Revell Handley Page Halifax B.MK.II (GR.MKII)
Jamesday1998
Post by Jamesday1998 »
so i have decided to do the handley page halifax from revell but rather than doing the normal black, dark earth and green that represents the night time bombers i will be doing the the coastal command variant
heres some reference pics
heres the revell colour call out of:
No58 squadron RAF, Stornoway, Scotland, early 1945
and the top
so lets get onto the sprues and i have to say this is a absolute bargain for under 20 quid!
the heap of sprues!
another nice touch from revell is doubled up sprues!
heres the wings
and a zoom in on the awesome panel lines :jd:
heres the fuselage half from the outside
sorry about the quality but heres the panel lines
and heres the cockpit and this is were the worst part is
no it isnt the detail but rather the tiny little ejecter pin mark!! :bash:
the same on the bombay!!!! come on revell :bash:
some of the insides
i have cut the sprue shots short because theres just so many of them!!
so here is the decals that are in perfect register and are thin :th:
the instructions
instruction 1
to instruction 99!!
this is it for the inbox review a bit of history will be on its way soon! :th:
my youtube
ModelingMatt
Re: Revell Handley Page Halifax B.MK.II (GR.MKII)
Post by ModelingMatt »
Terriffic choice from the looks of the kit. :th:
On the Bench: 1/72 Airfix Avro Lancaster B.III Special "The Dambusters"
Jamesday1998
ModelingMatt wrote:Terriffic choice from the looks of the kit. :th:
i am looking forward to staring it!!
my youtube
Jamesday1998
heres some quick shots of my dry fitting of the aircrafts fuselage and wings
the fit is very good in most places plus the reason why its doesn't look to good is because the tape didn't hold it together to well
and with the wings
my youtube
hey these parts look fimiliar
did take my kit lol
great start i did not dry fit mine yet
but it looks big when you do i see
good luck with your build
cheers Mark
T3hGuppy
Post by T3hGuppy »
Nice choice dude.
Looking very nice kit from Revell. :th:
Too much to list. !!
DC87
Post by DC87 »
Always good to see an RAF bomber - great start James.
Dan C
Filling the workbench with:
Sopwith Snipe late post war
WW1 RFC SE5a
WW1-1/32 Snipe
Jamesday1998
MarkVerploeg wrote:hey these parts look fimiliar
did take my kit lol
cheers Mark
LOL i didnt realise that you were going to do the same kit
its lucky i am doing the grII variant
my youtube
looking forward to this coming together james.
Jamesday1998
so here is my first update for this build
the finished painted cockpit side wall 1
heres it after a wash
i used three different washes to create different shading effects
and a little dry brushing
the other side wall
the rear undercarriage
after weathering
this time i used the flory washes and this
i put it on in streaks and then added enamal thiners to it to make it thinner and clench to the raised bits
after that i thought i might as well put the windows in but one was missing
i couldn't find it so i thought i might a well use this for the first time!
so i chose a spot and taped the front of the window up
and then applyed the micro klear from the inside
it turned out like this and i am pretty happy with it
this is my progress so far and apart from the mysterious disappearance of the window this kit has treated me well and i can
not wait to do more on it! :th: :banana:
my youtube
nice progress on your halifax
i still have to put my update on it on my thread
i don't know if you started on the engines but i find that they are very easy to missaline( hope i spelled that right)
i had to sand a pretty big seemline from mine
but otherwise this kit falls together
best of luck with your build
cheers Mark
patrickroos
Post by patrickroos »
Looking good so far!!! :th:
Painted, washed and dry brushed I dont Think the ejector pin marks will be a problem by the looks of it.
They kind of blend into the busy background.
Tip: Hard to get to pin marks can be sanded out with a pointy sanding bit on the Dremel.
But one has to be careful...a slip can be costly! :doh: (low rpm or the plastic is gone in no time)
:lol:
Tip: Dont tape when using Kristal Klear, just gently "smear it in" starting at the edges, until the hole is full, gently pull out the stick. The Surface tension in the PVA will hold it in place by itself.
That way it hardens really crystal clear when drying in the open.
In progress:
Jamesday1998
patrickroos wrote:Looking good so far!!! :th:
:lol:
thanks for the tips!
my youtube
Jamesday1998
MarkVerploeg wrote:nice progress on your halifax
cheers Mark
thanks for the heads up! and good luck with your build as well!
my youtube
Great update mate.
