Airfix 1:24 BAe Sea Harrier FRS-1
Joesdad
Post by Joesdad »
My neighbour said the other week,
"I've got a kit you could do for me, I'll dig it out"
"Ok Jas, no problem" says I
Imagine my surprise when he rocked up this....
It's enormous....
By a country mile the biggest kit I've ever attempted, I'm going to need your help.
First up... I need to fill in all the rivet detail.. Which filler would you suggest?
I will put up a picture review soon. Thanx chaps.
:eeek: :eeek: :crazy: :scratch:: :wtf:
Tim (Ted)
British Aviation In Scale
Re: Airfix 1:24 BAe Sea Harrier FRS-1
Wow! That's a big kit! I want all of those Airfix 1/24 scale kits for Christmas....but, that'll never happen, only in my dreams. If you feel a little shy about tackling it, I'll PM my address and you can send it to me! :tongue:
I look forward to watching this build thread!
Cheers, :cheers2:
Martin
Joesdad
Post by Joesdad »
Ha! Martin, I think It's going to be a slow burner...
Tim (Ted)
Willem
Post by Willem »
I think the technical term is 'mahoosive'! forget about filler and mix some plaster. :nena:
Seriously though, it's an Airfix Harrier in 1/24 should be an epic build mate. How much Dark Ocean Grey is that going to get through?
Better ring B&Q. :eeek:
All the best.
Will
Edward R Murrow
trekfanj
Post by trekfanj »
What scale is that Spitfire? It looks so tiny next to this behemoth!
Jarod
-Ralph Waldo Emerson
Joesdad
Post by Joesdad »
Willem wrote:I think the technical term is 'mahoosive'! forget about filler and mix some plaster. :nena:
All the best.
Cheers Will, it's going to be one of them... A bitch or an angel...
Tim (Ted)
Joesdad
Post by Joesdad »
trekfanj wrote:What scale is that Spitfire? It looks so tiny next to this behemoth!
It's a Tamiya 1:72 MkI trek, that Harrier is absolutely massive in comparison mate....
Tim (Ted)
Willem
Post by Willem »
Good luck with the build Tim. It will make an awesome build thread.
Will
Edward R Murrow
Joesdad
Post by Joesdad »
Right Will here we go....
First an apology, I know I said I'd do a review of the kit but its simply too big too get it all in..
What I think I'll do is try and review as we go along... We'll see how that turns out :think:
I've started on the cockpit first, unsurprisingly..
Basic is the word here, lets have a look at matey..
I have found this though...
Thanx for looking, not sure how often I'm going post but I'll see you soon
Tim (Ted)
martin57
Post by martin57 »
wow thats huge , good job its only got a short wing span . looking forward to following this one to the end good luck :thumb1:
Willem
Post by Willem »
1974 Blimey! Great start Tim. Good luck mate.
Will
Edward R Murrow
Apple
Post by Apple »
Is that control stick glued in place or dry fitted?
Because now the part that needs to point to the front of the plane, is pointing to the right of the plane.
Other than that, great plane.. Hope se comes together fine
Hakuna matata. :D
Joesdad
Post by Joesdad »
World Cup year too Will.
Is that right Apple? Bloody instructions....
Tim (Ted)
Apple
Post by Apple »
Well.. Is it right? Yes and no.
Your config is for a GR3
The FRS1 has this layout:
Guess Airfix used the GR3 molds.
So, if you want an accurate FRS mk1. It's the wrong stick.
If you just want a nice harrier, it's perfectly ok.
Hakuna matata. :D
Joesdad
Post by Joesdad »
Wow, thanks for that Apple looks like I might have to spin it about then.... Great start this is :doh:
Tim (Ted)
Apple
Post by Apple »
Anytime mate
Hakuna matata. :D
LeoDahlin
Post by LeoDahlin »
:jd:
Enough said.......
eoinfinnegan
Post by eoinfinnegan »
This is gonna be an EPIC build, it's bloody HUGE. Good luck with it
Joesdad
Post by Joesdad »
Don't hold your breath Eion, already cock up central..
