panel lines
gaz45
panel lines
Post by gaz45 »
as i don't have an AB does the panel lines work as well using a brush i plan to use some XF-1 do i need to thin it at all any help would be appreciated
Re: panel lines
what model ? what scale ?
gaz45
Re: panel lines
Post by gaz45 »
revell 1:72 tornado
MikeyKb
Re: panel lines
Post by MikeyKb »
I've seen people use a fine-tip sharpie, that can work. The real issue will be painting over them so that they show through. Without the super fine/light coats of an airbrush, you might be better off thinking of post-shading, as opposed to pre-shading... just my $0.02
Mikey
gaz45
Re: panel lines
Post by gaz45 »
thanks mate i'll try that
