JU88A-4 1/48
mademodeller
JU88A-4 1/48
Post by mademodeller »
JU88A-4 1/48 Group Build Enter :banana:
You Tube Video Group Build Enter
[youtube]hN9xaq6pl8k[/youtube]
Trees shots
Clear parts
Pin City Trees
There more trees 24 in all but my stills camera stop working this is all I have for now but you can see all of them on the review video
Build review video
:pop: coming soon to your pc
Watch this space
I only hope I can get it done in time here hoping
My you tube
http://www.youtube.com/user/mademodeller
working on now
JU 87-B
Hobby boss P51 1/48
UKscalemodeller
Re: JU88A-4 1/48
Post by UKscalemodeller »
really looking forward to this one
patrickroos
Re: JU88A-4 1/48
Post by patrickroos »
Very nice entry, on my potential buy list, will follow this with great interest!
:th:
Good luck! :cheers2:
In progress:
mademodeller
Re: JU88A-4 1/48
JU88A-4 Review
I will be building this OOB
This model looked great in the box
but on opening it lots of pin marks all over it going to take a lot of work to do.
[youtube]__BjYZVPwyg[/youtube]
Depending the time I may do more Pilots & Ground crew
the revell ones
Also I am waiting for Ref books
Junkers Ju 88 Kampfgeschwader in North Africa
and
Luftwaffe Air & Ground Crew 1939–45
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
mademodeller
Re: JU88A-4 1/48
This will be my first entry GB building in this ISM forum
Some history for the JU88
Famous Warplanes - Junkers JU88 long 47min
http://www.youtube.com/watch?v=HkzMogPw7MQ
Junkers Ju 88 - Wings Of The Luftwaffe Short video 15 min
http://www.youtube.com/watch?v=OzS8_yBY8qI
The Junkers Ju 88 was a World War II German Luftwaffe twin-engine, multi-role aircraft.
Designed by Hugo Junkers' company in the mid-1930s to be a so-called Schnell bomber
which would be too fast for any of the fighters of its era the JU 88 proved to be suited to almost any role.
The assembly line ran constantly from 1936 to 1945, and more than 16,000 JU88s were built in dozens of variants.
The basic structure of the aircraft remained unchanged.
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
patrickroos
Re: JU88A-4 1/48
Nice Review dude!
Some ejector pin marks in not so god places but other than that seems like a nice kit.
Im sure it will build up to an impressive model of the Ju88 which I Love! :th:
In progress:
Re: JU88A-4 1/48
Nice start to a build thread, excellent stuff :cheers2: :thumb2:
T3hGuppy
Re: JU88A-4 1/48
Post by T3hGuppy »
Nice start to this one.
Will be watching to see how it goes together. :th:
Too much to list. !!
mademodeller
Re: JU88A-4 1/48
part 1 build
Here pic I manage to get of the clear parts
The line you can hardly see it with the eye but its there
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
mademodeller
Re: JU88A-4 1/48
JU88 Part 2
[youtube]9VviUWRJwsA[/youtube]
now after the sanding all the pin mark have gone
inside paintting now been done
The detail painting now started using Photos internet plus books for Ref
now the dry bushing can be done
The last thing to do is the Wash this time using Ink mix with A20
now I can start to button it up
Just the seat belts to do over the weekend
Thanks for looking see you all soon in Part 3
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
Opapapa
Re: JU88A-4 1/48
Post by Opapapa »
Really nice job with the cockpit! :th: :cheers2:
Olli
Jamesday1998
Re: JU88A-4 1/48
Post by Jamesday1998 »
Great work on the cockpit! :jd:
my youtube
conradschmid99
Re: JU88A-4 1/48
Post by conradschmid99 »
:thumb2: :thumb2: :thumb2:
"Interdum feror cupidine partium magnarum Europae vincendarum"
"Sometimes I get this urge to conquer large parts of Europe."
