HELLO!
CJSomerset
HELLO!
Post by CJSomerset »
Hi guys,
I don't want to seem too presumptuous, but I thought I'd let you know that when I'm not modelling, I'm a pro (hate that term) photographer and retoucher. So if there's anything I can help with in this section just ask.
I actually teach model photography! But not the same sort of model :mrgreen:
Here's something I put together using the 109 I've just finished. ( I Sooooo wanted to retouch all the flaws! )
Re: HELLO!
Post by Rob »
Great 109!
Super photo too - it is beautifully lit. Would you mind describing (or showing a photo) how it was set up?
Also, those other models... :roll:
CJSomerset
Re: HELLO!
The set up was really simply, the model is sitting on a sheet of glass that's on top of a piece of white card. I've used one studio flash with a big soft box directly above the model. Being such a soft light means that it tends to wrap around the subject and the white base works like a reflector to light the underside.
If you don't have a studio with flash heads, use the sun! On a dull day it will have the same soft lighting. Get some white card and stand something on it, if it doesn't cast a shadow you are good to go, if it does have a shadow use a second piece of card to block out the sun. Shooting in the shadow is the same as a dull day.
Obviously if it's too dark, you'll be needing a tripod - but you should be using one anyway.
The sky background is all done in Photoshop I'm afraid!
moi196872
Re: HELLO!
Post by moi196872 »
Very nice pic, thanks for the advice.
Stéphane Viens
"From the Belle Province"
ON THE WORKBENCH
Re: HELLO!
Post by Rob »
CJSomerset wrote:The set up was really simply, the model is sitting on a sheet of glass that's on top of a piece of white card. I've used one studio flash with a big soft box directly above the model. Being such a soft light means that it tends to wrap around the subject and the white base works like a reflector to light the underside.
Glass on top of white card: genius! I have a big soft box type light (but no studio flash) so I will he giving this a go. Many thanks for the tip
The photoshop work is done very nicely
:th:
JayCub
Re: HELLO!
Post by JayCub »
Super 109 and i really like your photographic skills, and the sky in the background is a really nice touch and i look forward to more of your builds and photographs
Tom