Control column in wrong place and wrong way round..
So had bodge some tape and filler in resulting hole :doh:
Walking Dead extra....
Must do better.... Must do better...
:oops:
Tim (Ted)
eoinfinnegan
That's like something I would do..lol
eoinfinnegan
That pilot looks fantastic
Joesdad
Post by Joesdad »
Thanx Eion :shifty: I've said before that these iPhones must have some sort of filter on them...
I think I'm worrying about the finished article rather than concentrating on the step by step stuff, or I've bitten off more than I can glue...
Updates to follow...
Tim (Ted)
Prop72
Post by Prop72 »
Looking good and your figure painting is excellent!
Joesdad
Post by Joesdad »
Cheers AJ.
Updates...
Firstly a bit of engine stuff..
Turbine next and another example of Mr Hobby buffable, absolutely lovely for a metal look, I wonder if they would be any good for a complete NMF :scratch:: might have to give it ago...
Next is becoming the bane of my world! Started off with Mr Hobby putty..
Hmmm.... Not sure
After primer really not ok...
These bloody rivets are sucking the life outta me!!
Plastic Putty might be answer?
The pain will continue......
Tim (Ted)
Looking good so far, Father of Joe....the Pilot looks great! :thumb1:
I must have been out for the day to miss this post :(
Looking forward to seeing your next update....I want to see this baby go together...she's a big one! :eeek:
Cheers, :cheers2:
Martin
Joesdad
Post by Joesdad »
A monster Martin.
Please find enclosed rather dull pictures of some plastic...
Well, I've applied Purfect Plastic putty 'grout' style and rubbed down, destroying a sanding stick in the process, after a prime coat I HOPE should be ok...
Some stuff that sticks out the back.. Note the "moveable control surface", trouble in store I think...
On the upside though, finished the Pegasus engine. No Aries resin or exotic aftermarket here, just "out of the box" like Airfix intended..
I've got give it a wash tho...
On the down side tho, I don't think you'll get to see it.....just like Airfix intended?
I don't think it actually looks that bad really, seeing it came in '74, in fact this kit would be a micro-retailers dream there's loads of scope for extra detail. But I'm not there yet, think its a patience thing... Oh and an ability thing too...
Thanx for looking, hopefully will get to get the fuselage together soon...
Tim (Ted)
Willem
Post by Willem »
Looking great with all that hard work Tim.
Keep it coming.
Will
Edward R Murrow
Oh my, Tim....that was a lot of filling-in of those rivets etc and sanding to boot!
Hope it's smooth sailing from hereon?! :crazy:
Cheers, :cheers2:
Martin
Joesdad
Post by Joesdad »
Thanks Will...
I hope so Mart, although I'm not holding my breath :doh:
Lovely looking Typhoon btw mate...
Tim (Ted)
portlandjoe
Post by portlandjoe »
I think it's look great. I want to see it when it is done.
I came into this world with out my consent and will leave it against my will.
Joesdad
Post by Joesdad »
Thank you portlandjoe..
To convert the original kit to a FRS-1 you are required to remove the nose/cockpit section. Better get on with it then..
I've also painted the inside of the engine air intake..
And I've knocked up the nozzles...
And started on the fuselage..
Not a lot to show unfortunately and I don't think it's gonna get any better what with the World Cup starting any day.....
Anyway thanx for looking as always chaps.
Tim (Ted)
Joesdad
Post by Joesdad »
A little update between games...
I've been mostly cutting out auxiliary air intakes (?)!
Then chopping up a yoghurt carton to make the sides...
Fidderly work and my glue doesn't stick :wall:
This is on tho...
See yer soon....
Tim (Ted)
That is great work mate your really going the extra mile on this one can't wait to see more.
Joesdad
Post by Joesdad »
Thank you Nigel your very kind...
