Coen's Nachtjagd panther
Hey Guys,
Here is my entry into Sebastian and Hendrik's Dangerous Cats SIG.
I'll be building a semi-mythical vehicle that was used in the late war.
A night vision equipped Panther tank.
I haven't completely decided if I'm going to use the interior bits that I have here, but I'll think about it.
It's in pretty bad shape.
I'll be adding a crew though.
This will be a vehicle that would have been somewhere on the Eastern Front in April of 1945.
I will be making her an ambush camo Panther with late winter white wash that is about done in and all worn off.
Many of these things I haven't done before so it should be interesting to see what happens.
This is really long, but I'll be using this on and off during the build and it makes it easier for me to find.
Just scroll down to find the photos and videos.
The History!
The Panther tank
From Wikipedia, the free encyclopedia
Panther
Panther Ausf. D tanks, 1943. The D model can best be recognized by the drum-shaped cupola.
Type Medium tank
Place of origin Nazi Germany
Service history
In service 1943–1945 (Nazi Germany)
Used by Nazi Germany
Kingdom of Hungary
Kingdom of Romania (postwar)
Soviet Union (captured)
France (captured, postwar)
United Kingdom (captured)
Wars World War II
Production history
Designer MAN AG
Designed 1942
Manufacturer MAN, Daimler-Benz, MNH
Produced 1943–1945 (1946- 9 post-war for British Army)
Number built about 6,000[1]
Specifications
Weight 44.8 tonnes (44.1 long tons; 49.4 short tons) [2]
Length 6.87 metres (22 ft 6 in)
8.66 metres (28 ft 5 in) gun forward[2]
Width 3.27 metres (10 ft 9 in)[2]
3.42 metres (11 ft 3 in) with skirts
Height 2.99 metres (9 ft 10 in)
Crew 5 (Driver, radio-operator/hull machine gunner, commander, gunner, loader)
Armor 15–120 mm (0.59–4.72 in)
Main
armament
1 × 7.5 cm KwK 42 L/70
79 rounds [2]
Secondary
armament
2 × 7.92 mm Maschinengewehr 34
5,100 rounds
Engine V-12 petrol Maybach HL230 P30[2]
700 PS (690 hp, 515 kW)
Power/weight 15.39 PS/tonne (13.77 hp/ton)
Transmission ZF AK 7-200. 7 forward 1 reverse[2]
Suspension double torsion bar, interleaved road wheels
Operational
range
250 km (160 mi)
Speed 55 km/h (34 mph) (first models), 46 km/h (29 mph) (later models)
Panther is the common name of a medium tank deployed by Nazi Germany in World War II from mid-1943 to the end of the European war in 1945. It was intended as a counter to the Soviet T-34, and as a replacement for the Panzer III and Panzer IV. While never replacing the latter, it served alongside it and the heavier Tiger tanks until the end of the war. The Panther's excellent combination of firepower, mobility, and protection served as a benchmark for other nations' late war and post-war tank designs, and it is regarded as one of the best tanks of World War II.[3]
Until 1944, it was designated as the Panzerkampfwagen V Panther and had the ordnance inventory designation of Sd.Kfz. 171. On 27 February 1944, Hitler ordered that the Roman numeral V be deleted from the designation.
The Panther tank was a compromise of various requirements. While having essentially the same engine as the Tiger I tank, it had better frontal armor (including the benefit of a sloped armor, increasing effective armor depth), better gun penetration, was lighter and thus faster, and could traverse rough terrain better than the Tigers. The tradeoff was weaker side armor. The Panther proved to be deadly in open country and long range engagements, but vulnerable in close-quarters combat. Also, the 75 mm gun fired a slightly smaller shell than the Tiger's 88 mm gun, providing less high explosive firepower against infantry.
The Panther was also far cheaper to produce than the Tiger tanks, and only slightly more expensive than the Panzer IV, as its design came to fruition when the Reich Ministry of Armament and War Production was making great efforts to increase war production. Key elements of the Panther design, such as its armor, transmission, and final drive, were compromises made specifically to improve production rates and address Germany's war shortages, whereas other Over-engineered elements such as its highly compact engine and its complex suspension system remained. The result was that Panther tank production was far higher than what was possible for the Tiger tanks, but not much higher than what had been accomplished with the Panzer IV. At the same time, the simplified final drive became the single major cause of breakdowns of the Panther tank, and was a problem that was never corrected.
The Panther tank arrived in 1943 at a crucial phase in World War II for Germany. Rushed into combat at the Battle of Kursk with un-corrected teething problems, which resulted in breakdowns and other equipment failures, the Panther tank would thereafter only be fighting outnumbered in Germany's steady retreat against the Allies for the remainder of World War II. Its success as a battlefield weapon was thus hampered by Germany's generally declining position in the war, with the loss of airpower protection by the Luftwaffe, the loss of fuel and training space, and the declining quality of tank crews. Nevertheless, the Panther tank commanded respect from the Allies, and its combat capabilities led directly to the introduction of heavier Allied tanks such as the Soviet IS-2 and the American M26 Pershing into the war and the development of the formidable British Centurion Tank, even though it appeared too late to participate in World War II.
Design
Albert Speer examines a T-34 in June 1943
The Panther was a direct response to the Soviet T-34 and KV-1 tanks. First encountered on 23 June 1941,[4] the T-34 outclassed the existing models of the Panzer III and IV.[5] At the insistence of General Heinz Guderian, a special Panzerkommision was dispatched to the Eastern Front to assess the T-34.[6] Among the features of the Soviet tank considered most significant were the sloping armor, which gave much improved shot deflection and also increased the effective armor thickness against penetration, the wide track, which improved mobility over soft ground, and the 76.2 mm gun, which had good armor penetration and fired an effective high explosive round. Daimler-Benz (DB) and Maschinenfabrik Augsburg-Nürnberg AG (MAN) were given the task of designing a new 30- to 35-ton tank, designated VK30.02, by April 1942 (apparently in time to be shown to Hitler for his birthday).
Panther Ausf. G
The DB design resembled the T-34 in hull and turret form. DB's proposal used a leaf spring suspension, in contrast to the T-34s coil spring suspension. The leaf spring suspension lay outside of the hull. Subsequently, the hull was more narrow, offering a smaller turret ring. Thus, the DB turret was necessarily smaller than that of the MAN design. The main advantages of the leaf springs over a torsion bar suspension were lower hull silhouette and a simpler shock damping design. Like the T-34, the DB design had a rear drive sprocket and a forward situated turret, but unlike the T-34, the DB design had the preferred three-man turret crew: commander, gunner, and loader. As the planned L/70 75 mm gun was much larger than the T-34's, mounting it in the Daimler-Benz turret was difficult. Plans to address the space limitations by reducing the turret crew to two men were considered, but were eventually discarded as experience had shown this to be a less effective arrangement.
