Making Sandbags
fly1ngdutchm4n
Making Sandbags
Post by fly1ngdutchm4n »
Hello guys!
I was making sandbags for a diorama, and reading the comments, it seems that there are a lot of people who want to know how to make them.
So I decided to do a little how to on making sandbags.
I want to be able to explain it as clearly as posible, so I had a little help with the text from Ronny Noben (roadkill) of Armorama. English is not my native language, so that why :mrgreen:
Here we go!
To make good sandbags you don't need many tools:
Milliput (or A+B Epoxy putty).
Smooth surface.
A knife.
A piece of cloth (cheese cloth ore fine mesh even a old sock will do).
Your fingers.
Mix the Milliput according to the instructions into a good homogeneous mixture. Use a smooth plate to work on.
Roll from this mixture several sausages from about 8-10 cm long and 6mm in diameter (if necessary put a little Talcum powder on your glass plate to prevent the Milliput from sticking to much). Cut this sausage in to little pieces of about 1 cm
Take these little lumps of Milliput between your fingers and form them into little blocks
Now you have created rectangular shapes, which you can starting to stack onto each other, by using a little pressure when stacking them, they will form themselves like sandbags. Don't worry about the different shapes and sizes you create by applying pressure. This is very natural because of the material and content of real sandbags. If you are using the sandbags to fortify a bunker or MG nest then you should also consider to put some wooden ammo boxes on the sides of the construction, these where placed to reinforce the sandbag construction.
Let the sandbags dry for about 10 minutes then use some cloth and press lightly on the bags to give them some texture. Don't forget to scribe some seams on the side of the bags using a pencil or knife.
Now painting them....
First I prime them flat black and paint it in a canvas base colour.
Then a black wash...
And finaly a light canvas drybrush for the highlights.
That is how I make sandbags. :thumb2:
I hope this small tutorial will help :th:
Cheers, Frans
Schoof
Re: Making Sandbags
Post by Schoof »
me like !!!
Radzy
Re: Making Sandbags
Post by Radzy »
great and simple idea Frans!
The finished sandbag wall looks amazing! especially with great usage of plastik aquarium plants!
Thanks for sharing.
Cheers,
Radek
WIP:
My Portfolio
My YouTube Channel
wappynutter
Re: Making Sandbags
Post by wappynutter »
Brilliant "How-to" Frans....
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
:bow:: :bow:: :bow:: :bow:: :bow:: :bow::
Thanks for sharing matey... :th:
Regards Andy...Image
fly1ngdutchm4n
Re: Making Sandbags
Thanks guys!
I hope it will come in handy for fellow modelers :thumb2:
Love sharing it, and love making tutorials.
mattsmith
Re: Making Sandbags
Post by mattsmith »
that look really easy to do, think i might give it a go.
fly1ngdutchm4n
Re: Making Sandbags
mattsmith wrote:that look really easy to do, think i might give it a go.
Good luck, and if you have any questions, just ask :th:
alextheblue
Re: Making Sandbags
Post by alextheblue »
That's a great tip Frans, going to have to give that a go. Ironically I have just had some Tamiya sandbags delivered and they don't look a patch on yours! :th:
www.alextheblue.com
Re: Making Sandbags
Post by Rob »
Nice. Thanks. I will definitely have a crack at this :th:
Re: Making Sandbags
Great how to Frans thanks for doing it.
badpirate
Re: Making Sandbags
Post by badpirate »
Nicely done :) this will help me out alot :)
Mike
On the bench, or in my case, the desk;
Hobbyboss 1/350 USS Greeneville
Tamiya 1/35 Russian Field Car GAZ67B
Trumpter 1/72 CH-47D Chinook
Bissyboat
Re: Making Sandbags
Post by Bissyboat »
That's magic! :thumb2:
Where`s my dinghy?
fly1ngdutchm4n
Re: Making Sandbags
you're welcome guys!
Glad I could help :D
