side finger thumb nuts tend to work themselves loose.....bit of a pain.
So I use the Optivisor head piece and the Chinese lenses and it works fine no headaches or the like at all.
I don't recommend using a magnifier with a light type of solution as it's hard to keep parts in focus all the time because as you move around, twistt your head then you have to readjust all the time....a pain.
I don't know what the ones that clip to your glasses are like, but I imagine keeping ones glasses on maybe a problem.
The ones that are attached to a cap may work ok, but maybe might collect a few finger prints flipping it up and down. I have no experience with these either.
This is the Chinese one I bought like 6 or 7yrs ago I think.
https://www.aliexpress.com/item/3286447 ... 1819486122
The USA original will set you back about 200 bucks aud to get all the lenses.
I find mine ( original) to be very comfortable to wear for protracted periods.
Rubicon
Post by Rubicon »
It seems like it is so ingrained into me that as soon as I sit at the bench the progressives come off and the visor goes on. I haven't tried using them with my prescription glasses though.
digger303 wrote: Tue Apr 14, 2026 1:56 pm
Thank you Sir. I shall definitely look into this.
I'm looking for something better too. Thanks for the info.
I know some people do not like the wrap around the head flip visor type, so I will also suggest these. I found on Amazon between $17.00 and $39.00:
Thay all have several different magnifying strengths.
For me, I have better than 20/20 vision up close, so I rarely use mine (except when messing with PE on 1/350 or smaller ships).
Ben