The MAN design embodied more conventional German thinking with the transmission and drive sprocket in the front and a centrally mounted turret. It had a gasoline engine and eight torsion-bar suspension axles per side. Because of the torsion bar suspension and the drive shaft running under the turret basket, the MAN Panther was higher and had a wider hull than the DB design. The Henschel firm's design concepts for their Tiger I tank's suspension/drive components, using its characteristic Schachtellaufwerk-format large, overlapping, interleaved road wheels with a "slack-track" using no return rollers for the upper run of track were repeated with the MAN design for the Panther. These large, rubber-rimmed steel wheels added to the protection of the hull from a lateral penetrating shot.
The two designs were reviewed over a period from January through March 1942. Reichminister Todt, and later, his replacement Albert Speer, both recommended the DB design to Hitler because of its several advantages over the initial MAN design. However, at the final submission, MAN improved their design, having learned from the DB proposal, and a review by a special commission appointed by Hitler in May 1942 ended up selecting the MAN design. Hitler approved this decision after reviewing it overnight. One of the principal reasons given for this decision was that the MAN design used an existing turret designed by Rheinmetall-Borsig, while the DB design would have required a brand new turret to be designed and produced, substantially delaying the commencement of production.[7]
Since the Tiger had originally been designed to weigh fifty tons but as a result of Hitler's demands had gone up to seventy five tons, we decided to develop a new thirty ton tank whose very name, Panther, was to signify greater agility. Though light in weight, its motor was to be the same as the Tiger's, which meant it could develop superior speed. But in the course of a year Hitler once again insisted on clapping so much armor on it, as well as larger guns, that it ultimately reached forty eight tons, the original weight of the Tiger.[8]
Production
The MAN design also had better fording ability, easier gun servicing and higher mobility due to better suspension, wider tracks, and a bigger fuel tank. A mild steel prototype was produced by September 1942 and, after testing at Kummersdorf, was officially accepted. It was put into immediate production. The start of production was delayed, however, mainly because there were too few specialized machine tools needed for the machining of the hull. Finished tanks were produced in December and suffered from reliability problems as a result of this haste. The demand for this tank was so high that the manufacturing was soon expanded beyond MAN to include Daimler-Benz (Berlin-Marienfelde, former DMG plant), Maschinenfabrik Niedersachsen Hanover (MNH, subsidiary of Eisenwerk Wülfel/Hanomag) and Henschel & Sohn in Kassel.
The initial production target was 250 tanks per month at MAN plant Nuremberg. This was increased to 600 per month in January 1943. Despite determined efforts, this figure was never reached due to disruption by Allied bombing, manufacturing bottlenecks, and other difficulties. Production in 1943 averaged 148 per month. In 1944, it averaged 315 a month (3,777 having been built that year), peaking with 380 in July and ending around the end of March 1945, with at least 6,000 built in total. Front-line combat strength peaked on 1 September 1944 at 2,304 tanks, but that same month a record number of 692 tanks were reported lost.[1]
Allied bombing was first directed at the common chokepoint for both Panther and Tiger production, the Maybach engine plant. This was bombed the night of 27/28 April 1944 and production was shut down for five months. A second manufacturer factory had already been planned, the Auto Union Siegmar plant (former Wanderer car factory), and this came online in May 1944.[9] Targeting of Panther factories began with a bombing raid on the DB plant on 6 August 1944, and again on the night of 23/24 August. MAN was struck on 10 September, 3 October and 19 October 1944, and then again on 3 January and 20/21 February 1945. MNH was not attacked until 14 and 28 March 1945.[10]
In addition to interfering with tank production goals, the bombing forced a steep drop in the production of spare parts. Spare parts as a percentage of tank production dropped from 25–30 percent in 1943, to 8 percent in the fall of 1944. This only compounded the problems with reliability and the numbers of operational Panthers, as tanks in the field had to be cannibalized for parts.[11]
Production figures
Panther tank production line
The Panther was the third most produced German armored fighting vehicle, after the Sturmgeschütz III assault gun/tank destroyer at 9,408 units, and the Panzer IV tank at 8,298 units.
Production by type
Model Number Date Notes
Prototype 2 11/42 Designated V1 and V2
Ausf. D 842 1/43 to 9/43
Ausf. A 2,192 8/43 to 6/44 Sometimes called Ausf. A2
Ausf. G 2,953 3/44 to 4/45
Befehlspanzer Panther 329 5/43 to 2/45 Converted
Beobachtungspanzer Panther 41 44 to 45 Converted
Bergepanther 347 43 to 45
Panther production in 1944 by manufacturer [12]
Manufacturer % of total
Maschinenfabrik Augsburg-Nürnberg (M.A.N.) 35%
Daimler-Benz 31%
Maschinenfabrik Niedersachsen-Hannover 31%
Other 3%
Cost
One source has cited the cost of a Panther tank as 117,100 Reichmarks (RM). This compared with 82,500 RM for the StuG III, 96,163 RM for the Panzer III, 103,462 RM for the Panzer IV, and 250,800 RM for the Tiger I. These figures did not include the cost of the armament and radio.[13][14] In terms of Reichmarks per ton, therefore, the Panther tank was one of the most cost-effective of the German armored fighting vehicles of World War II. Using conscript labour on the production lines greatly reduced costs, it also greatly reduced reliability. French army studies in 1947 found that many Panthers had been sabotaged in production. [15] However, these cost figures should be understood in the context of the time period in which the various armored fighting vehicles were first designed, as the Germans increasingly strove for designs and production methods that would allow for higher production rates, and thus steadily reduced the cost of their armored fighting vehicles. For example, another source has cited the total cost of the early production Tiger I in 1942–1943 to be as high as 800,000 RM.[16]
The process of streamlining the production of German armored fighting vehicles first began after Speer became Reichminister in early 1942, and steadily accelerated through 1944; production of the Panther tank thus coincided with this period of increased manufacturing efficiency. At the beginning of the war, German armored fighting vehicle manufacturers had employed labor-intensive and costly manufacturing methods unsuitable for the needs of mass production; even with streamlined production methods, Germany never approached the efficiency of Allied manufacturing during World War II.[17]
Design characteristics
The Panther had a five-man crew
The weight of the production model was increased to 45 metric tons from the original plans for a 35 ton tank. Hitler had personally reviewed the final designs and insisted on an increase in the thickness of the frontal armor - the front glacis plate was increased from 60 mm (2.4 in) to 80 mm (3.1 in) and the turret front plate was increased from 80mm to 100 mm (3.9 in).[18]
The Panther was rushed into combat before all of its teething problems had been corrected. Reliability was considerably improved over time, and the Panther did prove to be a very effective fighting vehicle; however, some design flaws, such as its weak final drive units, were never corrected due to various shortages in German war production.
The crew comprised five members: driver, radio operator (who also fired the bow machine gun), gunner, loader, and commander.