-unknown
Russ72
Re: JU88A-4 1/48
Post by Russ72 »
That's looking sweet. I had that bit of a sand back on the tail sits in there nicely. :thumb1:
Re: JU88A-4 1/48
Post by Rob »
Lot of work going into this! Doing a cracking job
mademodeller
Re: JU88A-4 1/48
Build Part 3.
[youtube]TcAf7QWL144[/youtube]
The main rear fuzz joints went fine as did the cockpit but the wings roots that the cockpit had a lots of filler to bring them out to the fuzz roots.
Most of the filling was done is in the sink marks & the cockpit to the rear fuzz.
This rear can-of-peas was made up to see if it fitted to the fuzz.
next came to the fin & the tail plan witch came out very good just a light sanding.
Tail plan.
The U/C was done at the same time so that it can be fitted at the end.
You can how I did these in the video.
Under side wings no filler was needed.
The upper wing had some filler in the tips & the sink marks.
These Parts were not to bad.
A little work and there fitted well.
Back with Part 4 soon.
Thanks for looking.
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
mademodeller
Re: JU88A-4 1/48
Part 5
[youtube]q8Rqa2D-tqs[/youtube]
The wheels are done by using Eduard Marks
Tail plan all done on filler needed.
also redone the resist panel lines.
Leaving the Eng cols off till later to aid mask off
A lot of sanding done this week
Thanks for looking hope yours is going good for you
see you all soon
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
mademodeller
Re: JU88A-4 1/48
Its been a long time but here the next bit :hi:
[youtube]dBCaBfa-RH4[/youtube]
Now I put the wings on there a very good fit
Next came the belts I use paint shop pro 9 to draw them print & cut them out then using tape on the back and fixing them with wood glue
as in the next 4 pictures.
Painting next using Lifecolor RML 78 for the under side.
some touch-up needed after the top was done.
I then put on U/C
Painting next using Lifecolor RML 79 for the top
and that's it for now.
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
eoinfinnegan
Re: JU88A-4 1/48
Post by eoinfinnegan »
Those seat belts look fantastic, you could go into buisness selling them :th:
Good luck with the rest of the build and also car hunting...thats bloody stressfull :bash:
mademodeller
Re: JU88A-4 1/48
:wall: Sorry this one was to go in to the last video :wall:
its mix up with other stuff
the JU88 start at 8.37 into the video
[youtube]P_9182fBBuI[/youtube]
The under side clear parts
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
mademodeller
Re: JU88A-4 1/48
Build Part 6
[youtube]LA7EfaFUgw4[/youtube]
Just done the white
and the doors
the fan in now
Also the rads are in place
with the pros on the under side is done
now to the top side in the next one part 7
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
mademodeller
Re: JU88A-4 1/48
Part 7 Top Side
[youtube]tLhe9V3dEDc[/youtube]
base & Pictures to come later
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
mademodeller
Re: JU88A-4 1/48
Last part 8
Dragon/Cyber Hobby 1:48 Ju88-A4 (Finnish)but not the big "D" ("Sand gets every wear")
Here are the final reveal photos of my entry into the group Bomber build
[youtube]UW6T5t7jaZQ[/youtube]
The model underside
underside from back
top view
From the Side views all around
One of the crew ("Sand gets every wear")
and the loader
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
mademodeller
Re: JU88A-4 1/48
Some information if you do not know the Ju 88
The Junkers Ju 88 was a World War II Luftwaffe twin-engine, multi-role aircraft. Designed by Hugo Junkers' Junkers company in the mid-1930s, it suffered from a number of technical problems during the later stages of its development and early operational roles, but became one of the most versatile combat aircraft of the war. Like a number of other Luftwaffe bombers, it was used successfully as a bomber, dive bomber, night fighter, torpedo bomber, reconnaissance aircraft, heavy fighter, and even as a flying warhead during the closing stages of conflict. Despite its protracted development, the aircraft became one of the Luftwaffe's most crucial assets. There were 15,000 Ju 88s built during World War II, more than any other twin-engine German aircraft of the period.
