it's a bird, it's a plane and it's a whirlybird... MV-22B
SaG
Belgium
Post by SaG »
I know it is a late start, but here is my entry. Hasegawa's 1/72 MV-22B Osprey.
cheers
--Bennet--
Part 00: the in-box review
[youtube]MQ54U6RFoTA[/youtube]
- empty :roll:
http://www.sprueandglue.com (SaG)
Schoof
Re: it's a bird, it's a plane and it's a whirlybird... MV-22
Post by Schoof »
I was wondering if this one would count as a whirlybird. ... or as an prop aircraft ??
Having fixed wings and stuff
gosselin2112
Post by gosselin2112 »
Cool subject! I was wondering if the kit allows the props to move in either position. Or do you have to pick one and keep it static?
Russ
SaG
Belgium
Post by SaG »
@ Schoof: I'll leave it up to Paul to decide but the V-22 Osprey is designed to combine the functionality of a conventional helicopter with the long-range, high-speed cruise performance of a turboprop aircraft.
@ Russ: I'll show it during the build, but thanks to the plastic polycaps the engines can be changes depening on your needs. However, if you want to have the rotors in the vertical position, you have to use the plastic stand.
bye,
Bennet
- empty :roll:
kiwigav
New Zealand
Post by kiwigav »
Very cool choice
will look forward to your progress
Cheers Gav