Engine
The first 250 Panthers were powered by a Maybach HL 210 P30 engine, V-12 gasoline engine which delivered 650 metric hp at 3,000 rpm and had three simple air filters.[19] Starting in May 1943, the Panthers were built using the 700 PS (690 hp, 515 kW)/3000 rpm, 23.1 litre Maybach HL 230 P30 V-12 gasoline engine. To save aluminum, the light alloy block used in the HL 210 was replaced by a cast iron block. Two multistage "cyclone" air filters were used to automate some of the dust removal process.[20][21] In practice, due to the use of low-quality gasoline, the engine power output was reduced. With a capacity of 190 US gallons of fuel, a fully fueled Panther could travel 97–130 km (60–81 mi) on roads and 64–80 km (40–50 mi) cross country.[22]
The HL 230 P30 engine was a very compact design, which kept the space between the cylinder walls to a minimum. The crankshaft was composed of seven discs, each with an outer race of roller bearings, and a crankshaft pin between each disc. To reduce the length of the engine further, by one-half a cylinder diameter, the two banks of 6 cylinders of the V-12 were not offset - the "big ends" of the connecting rods of each cylinder pair in the "V" where they mated with the crankpin were thus at the same spot with respect to the engine block's length rather than offset; this required a "fork and blade" matched pair of conrods for each transversely-oriented pair of cylinders. Usually, "V"-form engines have their transversely-paired cylinders' conrods' "big ends" simply placed side by side on the crankpin, with their transverse pairs of cylinders offset to match. This compact arrangement with the connecting rods was the source of considerable teething problems early on.[23] Blown head gaskets were another problem, which was corrected with improved seals in September 1943. Improved bearings were introduced in November 1943 to replace the faulty ones that had failed frequently. An engine governor was also added in November 1943 that reduced the maximum engine speed to 2500 rpm. An eighth crankshaft bearing was added beginning in January 1944 to help reduce motor failures.[24]
The engine compartment space was designed to be watertight so that the Panther could be submerged and cross waterways. The result was that the engine compartment was poorly ventilated and prone to overheating. The fuel connectors in the early models were non-insulated, leading to leakage of fuel fumes into the engine compartment. This led to many engine fires in the early Panthers. Additional ventilation was added to draw off these gasses, which mitigated but did not completely solve the problem of engine fires.[25] Other measures taken to reduce this problem included improving the coolant circulation inside the motor and adding a reinforced membrane spring to the fuel pump.[26] The Panther had a solid firewall separating the engine compartment and the fighting compartment to keep engine fires from spreading.
The engine became more reliable over time. A French assessment of their stock of captured Normandy Panther A's in 1947 concluded that the engine had an average life of 1,000 km (620 mi) and maximum life of 1,500 km (930 mi).[27]
Suspension
Interleaved wheels on a Panther
The suspension consisted of front drive sprockets, rear idlers and eight double-interleaved rubber-rimmed steel road wheels on each side — in the so-called Schachtellaufwerk design, very similar to the Tiger I's own road wheel arrangement, pioneered for large-scale production German full-track AFVs in 1942 — suspended on a dual torsion bar suspension. The dual torsion bar system, designed by Professor Ernst Lehr, allowed for a wide travel stroke and rapid oscillations with high reliability, thus allowing for relatively high speed travel by this heavy tank over undulating terrain. However, the extra space required for the bars running across the length of the bottom of the hull, below the turret basket, increased the overall height of the tank and also prevented any chance for a provision for an escape hatch in the hull bottom. When damaged by mines, the torsion bars often required a welding torch for removal.[28]
The Panther's suspension was complicated to manufacture and the Schachtellaufwerk interleaved road wheel system made replacing inner road wheels time consuming (though it could operate with multiple missing or broken wheels). The interleaved wheels also had a tendency to become clogged with mud, rocks and ice, and could freeze solid overnight in the harsh winter weather, that followed the autumn rasputitsa mud season of the Eastern Front. Shell damage could also cause the road wheels to jam together and become extremely difficult to separate.[29] Interleaved wheels had long been standard on all German half-tracks. The extra wheels did provide better flotation and stability, and also provided more armor protection for the thin hull sides than smaller wheels or non-interleaved wheel systems, but the complexity meant that no other country ever adopted this design for their tanks.[30] In September 1944, and again in March/April 1945, M.A.N. built a limited number of Panther tanks with overlapping, non-interleaved steel-rimmed roadwheels originally designed for the Tiger II and late series Tiger I tanks. Steel-rimmed roadwheels were introduced from chassis number 121052 due to raw material constraints.[31]
From November 1944 through February 1945, a conversion process began to use sleeve bearings in the Panther tank, as there was a shortage of ball bearings. The sleeve bearings were primarily used in the running gear; plans were also made to convert the transmission to sleeve bearings, but were not carried out as production of Panther tanks came to an end.[32]
Steering and transmission
Repair of the transmission of a Panther
Steering was accomplished through a seven-speed AK 7-200 synchromesh gearbox, designed by Zahnradfabrik Friedrichshafen (ZF), and a MAN single radius steering system, operated by steering levers. Each gear had a fixed radius of turning, ranging from five meters for 1st gear up to 80 meters for 7th gear. The driver was expected to judge the sharpness of a turn ahead of time and shift into the appropriate gear to turn the tank. The driver could also engage the brakes on one side to force a sharper turn.[33] This manual steering was a much simplified design, compared to the more sophisticated dual-radius hydraulically controlled steering system of the Tiger tanks.
The AK 7-200 transmission was also capable of pivot turns, but this method of turning could accelerate failures of the final drive.[34]
Throughout its career, the weakest parts were its final drive units. The problems were from a combination of factors. The original MAN proposal had called for the Panther to have an epicyclic gearing (planetary) system in the final drive, similar to that used in the Tiger I.[35] However, Germany at the time suffered from a shortage of gear-cutting machine tools and, unlike the Tiger tanks, the Panther was intended to be produced in large numbers. To achieve the goal of higher production rates, numerous simplifications were made to the design and its manufacture. This process was aggressively pushed forward, sometimes against the wishes of designers and army officers, by the Chief Director of Armament and War Production, Karl-Otto Saur (who worked under, and later succeeded, Reichminister Speer). Consequently, the final drive was changed to a double spur system.[36] Although much simpler to produce, the double spur gears had inherently higher internal impact and stress loads, making them prone to failure under the high torque requirements of the heavy Panther tank. Furthermore, high quality steel intended for double spur system was not available for mass production, and was replaced by 37MnSi5 tempered steel, which was unsuitable for high-stress gear.[37] In contrast, both the Tiger II[38] and the US M4 Sherman tank had double helical (herringbone gears) in their final drives,[39] a system that reduced internal stress loads and was less complex than planetary geartrains.
