What colour for DAK clothing
Nige99
Post by Nige99 »
What colour paint (valejo) would you use for Africa Corp clothing? or other paint would you use??
You can run, but you'll only die tired!
Re: What colour for DAK clothing
I just use Vallejo Russian Uniform. I used Green Ochre as a base for the helmets, highlighted up to Dark Sand. The German tropical uniform was only a bit greener than the standard grey/green uniform, but the material type faded quite easily in the sun and so often appeared much lighter.
So try a base of Russian Uniform and add small amounts of Khaki for successive highlights. It also doesn't hurt to add in some Dark Sand/Green Ochre or Khaki uniform bits, as it wasn't uncommon for DAK soldiers to replace parts of their kit with Italian uniforms etc.
Hope that helps.
