Decal Solutions
IanS
Decal Solutions
Post by IanS »
Hi Guys, Sorry, once, again, for asking what must be the most basic of questions but what is the difference between Micro-Set, Micro-Sol and Micro Decal Film, are they all required for the application of Decals or can they be used on their own? I am sure that Paul's 'aircraft modelling techniques' guides will cover the subject but I am gathering together a fresh set of modelling tools and materials since returning to the hobby. Thanks Guys :cheers2:
Completed:
Eduard 1/48 Me Bf109E-4
Tamiya 1/48 Kubelwagen type 82
Work in progress:
Eduard 1/48 FW 190A-7
In my store:
Eduard 1/48 Spitfire Mk IXe
Re: Decal Solutions
Hi ian, that video should be up over the next week or so
The decal film is for use with printable decal paper as a sealing solution, when printing your own decals.
The micro set i tend to mix a little in luke warm water (just a tiny amount) that i then put the decals in, you can brush it on where needed but i find that unnecessary.
Once the decal has been placed on the model i let it set a little before applying the micro sol with a brush, this is then left to dry and re applied if needed. :thumb2:
alextheblue
Re: Decal Solutions
Post by alextheblue »
That's a great tip, adding Micro Set to the water! Thanks Paul! :th:
Apologies Ian for hi-jacking your thread. :oops:
Nothing I can really add to what Paul has said, other than I can thoroughly recommend the MicroScale products. I've tried other brands in the past for decals, but much prefer Micro Set & Micro Sol.
www.alextheblue.com
IanS
Re: Decal Solutions
Post by IanS »
Thanks very much Guys, that explains what three types are for perfectly. Looking forward to the concluding parts of the techniques build and the corsair build. :thumb1:
Completed:
Work in progress:
In my store:
Rodney
Re: Decal Solutions
Post by Rodney »
tanks for asking that Ian I was wondering the same thing and tanks to paul for the info
SgtSaboo
Re: Decal Solutions
Post by SgtSaboo »
Just a quick tip with the set and sol so you don't go nut's (like i did) trying to remember which is which. Just remember you use them in alphabetical order :thumb1:
Mike
-Items can be managed, people need to be led!
http://www.youtube.com/sgtsaboo
Switcher
Re: Decal Solutions
Post by Switcher »
SgtSaboo wrote:Just a quick tip with the set and sol so you don't go nut's (like i did) trying to remember which is which. Just remember you use them in alphabetical order :thumb1:
I was confused as well wrt which order to use them as well. I was tired of going back over videos so I numbered my caps 1 & 2, solved that problem nicely :)
On my desk:
1/350 Alpha Class Sub (Russian)
1/350 Akula Class sub (Russian)
1/350 USS Missouri USN Battleship BB-63