Compounding these problems was the fact that the final drive's housing and gear mountings were too weak because of the type of steel used and/or the tight space allotted for the final drive. The final gear mountings deformed easily under the high torque and stress loads, pushing the gears out of alignment and resulting in failure.[40] Due to the weakness of the final drives their average fatigue life was only 150 km. In Normandy, about half of the abandoned Panthers were found by the French to have broken final drives.[27] The final gear housing was eventually replaced with stronger one, while the final gear problem was never solved.[41]
Plans were made to replace the final drive, either with a version of the original epicyclic gears planned by MAN, or with the final drive of the Tiger II. These plans were intertwined with the planning for the Panther II, which never came to fruition because the Panzer Commission deemed that a temporary drop in production of the Panther due to a merger of Tiger II and Panther II would be unacceptable. It was estimated that building the epicyclic gear final drive would have required 2.2 times more machining work than double spur gears, and this would have affected manufacturing output.[42]
Most of the shortcomings were considered acceptable once design flaws were rectified.[43] Due to the mechanical unreliability of the final gear, the Panther had to be driven with care, a characteristic shared with the Tiger tanks as well as Jagdtigers. Long road marches would result in a significant number of losses due to breakdowns, and so the German Army had to ship the tanks by rail as close to the battlefield as possible.[44]
Armor
Initial production Panthers had a face-hardened glacis plate (the main front hull armor piece), but as armor-piercing capped rounds became the standard in all armies (thus defeating the benefits of face-hardening, which caused uncapped rounds to shatter), this requirement was deleted on 30 March 1943. By August 1943, Panthers were being built only with a homogeneous steel glacis plate.[45] The front hull had 80 mm of armor angled at 55 degrees from the vertical, welded but also interlocked for strength. The combination of well-sloped and thick armor meant that few Allied or Soviet weapons could penetrate this part of the tank.[46]
The armor for the side hull and superstructure (the side sponsons) was much thinner (40–50 mm). The thinner side armor was necessary to keep the overall weight within reasonable bounds, but it made the Panther vulnerable to attacks from the side by most Allied and Soviet tank and anti-tank guns. German tactical doctrine for the use of the Panther thus emphasized the importance of flank protection.[47] Five millimeter thick skirt armor, known as Schürzen, intended to provide protection for the lower side hull from Soviet anti-tank rifle fire was fitted on the hull side. Zimmerit coating against magnetic mines started to be applied at the factory on late Ausf D models beginning in September 1943;[48] an order for field units to apply Zimmerit to older versions of the Panther was issued in November 1943.[49] In September 1944, orders to stop all application of Zimmerit were issued, based on false rumors that hits on the Zimmerit had caused vehicle fires.[50]
Panther with track segments hung on the turret sides to augment the armour
Panther crews were aware of the weak side armor and made unauthorized augmentations by hanging track links or spare roadwheels onto the turret and/or the hull sides.[51] The rear hull top armor was only 16 mm thick, and had two radiator fans and four air intake louvres over the engine compartment that were vulnerable to strafing by aircraft.[52]
As the war progressed, Germany was forced to reduce or no longer use certain critical alloy materials in the production of armor plate, such as nickel, tungsten, molybdenum, and manganese; this resulted in lower impact resistance levels compared to earlier armor.[53] Manganese from mines in the Ukraine became unavailable when the German Army lost control of this territory in February 1944. Allied bombers struck the Knabe mine in Norway and stopped a key source of molybdenum; other supplies from Finland and Japan were also cut off. The loss of molybdenum, and its replacement with other substitutes to maintain hardness, as well as a general loss of quality control resulted in an increased brittleness in German armor plate, which developed a tendency to fracture when struck with a shell. Testing by U.S. Army officers in August 1944 in Isigny, France showed catastrophic cracking of the armor plate on two out of three Panthers examined.[54][55]
Armament
Main armament: 7.5 cm KwK 42 (L/70)
The main gun was a 7.5 cm Rheinmetall-Borsig KwK 42 (L/70) with semi-automatic shell ejection and a supply of 79 rounds (82 on Ausf. G). The main gun used three different types of ammunition: APCBC-HE (Pzgr. 39/42), HE (Sprgr. 42) and APCR (Pzgr. 40/42), the last of which was usually in short supply. While it was of only average caliber for its time, the Panther's gun was one of the most powerful tank guns of World War II, due to the large propellant charge and the long barrel, which gave it a very high muzzle velocity and excellent armor-piercing qualities. The flat trajectory also made hitting targets much easier, since accuracy was less sensitive to range. The high velocity increased the chance of hitting a moving target. The Panther's 75 mm gun had more penetrating power than the main gun of the Tiger I heavy tank, the 8.8 cm KwK 36 L/56,[56] although the larger 88 mm projectile might inflict more damage if it did penetrate.[57]
The tank typically had two MG 34 machine guns of a specific version designed for use in armored combat vehicles featuring an armored barrel sleeve. An MG 34 machine gun was located co-axially with the main gun on the gun mantlet; an identical MG 34 was located on the glacis plate and fired by the radio operator. Initial Ausf. D and early Ausf. A models used a "letterbox" flap enclosing its underlying thin, vertical arrowslit-like aperture, through which the machine gun was fired.[58] In later Ausf A and all Ausf G models (starting in late November-early December 1943), a ball mount in the glacis plate with a K.Z.F.2 machine gun sight was installed for the hull machine gun.[59]
Turret
Panther with flattened lower 'chin' mantlet
The front of the turret was a curved 100 mm thick cast armor mantlet. Its transverse-cylindrical shape meant that it was more likely to deflect shells, but the lower section created a shot trap. If a non-penetrating hit bounced downwards off its lower section, it could penetrate the thin forward hull roof armor, and plunge down into the front hull compartment.[60] Penetrations of this nature could have catastrophic results, since the compartment housed the driver and radio operator sitting along both sides of the massive gearbox and steering unit. Even worse, four magazines containing main gun ammunition were located between the driver/radio operator seats and the turret, directly underneath the gun mantlet when the turret was facing forward.[61]
From September 1944, a slightly redesigned mantlet with a flattened and much thicker lower "chin" design started to be fitted to Panther Ausf G models, the chin being intended to prevent such deflections. Conversion to the "chin" design was gradual, and Panthers continued to be produced to the end of the war with the rounded gun mantlet.[62]
In most cases the Panther's gun mantlet could not be penetrated by the M4s 75 mm gun, the T-34s 76.2 mm gun, or the T-34-85s 85 mm gun. But it could be penetrated by well-aimed shots at 100 m by the 76mm M1A1 gun used on certain models of the M4, at 500 m by the Soviet A-19 122 mm gun on the IS-2 and at 2,300 m (2,500 yd) by the British Ordnance QF 17 pounder using APDS ammunition. The side turret armor of 45 mm (1.8 in) was vulnerable to penetration at long range by almost all Allied tank guns, including the M4's 75 mm gun which could penetrate it at 1,500 m (0.93 mi).[46] These were the main reasons for continued work on a redesigned Panther turret, the Schmalturm.
