Help with washes!
Trainboy153
Help with washes!
Post by Trainboy153 »
Hello, I have been using washes one the interior doors of my b-17 (not what you expected, huh?) I have mad a ratio of about 2:1 ratio of water to paint, applied, waited to dry and then used a wet cloth to take the wash off, but it wont come off, even with soapy water from the faucet. I have managed to completely ruin my 262's underside with this. I tryed wiping it while wet but it takes all the paint off, any help? :wall: :wall: :wall: :wall: :think: :think: :think: :think:
Raptor
Re: Help with washes!
Post by Raptor »
Probably a silly question but you are talking about an Acrylic wash right?
Andy
WH40k - Dark Angel, Company Veterans <Status: Painted>
WH40k - Chaos Hellbrute <Status: Airbrushing>
"you can't stop the waves, but you can learn to surf"
Yeah you have just applied thinned paint so it won't come off. when using paint for a wash it needs to be ultra thin (like 80% thinner and 20% paint) and i prefer airbrushing it so it settles in recesses
Trainboy153
Okay, will try that and yes, an acrylic wash
Raptor
Post by Raptor »
ah ok I was just checking before I said the exact same thing Paul just did :thumb1:
Also might be worth noting to let your base coat dry fully before using a very thinned down wash, as the thinner has a tendency to agitate the paint underneath if your not careful....learned that the hard way .....
Andy
And if your wanting to remove most of the wash you need to apply a gloss coat before hand.
Trainboy153
The 8:1 ratio worked pretty well. Thanks. :-)
NovYank
Post by NovYank »
Like Lee said, make sure your surface is smooth with a clear coat varnish. Otherwise the wash will have problems spreading out.
Also, did you say water? I've never used H2O but I'm no expert. I'd use turpentine (in a well ventilated room) and paints if I didn't have the premixed washes. I also pin wash so I'm not quite sure if that has any jurisdiction.
NovYank wrote:Like PAUL said!!!.
:whip: :boom: :tongue:
5Craven
Post by 5Craven »
You two are getting to be like that other famous double act Ant & Dec :lol: No one knows which one of them is which but it hasn't held them back :mrgreen:
Trainboy153
How long should I leave it to set before I wipe it?
