Uses of WD40 in modelling
rodders
Post by rodders »
Hello,
Does anyone use WD40 maintenance spray in modelling. I was thinking of using it as a cleaner before priming. i normally use airbrush cleaner but need to save the pennies and WD40 or equivalent is quite cheap and more readily available in comparison. Does anyone else use it this way.
Is there any other uses that anyone can recommend.
Thanks.
Gb64c
Re: Uses of WD40 in modelling
Post by Gb64c »
There are hundreds of uses for wd 40, funny but one is not lubricant
My bicycle guy told me to use it to wipe down my bike.
I would not use it on a model to prep for paint.
I use Windex to clean my models before paint
gb
gb64c
Fait Accompli
rodders
Post by rodders »
Gb64c wrote:There are hundreds of uses for wd 40, funny but one is not lubricant
gb
Thanks for the help gb.
Stay away fom WD40! At all cost!
Paints won't stick and oily residue will keep contaminating your paintjob overtime!
It gets everywhere! And I speak from experience.
My son sprayed it in my display case as a toddler and ruined everything!
And he still lives! LOL
WD40. Ain't a modeling cleaner!
Use Windex or SimpleGreen or SuperClean!
or a solution of warm water and dish soap
Rinse well and Air dry!
Good luck buddy!
rodders
Post by rodders »
schweinhund227 wrote:Stay away fom WD40! At all cost!
Good luck buddy!
Thanks. It was just a thought as it was used a lot while i was in the motor trade. But i'll take your advice.
Cheers.
Daishi12
Post by Daishi12 »
Hi Rodders, as the guys have said stay away from WD40 as it is apparently fish oil as the active ingredient. There is a good chance that there may be silicon in the mix as well which is a big no no for paint :) I would recommend that if you get WD40 on your hands, use a good quality alcohol based hand cleaner. Hope this helps. :th:
W.I.P.
Revell 1/72 P-47M
rodders
Post by rodders »
Daishi12 wrote:Hi Rodders, as the guys have said stay away from WD40 as it is apparently fish oil as the active ingredient. There is a good chance that there may be silicon in the mix as well which is a big no no for paint :) I would recommend that if you get WD40 on your hands, use a good quality alcohol based hand cleaner. Hope this helps. :th:
Thanks. I'll just use it for oiling my creaking joints :lol:
Daishi12
Post by Daishi12 »
Nope, doesn't work, otherwise I wouldn't need all the painkillers I'm on :lol:
W.I.P.
Revell 1/72 P-47M
rodders
Post by rodders »
I'm with you there. I rattle when i walk. :cheers2:
UKscalemodeller
Post by UKscalemodeller »
From what I understand (and I'd be happy to be corrected) but WD will perish rubber seals and O-rings.
If you want a cheap airbrush cleaner, use car screen wash.
rodders
Post by rodders »
UKscalemodeller wrote:From what I understand (and I'd be happy to be corrected) but WD will perish rubber seals and O-rings.
Thanks, you've saved me much hardship.
Regards.
keith
Post by keith »
Your right about the o rings
Nostalgia isn't as good as it use to be
rodders
Post by rodders »
thanks guys for the help.