The Ausf A model introduced a new cast armor commander's cupola, replacing the more difficult to manufacture forged cupola. It featured a steel hoop to which a third MG 34 or either the coaxial or the bow machine gun could be mounted for use in the anti-aircraft role, though it was rare for this to be used in actual combat situations.[63]
The first Panthers (Ausf D) had a hydraulic motor that could traverse the turret at a maximum rate of one complete revolution in one minute, independent of engine speed. This slow speed was improved in the Ausf A model with a hydraulic traverse that varied with engine speed; one full turn taking 46 seconds at an engine speed of 1,000 rpm but only 15 seconds if the engine was running at 3,000 rpm.[64] This arrangement was a slight weakness, as traversing the Panther's turret rapidly onto a target required close coordination between the gunner and driver, who had to run the engine to maximum speed. By comparison, the turret of the M4 Sherman turret traversed at up to 360 degrees in 15 seconds and was independent of engine speed, which gave it an advantage over the Panther in close-quarters combat.[65] As usual for tanks of the period, a hand traverse wheel was provided for the Panther gunner to make fine adjustment of his aim.[64]
Ammunition storage
Ammunition storage for the main gun was a weak point. All the ammunition for the main armament was stored in the hull, with a significant amount stored in the sponsons. In the Ausf D and A models, 18 rounds were stored next to the turret on each side, for a total of 36 rounds. In the Ausf G, which had deeper sponsons, 24 rounds were stored on each side of the turret, for a total of 48 rounds. In all models, four rounds were also stored in the left sponson between the driver and the turret. An additional 36 rounds were stored inside the hull of the Ausf D and A models - 27 in the forward hull compartment directly underneath the mantlet. In the Ausf G, the hull ammunition storage was reduced to 27 rounds total, with 18 rounds in the forward hull compartment. For all models, three rounds were kept under the turntable of the turret.[66] The thin side armor could be penetrated at combat ranges by many Allied tank guns, and this meant that the Panther was vulnerable to catastrophic ammunition fires ("brewing up") if hit from the sides.[67]
The loader was stationed in the right side of the turret. With the turret facing forward, he had access only to the right sponson and hull ammunition,[68] and so these served as the main ready-ammunition bins.
Combat use
Panthers were supplied to form Panzer Abteilung 51 (Tank Battalion 51) on 9 January, and then Pz.Abt. 52 on 6 February 1943.[69]
The first production Panther tanks were plagued with mechanical problems. The engine was dangerously prone to overheating and suffered from connecting rod or bearing failures. Gasoline leaks from the fuel pump or carburetor, as well as motor oil leaks from gaskets easily produced fires in the engine compartment; several were destroyed in such fires. Transmission and final drive breakdowns were the most common and difficult to repair. A large list of other problems were detected in these early Panthers, and so from April through May 1943 all Panthers were shipped to Falkensee and Nuernburg for a major rebuilding program. This did not correct all of the problems, so a second program was started at Grafenwoehr and Erlangen in June 1943.
Eastern Front
Panther tanks of the Großdeutschland Division advance in the area of Iaşi, Romania in 1944.
The Panther tank was seen as a necessary component of the upcoming Operation Zitadelle, and the attack was delayed several times because of their mechanical problems, with the eventual start date of the battle only six days after the last Panthers had been delivered to the front. This resulted in major problems in Panther units during the Battle of Kursk, as tactical training at the unit level, coordination by radio, and driver training were all seriously deficient.[70]
It was not until 23-29 June 1943 that a total of 200 rebuilt Panthers were finally issued to Panther Regiment von Lauchert, of the XLVIII Panzer Corps (4 Panzer Army). Two were immediately lost due to motor fires upon disembarking from the trains.[70] By 5 July, when the Battle of Kursk started, there were only 184 operational Panthers. Within two days, this had dropped to 40.[70] On 17 July 1943 after Hitler had ordered a stop to the German offensive, Gen. Heinz Guderian sent in the following preliminary assessment of the Panthers:
Due to enemy action and mechanical breakdowns, the combat strength sank rapidly during the first few days. By the evening of 10 July there were only 10 operational Panthers in the front line. 25 Panthers had been lost as total writeoffs (23 were hit and burnt and two had caught fire during the approach march). 100 Panthers were in need of repair (56 were damaged by hits and mines and 44 by mechanical breakdown). 60 percent of the mechanical breakdowns could be easily repaired. Approximately 40 Panthers had already been repaired and were on the way to the front. About 25 still had not been recovered by the repair service ... On the evening of 11 July, 38 Panthers were operational, 31 were total write-offs and 131 were in need of repair. A slow increase in the combat strength is observable. The large number of losses by hits (81 Panthers up to 10 July) attests to the heavy fighting.[70]
During Zitadelle the Panthers claimed 267 destroyed tanks.[71]
A later report on 20 July 1943 showed 41 Panthers as operational, 85 as repairable, 16 severely damaged and needing repair in Germany, 56 burnt out (due to enemy action), and two that had been destroyed by motor fires.[72]
However, before the Germans ended their offensive at Kursk, the Soviets began their counteroffensive, and succeeded in pushing the Germans back into a steady retreat. Thus, a report on 11 August 1943 showed that the numbers of total write-offs in Panthers swelled to 156, with only 9 operational. The German Army was forced into a fighting retreat and increasingly lost Panthers in combat as well as from abandoning and destroying damaged vehicles.[72]
The Panther demonstrated its capacity to destroy any Soviet AFV from long distance during the Battle of Kursk, and had a very high overall kill ratio.[73] However, it comprised less than seven percent of the estimated 2,400–2,700 total AFVs deployed by the Germans in this battle,[74] and its effectiveness was limited by its mechanical problems and the in-depth layered defense system of the Soviets at Kursk. Its greatest historical role in the battle may have been a highly negative one—its contribution to the decisions to delay the original start of Operation Zitadelle for a total of two months, time which the Soviets used to build up an enormous concentration of minefields, anti-tank guns, trenches and artillery defenses.[75]
Panther with infantry support, in combat, 1944
After the losses of the Battle of Kursk, the German Army went into a permanent state of retreat against the Red Army. The numbers of Panthers were slowly re-built on the Eastern Front, and the operational percentage increased as its reliability was improved. In March 1944, Guderian reported: "Almost all the bugs have been worked out," although many units continued to report significant mechanical problems, especially with the final drive.[76] The greatly outnumbered Panthers came to be used as mobile reserves to fight off major attacks.[77]
The highest total number of operational Panthers on the Eastern Front was achieved in September 1944, when some 522 were listed as operational out of a total of 728. Throughout the rest of the war, Germany continued to keep the great majority of Panther forces on the Eastern Front, where the situation progressively worsened for the Germans. The last recorded status, on 15 March 1945, listed 740 on the Eastern Front with 361 operational.[78] By this time the Red Army had entered East Prussia and was advancing through Poland.
