Academy 1:72 A-10A Thunderbolt II
Pedronski
Post by Pedronski »
For the Cold war Built I'll be having a go at the Academy A-10A Thunderbolt II
The Fairchild Republic A-10 Thunderbolt II is an American twin-engine, straight-wing jet aircraft developed by Fairchild-Republic in the early 1970s. The only United States Air Force aircraft designed solely for close air support of ground forces, the A-10 was built to attack tanks, armored vehicles, and other ground targets with limited air defenses.
The A-10 was designed around the GAU-8 Avenger, a rotary cannon that is the airplane's primary armament and the heaviest such cannon mounted on an aircraft. The A-10's airframe was designed for survivability, with protective measures such as 1,200 pounds (540 kg) of armor to enable the aircraft to continue flying after taking significant damage.
The A-10's official name comes from the Republic P-47 Thunderbolt of World War II, a fighter that was particularly effective at close air support. The A-10 is more commonly known by its nicknames "Warthog" or "Hog".
The first prototype Thunderbolt II made its initial flight on May 10, 1972. A-10A production commenced in 1975. Delivery of aircraft to USAF units began in 1976 and ended in 1984.
Info and image from Wikipedia
Here are a couple of shots of the cockpit assembly with decals.
Pedronski
(aka. Peter).
HWGuderian23
Re: Academy 1:72 A-10A Thunderbolt II
Post by HWGuderian23 »
Nice project mate! Looking forward to see your progress ...
Good luck :cheers2: !
fly1ngdutchm4n
Post by fly1ngdutchm4n »
Nice entry mate! :th:
Are you planning the camo from the box art or the one from the wiki pic?
Pedronski
Post by Pedronski »
Here are some pictures taking the model from assembly to paint and decal applications.
This has been the most challenging kit I've built so far (only 3), loads of flash, ejector pin marks everywhere. Also the pieces didn't seem to fit together very well at all. There was a lot of sanding and filling, but I'm pleased now it's getting near completion.
More soon...
Pedronski
(aka. Peter).
Pedronski
Post by Pedronski »
I've finished the A-10A but I've fogged the canopy. :doh:
Here are the final Photos...
A few other problems were the nose landing gear doors, I broke them off and the front decals, I didn't apply them very well.
Thanks for all your comments.
Pedronski
(aka. Peter).
