P38 lightning
Steve5762
P38 lightning
Post by Steve5762 »
Can anyone recommend the best kit to build of a p-38 lightning 1/48 scale?
5Craven
Re: P38 lightning
Post by 5Craven »
The Academy kits are meant to be pretty decent and if you can run to it Eduard do a couple of Limited Edition versions with resin, PE and masks such as this one here http://www.eduard.com/store/Eduard/Plas ... html?cur=1. Nige did a build of the base kit which is on the forum here http://www.intscalemodeller.com/viewtop ... =45&t=2175. Hope this helps.
Steve5762
Re: P38 lightning
Post by Steve5762 »
Yes both look great thanks tho must say the academy one looks tempting with the extra fire power
Re: P38 lightning
Steve5762 wrote:Yes both look great thanks tho must say the academy one looks tempting with the extra fire power
The academy one went together really well no fit issues at all and good detail in the cockpit and the panel lines were very crisp all for £17 only down side where the decals a little to thin if im honest but if your careful they go on really well would highly recommend it