In August 1944, Panthers were deployed in Warsaw during the uprising as mobile artillery and troop support. At least two of them were captured in the early days of the conflict and used in actions against Germans, including the liberation of Gęsiówka concentration camp on 5 August, when the soldiers of "Wacek" platoon used the captured Panther (named "Magda") to destroy the bunkers and watchtowers of the camp. Most of the Germans in the camp were killed; the insurgents had lost two people and liberated almost 350 people. After several days they were immobilized due to the lack of fuel and batteries and were set ablaze to prevent them from being re-captured by the German forces.[79]
Western Front - France
At the time of the invasion of Normandy, there were initially only two Panther-equipped Panzer regiments in the Western Front, with a total of 156 Panthers between them. From June through August 1944, an additional seven Panther regiments were sent into France, reaching a maximum strength of 432 in a status report dated 30 July 1944.[80]
The majority of German panzer forces in Normandy – six and a half divisions, were drawn into the fighting around the town of Caen. Here, they checked the Anglo-Canadian forces of the 21st Army Group. The numerous battles to secure the town became collectively known as the Battle of Caen. While there were sectors of heavy bocage around Caen, there were also many open fields which allowed the Panther to engage the attacking enemy armor at long range. Conversely, by the time of the Normandy Campaign, British Divisional Anti-tank Regiments were well equipped with the excellent 17 pounder gun (the 17pdr also replaced the US gun on some M10 Tank Destroyers in British service), making it equally as perilous for Panthers to attack across these same fields. The British had begun converting regular M4 Shermans to carry the 17 pounder gun (nicknamed Firefly) prior to the D-day landings, and while limited numbers meant that during Normandy not more than one Sherman in four were of the Firefly variant, the lethality of its gun against German armor made them priority targets for German gunners.
US forces in the meantime, facing one and a half German panzer divisions, mainly the Panzer Lehr Division, struggled in the heavy, low-lying bocage terrain west of Caen. Against the M4 Shermans of the Allied tank forces during this time, the Panther tank proved to be most effective when fighting in open country and shooting at long range—its combination of superior armor and firepower allowed it to engage at distances from which the Shermans could not respond.[81] However, the Panther struggled in the bocage country of Normandy, and was vulnerable to side and close-in attacks in the built-up areas of cities and small towns.[82] The commander of the Panzer Lehr Division, Gen. Fritz Bayerlein, reported on the difficulties experienced by the Panther tank in the fighting in Normandy:
While the PzKpfw IV could still be used to advantage, the PzKpfw V [Panther] proved ill adapted to the terrain. The Sherman because of its maneuverability and height was good ... [the Panther was] poorly suited for hedgerow terrain because of its width. Long gun barrel and width of tank reduce maneuverability in village and forest fighting. It is very front-heavy and therefore quickly wears out the front final drives, made of low-grade steel. High silhouette. Very sensitive power-train requiring well-trained drivers. Weak side armor; tank top vulnerable to fighter-bombers. Fuel lines of porous material that allow gasoline fumes to escape into the tank interior causing a grave fire hazard. Absence of vision slits makes defense against close attack impossible.[82]
Through September and October, a series of new Panzerbrigades equipped with Panther tanks were sent into France to try to stop the Allied advance with counterattacks.[83] This culminated in the Battle of Arracourt (18-29September 1944), in which the mostly Panther-equipped German forces suffered heavy losses fighting against the 4th Armored Division of Patton's 3rd Army, which were still primarily equipped with 75 mm M4 Sherman tanks and yet came away from the battle with only a few losses. The Panther units were newly formed, poorly trained, and tactically disorganized; most units ended up stumbling into ambush situations against seasoned U.S. tank crews.[84]
Western Front - Ardennes Offensive
Burnt out Panther Ausf.G at the Battle of the Bulge, penetrated in the sponson.
A status report on 15 December 1944 listed an all-time high of 471 Panthers assigned to the Western Front, with 336 operational (71 percent). This was one day before the start of the Battle of the Bulge; 400 of the tanks assigned to the Western Front were in units sent into the offensive.[85]
The Panther once again demonstrated its prowess in open country, where it could shoot its victims at long range with near-impunity, and its vulnerability in the close-in fighting of the small towns of the Ardennes, where they suffered heavy losses.[86] A status report on January 15, 1945 showed only 97 operational Panthers left in the units involved in the operation, out of 282 still in their possession. Total write-offs were listed as 198.[87]
Panther disguised as an M10 Tank Destroyer
The Operation Greif commando mission included five Panthers assigned to Panzerbrigade 150, disguised to look like M10 Tank Destroyers by welding on additional plates, applying US-style camouflage paint and markings.[85] This was carried out as part of a larger operation that involved soldiers disguised as Americans and other activities. The disguised Panthers were detected and destroyed.
In February 1945, eight Panzer divisions with a total of 271 Panthers were transferred from the West to the Eastern Front. Only five Panther battalions remained in the west.[88]
One of the top German Panther commanders was SS-Oberscharführer Ernst Barkmann of the 2nd SS-Panzer Regiment "Das Reich". By the end of the war, he had some 80 tank kills claimed.[89]
Fortification
Pantherturm fortification in Italy, mid 1944.
From 1943, Panther turrets were mounted in fixed fortifications; some were normal production models, but most were made specifically for the task, with additional roof armor to withstand artillery. Two types of turret emplacements were used; (Pantherturm III - Betonsockel — concrete base) and (Pantherturm I - Stahluntersatz — steel sub-base). They housed ammunition storage and fighting compartment along with crew quarters. A total of 182 of these were installed in the fortifications of the Atlantic Wall and West Wall, 48 in the Gothic Line and Hitler Line, 36 on the Eastern Front, and two for training and experimentation, for a total of 268 installations by March 1945. They proved to be costly to attack, and difficult to destroy.[90]
Battalion organization
From September 1943, one Panzer battalion with 96 Panthers comprised the Panzer regiment of a Panzer-Division 43.[91]
Panzerbefehlswagen Panther Ausf. A (Sd.Kfz. 267) of the Panzergrenadier-Division Großdeutschland photographed in southern Ukraine in 1944.
