Pre-washing spues
IanS
Pre-washing spues
Post by IanS »
Hi Guys, a very simple question again, sorry :oops: . I have read in several places that it is a 'must' that spues are washed in a soapy solution, washing-up liquid, prior to assembly and painting to remove the mould release agent, has any anyone found if this is really necessary or is it something we all should do? Thanks Guys
Completed:
Eduard 1/48 Me Bf109E-4
Tamiya 1/48 Kubelwagen type 82
Work in progress:
Eduard 1/48 FW 190A-7
In my store:
Eduard 1/48 Spitfire Mk IXe
Re: Pre-washing spues
I never ever do it and have never had a problem yet :thumb2:
Tiger131
Post by Tiger131 »
i agree with paul never and i too have never had a problem
IanS
Post by IanS »
What can I say, great to have experts on hand, thanks very much Guys. :th:
Completed:
Work in progress:
In my store:
snappercity
Post by snappercity »
Built over 300 kits and never had an issue. It's one I think about from time to time but I'm normally half way through the build by then.
Mark - Too many models, Not enough time...
Airfix 1:72 Vulcan
Takom 1:35 Zwilling Flak 40
Roden 1:144 C-141B Starlifter
muskegman
Post by muskegman »
I have heard about the sprue washing thing too and in all the years I have been building I have never washed a thing and also have never had a problem :)
Mark
As above! Lol
Daishi12
Post by Daishi12 »
MrsModeller and I had a bit of a problem with the Airfix Westland Gazelle starter kit (think that Airfix had used their patent pending goat-fat mould release agent) but apart from that haven't had any problems at all with Airfix, Revell, Matchbox, Italeri or Tamiya.
I think if when you touch the plastic and it feels greasy then certainly bath-time it is :)
W.I.P.
Revell 1/72 P-47M
UKscalemodeller
Post by UKscalemodeller »
This comes up a lot and through my investigstions it seems that if you are spraying (either airbrush or can) you wont have a problem, with ahairy stick and acrylic pasint you may.
T3hGuppy
Post by T3hGuppy »
I only ever do this on resin and then only if I can feel any greasy residue.
Too much to list. !!
arss
Post by arss »
I also never did. I think it is a technique that comes from the old resin kits ...
Foxley
Post by Foxley »
I sometimes do.. Depends on the kit and my visual inspection to be honest, however, I do wash the model once built, leave it to dry and then put on the primer, that way I know no dust or impurities will affect the paint work.
I think I've only ever seen one kit that had mold release on in all my years.
ToddS
Post by ToddS »
I have never washed either. Only had one problem with a truck body a couple years ago. Other wise, I just dive in and build it.
Gb64c
Post by Gb64c »
Nope, the only wash mine get is at the end prior to primer, I spray Windex all over it and let it sit a few minutes, then rinse, good to go!
gb64c
Fait Accompli
timtamtung
Post by timtamtung »
I do wash mine with bit of warm water and detergent in a baking tray. Very quick and just blow dry. I think it does seem better as the sprues look cleaner. That's just me. 2min job
-tungy
To do list:
ForbesHutton
Post by ForbesHutton »
Washing the sprues won't make much difference, the glues will melt any release agent in the way, so it doesn't help assembly.
Washing the unpainted model makes more sense as there would still be some mold release on it and even if you have washed the sprues, oil from your hands will have gotten on the model.
I've only washed 2 models before painting, both from Eastern Europe makers (Russian or Ukrainian, or something near there), both were almost dripping in release agent.
FlyingCoffin
Post by FlyingCoffin »
I always wash my sprues. This comes as a habit from years of Warhammer model making and a good deal of the white metal had a release agent (powdery stuff) coating it. The older plastic sprues from 10 odd years ago had it on them as well. I don't think you'll have any trouble either way, but I like the feel the plastic has after a nice bath and it helps my butterfingers grip it... if that makes sense.
Cheers,
~Kyle
Per Ardua ad Astra
"In the end, this thing has earned its morbid moniker. This "flying coffin" lends a war which they call great, a glamour that it simply does not have."
On the Bench: On Deck:
  • Eduard 1:72 Fokker Dr. I
In the Aerodrome:
  • Nothing, yet!