Specifications Ju 88 A-4
General characteristics * Crew: 4 * Length: 14.36 m (47 ft 2⅞ in) * Wingspan: 20.08 m (65.88 ft) * Height: 5.07 m (16.63 ft) * Wing area: 54.7 m² (587 ft²) * Loaded weight: 8,550 kg (18,832 lb) * Max takeoff weight: 14,000 kg[39] (30,865 lb) * Power plant: 2× Junkers Jumo 211J [40] liquid-cooled inverted V-12, 1,044 kW (1,420 PS, 1,401 hp) each
Performance * Maximum speed: 510 km/h (without external bomb racks)[39] (317 mph) at 5,300 m (17,388 ft) * Range: 2,430 km (max internal fuel)[39] (1,429 mi) * Service ceiling: 9,000 m (at average weight, without bombs) (29,500 ft)
Armament * Guns: * Standard armament o 1 × 7.92 mm (.312 in) MG 81J single, flexible machine gun in A-Stand in the windscreen, firing forward from both main cockpit windscreen glazing, with 1,000 rounds of ammunition.
This gun could be also fixed for strafing attacks. o 2 × 7.92 mm (.312 in) MG 81J single, flexible machine gun in the armored B-Stand at the rear of the main cockpit, in two separate mounts covering the upper rear hemisphere, with 1,000 rpg (2,000 in total)[42] o 1 × 7.92 (.312 in) MG 81Z twin, flexible machine guns in the armored Bola gondola under the cockpit, covering the lower rear hemisphere, with 1,500 rpg (3,000 in total).
Optional gun armament o Additional fitting of single 7.92 mm (.312 in) MG 15 machine guns, one to each side of the cockpit glazing in flexible "Donut" mountings, covering the side hemisphere. o
Additional fitting of a single 7.92 mm (.312 in) MG 15, MG 81J (on occasion a twin MG 81Z) or 13 mm (.51 in) MG 131 machine gun in A-Stand in the lower nose glazing.
A single 13 mm (.51 in) MG 131 was sometimes used in place of the 7.92 mm (.312 in) MG 81J or MG 81Z machine guns in the A-Stand, B-Stand or Bola gondola positions.
A modification of the A-4, the Ju 88A-13s could carry the WB 81A or WB 81B (firing with 15° downwards deflection) gun pods on external bomb racks, each "watering can" containing three 7.92 mm (.312 in) MG 81Z twin machine guns, for strafing enemy troops. o Aircraft may carry one 20 mm MG FF cannon in the nose for ground attack purposes, with 90 rounds of ammunition, in place of the Lotfernrohr 7 bombsight * Bombs: Max load 3,000 kg (6,614 lb), 3,600 kg (7,937 lb) with overload.
Variations: o 28 × 50 kg (110 lb) bombs in forward and rear internal bomb bay. o 28 × 50 kg (110 lb) bombs in forward and rear internal bomb bay and 6 × 250 kg (551 lb) bombs externally. o 28 × 50 kg (110 lb) bombs in forward and rear internal bomb bay and 2 × 500 kg (1,102 lb) bombs externally. o 10 × 50 kg (110 lb) bombs in rear internal bomb bay and 4 × 250 kg (551 lb) bombs externally. o 6 × 250 kg (551 lb) bombs externally. o 4 × 500 kg (1,102 lb) bombs externally. o 2 × 1,000 kg (2,205 lb) bombs externally. o 2 × 1,000 kg (2,205 lb) and 2 × 500 kg (1,105 lb) bombs externally. o 2 × 1,400 kg (3,086 lb) bombs externally. o 1 or 2 × 1,800 kg (3,965 lb) bombs externally. o 2 × 1,000 kg (2,205 lb) LMA and 2 × 500 kg (1,102 lb) LMB sea mines externally. o 2 × LT aerial torpedoes
Wings of the Luftwaffe - Ju-88
[youtube]56RhTpawi7E[/youtube]
colour footage
[youtube]BBXeTd61d3A[/youtube]
B/W footage Junkers Ju88 Beginning 1935 a tender for a fast bomber
[youtube]ka6_d12UEm8[/youtube]
My you tube
working on now
JU 87-B
Hobby boss P51 1/48