Battalion Command (composed of Communication and Reconnaissance platoons)
Communication Platoon - 3 × Befehlswagen Panther SdKfz.267/268
Reconnaissance Platoon - 5 × Panther
1st Company - 22 × Panther
Company Command - 2 × Panther
1st Platoon - 5 × Panther
2nd Platoon - 5 × Panther
3rd Platoon - 5 × Panther
4th Platoon - 5 × Panther
2nd Company - 22 × Panther (composed as 1st Company)
3rd Company - 22 × Panther (composed as 1st Company)
4th Company - 22 × Panther (composed as 1st Company)
Service Platoon - 2 × Bergepanther SdKfz.179
From 3 August 1944, the new Panzer-Division 44 organisation called for a Panzer division to consist of one Panzer regiment with two Panzer battalions – one of 96 Panzer IVs and one of 96 Panthers. Actual strengths tended to differ, and became far lower after losses.[92]
The Allied response
Soviet
The appearance of the Panther on the Eastern Front led to another step in the ongoing arms race between the Germans and Soviets to produce AFVs with ever greater armor and firepower. The Tiger I and Panther tanks were German responses to encountering the T-34 in 1941. Soviet firing tests against a captured Tiger in April 1943 showed that the T-34's 76 mm gun could not penetrate the front of the Tiger I at all, and the side only at very close range. An existing Soviet 85 mm antiaircraft gun, the 52-K, was found to be very effective against the frontal armor of the Tiger I, and so a derivative of the 52-K 85 mm gun was developed for the T-34. The Soviets thus had already embarked on the 85 mm gun upgrade path before encountering the Panther tank at the Battle of Kursk.[93][94]
After much development work, the first T-34-85 tanks entered combat in March 1944. The production version of the T-34's new 85 mm gun proved to be ineffective against the Panther's frontal armor, meaning the Soviet tank had to flank the Panther to destroy it, while the Panther's main gun could penetrate the T-34 at long range from any angle.[95] Although the T-34-85 tank was not quite the equal of the Panther, it was much better than the 76.2 mm-armed versions and made up for its quality shortcomings by being produced in greater quantities than the Panther. New self-propelled anti-tank vehicles based on the T-34 hull, such as the SU-85 and SU-100, were also developed. A German Army study dated 5 October 1944 showed that the Panther could easily penetrate the turret of the T-34-85 from the front at ranges up to 2000 m, and the frontal hull armor at 3000 m, whereas from the front, the T-34-85 could only penetrate the non-mantlet part of the Panther turret at 500 m. From the side, the two were nearly equivalent as both tanks could penetrate the other from long range.[96]
The Battle of Kursk convinced the Soviets of the need for even greater firepower. A Soviet analysis of the battle in August 1943 showed that a Corps artillery piece, the A-19 122 mm gun, had done well against the German AFVs in that battle, and so development work on the 122 mm equipped IS-2 began in late 1943. First encounters with hostile enemy tanks revealed that the 122 mm BR-471 armor piercing shell could only punch through the Panther's frontal armor at a range of 600–700 meters. The early results of the IS-2's combat employment which were confirmed by firing tests in Kurbinka 1944 compelled the designers to seek innovate solutions.[97] German testing at Kummersdorf showed that the 122 mm gun could not penetrate the glacis plate of the Panther at all at 30 degrees, could penetrate the nose at 100 m and the turret mantlet of the Panther at ranges up to 600 m.[98] The Panther's 75 mm gun could penetrate the front of the IS-2's turret at over 1000 m, the drivers front plate at 1000 m and the hull nose at 1000 m. From the side, the Panther was more vulnerable than the IS-2.[96] Thus the two tanks, while nearly identical in weight, had quite different combat strengths and weaknesses. The Panther carried much more ammunition and had a faster firing cycle than the IS-2, which was a lower and more compact design; the IS-2's D25T 122 mm gun used a two piece ammunition which slowed its firing cycle to 1.5-2 rounds per minute on average.[99][100]
American and British
Panther tank with brush camouflage in Northern France, 1944
The response of the Western Allies to the Panther was confused. The Western Allies were aware of the Panther and had access to technical details through the Soviets, but there was a difference in the American and British camps as to the significance of the tank. After taking two years to catch up with German tank design in Africa, the British were wary of falling behind yet again. They had developed the excellent 17-pounder anti-tank gun, but had no vehicle that could fit this large gun into its turret. For its part, the U.S. Army did not believe the Panther would be a significant problem, and did not foresee their armored forces having to fight pitched engagements against the Panther. The Panther was not seen in combat by the Western Allies until early 1944 at Anzio in Italy, where Panthers were employed in small numbers. Until just before D-Day (June 1944), the Panther was thought to be another heavy tank that would not be built in large numbers.
Shortly before D-Day, Allied intelligence reported that large numbers of Panthers were being used in the panzer divisions, and an attempt was made to investigate Panther production. Using a statistical analysis of the road wheels on two captured tanks, U.S. intelligence estimated Panther production for February 1944 to be 270 units, much greater than what had been anticipated.[101] This indicated the Panther would be encountered in much larger numbers than had previously been thought.[102] In the planning for the Battle of Normandy, the U.S. Army expected to face a handful of German heavy tanks alongside large numbers of Panzer IVs. At this point it was too late to prepare to face the Panther. As it turned out, 38% of the German tanks in Normandy were Panthers, whose frontal armor could not be penetrated by the 75 mm guns of the US M4 Sherman.
The British were more astute in their recognition of the danger posed by the increasing armour strength of German tanks. They discovered that by rotating the 17-pounder anti-tank gun and slightly modifying the turret of the Sherman, the two could be combined. They began converting their Shermans into this version, which they called the Sherman Firefly. By the time of the Normandy invasion some 300 of these Sherman Fireflies were available to the Commonwealth armoured divisions. The British lobbied for American production lines to be modified to produce Fireflies, just as they had been modified to manufacture the American P-51 fighter with the British Merlin engine, but these suggestions were ignored by the U.S. Army, in part due to the poor performance of British tank designs in North Africa.[103] There were also 200 interim Challenger tanks with the 17-pounder and other improved tank designs under development. British and Commonwealth tank units in Normandy were initially equipped at the rate of one Firefly in a troop with three Shermans or Cromwells. This ratio increased until, by the end of the war, half of the British Shermans were Fireflies. The Comet with a gun similar to the 17-pounder had also replaced the 75 mm gun Sherman in some British units. The 17-pounder with APCBC shot was more or less equivalent in performance to the Panther's 75 mm gun, but superior with APDS shot.[104]
At the time, U.S. armor doctrine was dominated by the head of Army Ground Forces, Gen. Lesley McNair, an artilleryman by trade, who believed that tanks should concentrate on infantry support and exploitation roles, and avoid enemy tanks, leaving them to be dealt with by the tank destroyer force, which were a mix of towed anti-tank guns and lightly armored armored fighting vehicles with open top turrets with 3-inch (M10 tank destroyer), 76 mm (M18 Hellcat) or later, 90 mm (M36 tank destroyer) guns. This doctrine led to a lack of urgency in the U.S. Army to upgrade the armor and firepower of the M4 Sherman tank, which had previously done well against the most common German tanks - Panzer IIIs and Panzer IVs - in Africa and Italy. As with the Soviets, the German adoption of thicker armor and the 7.5 cm KwK 40 in their standard armored armored fighting vehicles prompted the U.S. Army to develop the more powerful 76 mm version of the M4 Sherman tank in April 1944. Development of a heavier tank, the M26 Pershing, was delayed mainly by McNair's insistence on "battle need" and emphasis on producing only reliable, well-tested weapons, a reflection of America's 3,000 mile supply line to Europe.[105]
An AGF (Armored Ground Forces) policy statement of November 1943 concluded the following:
