help needed! how I paint head lights?
Frankbe
Post by Frankbe »
I'm build a Tamiya Hanomag Sd.Kfz. 251/1 kit. There is no clearly visible parts for the head lights.
How can I paint the head lights, so they seem more realistic?
Many thanks for your help!
Greetings
Frank
On the workbench:
Academy Jagdpanzer 38(t) Hetzer
Tamiya German 8ton Semitrack 20mm Flak Vierling Sd.Kfz. 7/1
Stash:
Pz.Kpfw. III Ausf.J (Tp)
Sd.Kfz.138 Panzerjäger 38 Marder III H
Flak 38(t) Ausf. M Late Production
Heuschrecke IVb "Garsshopper"
Dragon
Finished Work:
https://www.youtube.com/channel/UCVUlAI ... P-Q/videos
SgtSaboo
Re: help needed! how I paint head lights?
Post by SgtSaboo »
A bit of chrome foil or silver paint as a base and then build up the "glass" with your choice of clear. This can be Future, PVA glue that dries clear, clear enamel, or if you are brave enough epoxy or CA. I would recommend the PVA or clear enamel.
Mike
-Items can be managed, people need to be led!
http://www.youtube.com/sgtsaboo
Frankbe
Post by Frankbe »
That's all? Nothing special?
Thanks for the answer, I will try it.
Frank
On the workbench:
Stash:
Dragon
Finished Work:
On the halftrack its likely the headlight isn't a big glass fronted light as you would expect. Chances are the lights are small roundish things with a rectangular slot on the front. This reduces the light coming out the lamp for wartime night driving. You don't want to be givin away your position.
In that case I would just paint the slot black and gloss it.
Switcher
Post by Switcher »
^^what he said^^
On my desk:
1/350 Alpha Class Sub (Russian)
1/350 Akula Class sub (Russian)
1/350 USS Missouri USN Battleship BB-63
Frankbe
Post by Frankbe »
Yes, thank you. I thinknext time i try that.
I would it build out of the box. Scratch building is too difficult for me at this moment.
Tamiya would it build in this way, for me this is ok. In a few mounth I try to make it better.
Thank you i hope you can help me next time too.
Cu
Frank
On the workbench:
Stash:
Dragon
Finished Work:
Switcher
Post by Switcher »
Here's a good example of cat's eyes
[youtube]iWLjFF7YnR8[/youtube]
On my desk:
Frankbe
Post by Frankbe »
Hi switcher,
can you send me the link for this video, please?
I can't open it on my tab.
Thank you for your effort.
Frank
On the workbench:
Stash:
Dragon
Finished Work:
