Need help with Dragon headphones
localjedi
Post by localjedi »
Could anybody help me with this figure set from Dragon (6214)?
It's got photo-etched and plastic parts for the headphones and I can't figure out how to put them together. The earpieces don't seem to fit in the PE parts. Does anybody have have experience with this kit and help me out? Thanks in advance!
Pete
"I love it when a dio comes together..."
viewtopic.php?f=29&t=13513
SuperDryBeef
Re: Need help with Dragon headphones
Post by SuperDryBeef »
could we see what it look like?
localjedi
Post by localjedi »
Uhm, sure. This is what it looks like:
I assume the pins on the earpieces need to go through the little loops in the PE part, but they don't fit. The pins are too big. Or am I getting something wrong?
Pete
DC87
Post by DC87 »
I think that is the idea:
You could try annealing (heating) the photo etch to soften it so it can be bent through, recovering the shape of the buckle when it is attached :scratch::
Dan C
Filling the workbench with:
Sopwith Snipe late post war
WW1 RFC SE5a
WW1-1/32 Snipe
localjedi
Post by localjedi »
Good photo. Thanks a lot !I think this does give me an idea what to do. I'll keep you updated when I have a result. :cheers2:
Pete
localjedi
Post by localjedi »
So this is my solution. I cut off a slice from the back of the earpieces with a hobby knife.
Then I glued the headband (or whatever that part of a headphone is called) to the earpieces with super-glue. After that I cut a small strip of PE to cover up the part where the headband and earpiece are joined. And that was basically it.
This is what it looks like on the figure:
Since this was my very first time using PE parts, I'm ok with the result. However, I think it looks a bit "plumpy" and there have got to be more elegant and realistic ways to represent a tank crew headphone. If any of you has any advice on that for me, hit me with it! :bash: :D
Pete
DC87
Post by DC87 »
If you want to make your own just grab some putty aka green stuff and sculpt away - that way you could get a thinner earpiece which is what looks clunky. What you have done looks good though, nice figure :thumb1:
Dan C
WW1 RFC SE5a
WW1-1/32 Snipe
localjedi
Post by localjedi »
Ok, next time maybe I'll try that. Thanks again for your help and your kind feedback. I'll post the whole dio I made the figure for here when it's finished. Damn!?! Why does it always take me so long to finish them??? Anyway, cheers! :cheers2:
Pete