Oooh, managed to get some paint down...
On my fence......!!!!! What's all that about!!!!
Tim (Ted)
Muzrik
Post by Muzrik »
:eeek: Thats a beast
Cheers Steve
On The Bench:
Academy 1/72 Tempest Mk V
FishBowlMan
Post by FishBowlMan »
Did you pre-shade? :nena:
John
Joesdad
Post by Joesdad »
Hehe FishBowl no I didn't, going to post shade instead.....
Tim (Ted)
Joesdad wrote:Hehe FishBowl no I didn't, going to post shade instead.....
'Post' shade, lol!
Nice work on the aux intakes, I did that on Airfix's 1/48 Gr3, PITA!
Merlin
Post by Merlin »
Wow, that looks quite a challenge, I'm enjoying it so far, it's coming along nicely.
Andy Mac
On with the modelling...
Joesdad
Post by Joesdad »
Cheers Merlin.
It's been ages since my last update, so.....
Painted up the nozzle's with Citadel Leadbelcher (love that name)...
With a bit of Citadel Nuln oil and tried to be clever with a bit blue to make some heat staining....
Aux air intake's...
Managed to get fuselage together, what a pig!!!
Not a great fit either!!! She's really testing me now, not enjoying it, want it done and gone to be honest!!
What am I going do with this?
Thanx for looking, I'll try my best to not chuck it out of the window....
Tim (Ted)
Apple
Post by Apple »
Coming along real nice.
The damage i would fix with some styrene sheet.
Also remember with the harrier, the rear two exhaust are getting real hot due to jet exhaust.
The front two on the other hand are being driven by that big fan in the front, and get the by-pass air.
(On a commercial jet, the by-pass by-passes the engine and goes straight to the rear)
Hakuna matata. :D
Looks like you've made some progress since my 2 1/2 week absence while on vacation, Tim. Looks like a Bear of a kit to contend with! Keep with it....you're doing a great job so far mate. :)
Martin
Joesdad
Post by Joesdad »
Thanks Apple, I do need to get some sheet anyway...
Martin your back! Hope you had a nice time. Thank you buddy she's not making it easy, now I reckon I've got bits missing :wall: :wall:
Tim (Ted)
Joesdad wrote:Thanks Apple, I do need to get some sheet anyway...
We had a great time, mate....we drove just over 3,500 miles during the trip that extended from our home in New Hampshire to Asheville, North Carolina, Gatlinburg, Tennessee, back east to Raleigh / Durham, North Carolina, then up to Quebec City in Canada and back home?!
Sorry that you might have bits missing....hopefully they're internal items, that wouldn't be seen once she's all closed up?
Spook
Post by Spook »
Just found your thread,man that is a task and a half I don't envy you a bit but keep it going pal
simon
In the stash
Lots and lots of phantoms
Joesdad
Post by Joesdad »
Road trip!!! No Mart it's not internal and I've not started all the undercarriage bits yet... :eeek:
I don't envy me either Spook, thanks though bud.... :thumb1:
Tim (Ted)
Just catching up with this thread. Great work dude!
Don't know if you've seen this, http://www.harriersig.org.uk lots of tips for modelling the harrier. I used it a lot on my 1/48 GR3. (Sometimes I wished I hadn't, so much work!) if there's no stuff for the 1/24, I'm sure it would scale up from 1/48. I can see you're putting a lot of effort into this, so thought it may help. Good luck mate!
Joesdad wrote:Road trip!!! No Mart it's not internal and I've not started all the undercarriage bits yet... :eeek:
Ouch!! Can you get the missing pieces from Airfix still?
Post by Rob »
Impressive in every way! :th:
Joesdad
Post by Joesdad »
chief5437 wrote:Just catching up with this thread. Great work dude!
Thanks Chiefy old boy, I've found some of that, there's one build where a lad converted a GR1 to a FRS-1.... Very impressive but you've got to ask........why?
Tim (Ted)