Jamesday1998
so hers and update and i have finished the cockpit and the wheel wells and nearly done with just some bits and bobs to be added to it!
heres a youtube vid of the cockpit just to warn you i do go over some of the stuff i have already been over
[youtube]qez3VOspYWU[/youtube]
heres my youtube account please subscribe
http://www.youtube.com/channel/UCjsWN0y ... d8mog/feed
so i will start by showing the wheel wells
heres the bottom of the wheel wells
here are some of the parts of the wheel well before they were assembled
heres when it is assembled but some pieces still need to be added
here is it added to the wing
some of the walls in the cockpit
them added to the main parts of the cockpit
the instrument panel was then added
i did dry brushing on this and also applyed some colour with a cocktail stick
the seat was then added
so was the control stick?? (if thats what its called)
completed cockpit!! :th:
practice fit
and the view of the cockpit
another birds eye view
I also had to drill holes for the version
so thats the update finished
hopefully i will be able to put the fuselage halves together soon :th:
my youtube
patrickroos
James, great progress!!! :thumb2:
Love what You have done so far and great vid! (tip: when you show detail parts try to shoot them on a black or blue background, then things show much better)
The windows turned out just fine, did You try to use kristal klear "on its own" without tape?
Just love the way your not afraid to try things, thats the best way to learn, just keep doing it.
Great build so far! :th: :th: :th:
In progress:
Jamesday1998
Thank you!
my youtube
Post by Rob »
I really like the look of this - I'll be back for more!
Jamesday1998
thank you
my youtube
This is another plane, like the Lancaster, that I don't have much knowledge of here in the USA. Watching your build, though, is making it much more interesting to me. You are doing such fine work on this!
T3hGuppy
Post by T3hGuppy »
Great looking interior on the this bird loving your work on it so far.
Will have to catch up on the videos soon
muskegman
Post by muskegman »
That cockpit looks brilliant, well done :th: . Looking forward to seeing you do some more.
Mark
Jamesday1998
Thanks guys!
my youtube
Coming on nicely James. I thought the Revell Halifax was a raised detail kit, but I guess they re-tooled it at somepoint. I built the older one, with the raised detail when I was younger. Found a lonely rudder from it last time I was at my parents too lol.
Coastal Command one should look good!
Jamesday1998
Thanks gav! It is a great kit with amazing detail! I would highly recommend it!
my youtube
FokkerDXXI
Post by FokkerDXXI »
Hey James, that looks really nice. I never build a bomber before ( don't have much money at the moment). I really like the effects you achieved with the wash.
oh, and check your google+.
Jos
Its DUTCH, not DEUTSCH!!!
Jamesday1998
Will do! And thank you
my youtube
Jamesday1998
after taking a couple of weeks off this build not because its an awful kit but just because its a long build, i decided to sit down and do a bit more work on the kit :th:
it may not be very much progress but i have learnt how to rescribe panel lines during the build! :th:
so i will show you the side walls of the front of the cockpit
i added a wash and the clear parts, i also did a small bit of dry brushing but not to much :th:
when i put the fuselage halves together there was a slight seam right near the cockpit!
i find the problem with this is the dust that youve made from sanding gets in the cockpit and it gets stuck in there :bash:
again on the front of the fuselage there was a gap! more filling!
i didnt want to display the bomb bay so i dint paint it in the end :th:
for sanding i will be using these magical tools!
VImage
for rescribing
after many attempts at rescribing i finally got a semi decent attempt :th:
this is the end of the update hope your enjoying the build so far and i hope all your builds are going well :th: :banana: :banana: :banana: :banana: :banana: :banana:
my youtube
HistoryRider
Post by HistoryRider »
Great looking bird! Great job on the interior! :th:
HistoryRider
Tamiya 1:35 M4 Sherman
Tamiya 1:35 Panzer IV AusfD
To Be Determined
T3hGuppy
Post by T3hGuppy »
Good job on the re-scribing dude.
Hope the rest goes well for you.
:th:
Jamesday1998
Thank you :th:
my youtube
ScaleModelling1105
Post by ScaleModelling1105 »
Looking very nice James. Keep up the good work buddy. :clap:
Will Hall
ScaleModelling1105
Check out my channel:
What's on the bench:
eoinfinnegan
Post by eoinfinnegan »
Your doing a fantastic job, Iv wanted to buy that kit for a few months but every time I go to buy it it's sold out :x
patrickroos
Good work and progress, looking nice!
:th:
In progress:
