After market metal parts and paints
NAMBiohazard
Post by NAMBiohazard »
Hi to all
I was wonder what is the best way to prepare PE parts and metal barrels for paint.
Cause no matter what I do mine keeps flaking before I even finish the kit :wall:
The only aftermarket parts that seems to hold paint is metal tracks :scratch::
Keep the glue on the Sprue
Bjorn
rsrdevon
Re: After market metal parts and paints
Post by rsrdevon »
Im kinda new to pe and metal parts myself. But ive seen guys like coen just lightly sand their metal parts to get the paint to stick better. Also do you use primer? Sorry im not much help but I thought I'd try
trekfanj
Post by trekfanj »
I like using metal barrels for my tanks, and I usually rub it down lightly with 2000 grit sandpaper(dry) to give it a rough texture for the paint to stick to. For PE I do the same, but you have to be careful around raised details. And finally, I use a gray primer to cover the entire model.
Hope this helped at least a little bit.
Jarod
-Ralph Waldo Emerson
NAMBiohazard
Hi guys
Thx for the responses
I use for metal part usually Humbrol No.1 (primer)
But will try out the sanding as I usually just wash the model after construction with alcohol.
Bjorn