The recommendation of a limited proportion of tanks carrying a 90mm gun is not concurred in for the following reasons: The M4 tank has been hailed widely as the best tank of the battlefield today....There appears to be no fear on the part of our forces of the German Mark VI (Tiger) tank. There can be no basis for the T26 tank other than the conception of a tank-vs.-tank duel-which is believed to be unsound and unnecessary. Both British and American battle experience has demonstrated that the antitank gun in suitable numbers is the master of the tank....There has been no indication that the 76mm antitank gun is inadequate against German Mark VI tank.[106]
U.S. awareness of the inadequacies of their tanks grew only slowly. All U.S. M4 Shermans that landed in Normandy in June 1944 had the 75 mm gun. The 75 mm M4 gun could not penetrate the Panther from the front at all, although it could penetrate various parts of the Panther from the side at ranges from 400 to 2,600 m (440 to 2,840 yd). The 76 mm gun could also not penetrate the front hull armor of the Panther, but could penetrate the Panther turret mantlet at very close range.[107] In August 1944, the HVAP (high velocity armor-piercing) 76 mm round was introduced to improve the performance of the 76 mm M4 Shermans. With a tungsten core, this round could still not penetrate the Panther glacis plate, but could punch through the Panther mantlet at 800 to 1,000 yd (730 to 910 m), instead of the usual 100 yards for the normal 76 mm round. However, tungsten production shortages meant that this round was always in short supply, with only a few rounds available per tank, and some M4 Sherman units never received any.[108]
Whereas Sherman tanks used a high flash powder, making it easier for German tankers to spot them, German tanks used a low flash powder, making it harder for Allied crews to spot them.[103] Shermans, even though they were around 15 tons lighter than Panthers, had worse cross country mobility due to their narrower tracks. Brig. Gen. J.H. Collier noted:
"I saw where some MkV tanks crossed a muddy field without sinking the tracks over five inches, where we in the M4 started across the same field the same day and bogged down." [109]
The 90 mm M36 tank destroyer was introduced in September 1944; the 90 mm round also proved to have difficulty penetrating the Panther's glacis plate, and it was not until an HVAP version of the round was developed that it could effectively penetrate it from combat range. It was very effective against the Panther's front turret and from the side, however.[110]
The high U.S. tank losses in the Battle of the Bulge against a force largely of Panther tanks brought about a clamor for better armor and firepower. At General Eisenhower's request, only 76 mm gun-armed M4 Shermans were shipped to Europe for the remainder of the war. Small numbers of the M26 Pershing were also rushed into combat in late February 1945.[111] A dramatic newsreel film was recorded by a U.S. Signal Corps cameraman of an M26 stalking and then blowing up a Panther in the city of Cologne, after the Panther had knocked out two M4 Shermans.[112]
Production of Panther tanks and other German tanks dropped off sharply after January 1945, and eight of the Panther regiments still on the Western Front were transferred to the Eastern Front in February 1945. The result was that for the rest of the war during 1945, the greatest threats to the tanks of the Western Allies were no longer German tanks, but infantry anti-tank weapons such as the Panzerschreck and Panzerfaust, and infantry anti-tank guns such as the ubiquitous 7.5 cm Pak 40, and self-propelled anti-tank guns such as the Marder, StuG III, StuG IV, and Jagdpanzer. A German Army status report dated 15 March 1945 showed 117 Panthers left in the entire Western Front, of which only 49 were operational.[113]
Re: Coen's Nachtjagd panther
Further development
Panther II
Panther II on display at Patton Cavalry and Armor Museum, Fort Knox, KY. The turret on display was not originally fitted to this hull and was installed later.
The early impetus for upgrading the Panther came from the concern of Hitler and others that it lacked sufficient armor. Hitler had already insisted on an increase in its armor once, early in its design process in 1942. Discussions involving Hitler in January 1943 called further increased armor; initially referred to as Panther 2 (it became the Panther II after April 1943). This upgrade increased the glacis plate to 100 mm (3.9 in), the side armor to 60 mm (2.4 in), and the top armor to 30 mm (1.2 in). Production of the Panther 2 was slated to begin in September 1943.
In a meeting on 10 February 1943, further design changes were proposed - including changes to the steering gears and final drives. Another meeting on 17 February 1943 focused on sharing and standardizing parts between the Tiger II tank and the Panther 2, such as the transmission, all-steel roadwheels, and running gear. Additional meetings in February began to outline the various components, including use of the 88 mm L/71 KwK 43 gun. In March 1943, MAN indicated that the first prototype would be completed by August 1943. A number of engines were under consideration, among them the new Maybach HL 234 fuel-injected engine (900 hp operated by an 8-speed hydraulic transmission) and the GT 101 gas turbine.
Thus, plans to replace the original Panther design with the Panther II were already underway before the first Panther had even seen combat. But from May to June 1943, work on the Panther II ceased as the focus was shifted to expanding production of the original Panther tank. It is not clear if there was ever an official cancellation - this may have been because the Panther II upgrade pathway was originally started at Hitler's insistence. The direction that the design was headed would not have been consistent with Germany's need for a mass-produced tank, which was the goal of the Reich Ministry of Armament and War Production.
One Panther II chassis was completed and eventually captured by the U.S.; it is now on display at the Patton Museum in Fort Knox. An Ausf G turret is mounted on this chassis.[114][115]
Panther Ausf. F
After the Panther II project died, a more limited upgrade of the Panther was planned, centered around a re-designed turret. The Ausf F variant was slated for production in April 1945, but the war ended these plans.
The earliest known redesign of the turret was dated 7 November 1943 and featured a narrow gun mantlet behind a 120 mm (4.7 in) thick turret front plate. Another design drawing by Rheinmetall dated 1 March 1944 reduced the width of the turret front even further; this was the Turm-Panther (Schmale Blende) (Panther with narrow gun mantlet).[116]
Several experimental Schmaltürme (literally: "narrow turrets") were built in 1944 with modified versions of the 75 mm KwK 42 L/70, which were given the designation of KwK 44/1. A few were captured and shipped back to the U.S. and Britain. One badly damaged vehicle is on display at the Bovington Tank Museum. It had been used as a post-war range target until its historical significance was recognised.
Model of Panther Ausf. F with proposed Schmalturm
The Schmalturm had a much narrower front face of 120 mm (4.7 in) armor sloped at 20 degrees; side turret armor was increased to 60 mm (2.4 in) from 45 mm (1.8 in); roof turret armor increased to 40 mm (1.6 in) from 16 mm (0.63 in); and a bell shaped gun mantlet similar to that of the Tiger II was used. This increased armor protection also had a slight weight saving due to the overall smaller size of the turret.[117]
The Panther Ausf F would have had the Schmalturm, with its better ballistic protection, and an extended front hull roof which was slightly thicker. The Ausf F's Schmalturm was to have a built-in stereoscopic rangefinder and lower weight than the original turrets. A number of Ausf F hulls were built at Daimler-Benz and Ruhrstahl-Hattingen steelworks; however there is no evidence that any completed Ausf F saw service before the end of the war.
Proposals to equip the Schmalturm with the 88mm KwK 43 L/71 were made from January through March 1945. These would have likely equipped future German tanks but none were built, as the war ended.[118]
E-50
The E series of tanks — E-25, E-50, E-75, E-100 (the numbers designated their weight class) - was proposed to further streamline production with an even greater sharing of common parts and simplification of design. In this scheme, the Panther tank would have evolved into the E-50. A conical spring system was proposed to replace the complex and costly dual torsion bar system. The Schmalturm would have been used, likely with a variant of the 88 mm L/71 gun.[119]
Derived vehicles
Bergepanther on display at Saumur armor museum
Jagdpanther - heavy tank destroyer with the 88 mm L/71
Befehlspanzer Panther - command tank with additional radio equipment
Beobachtungspanzer Panther - observation tank for artillery spotters; dummy gun; armed with only two MG 34
Bergepanther - armored recovery vehicle
Flakpanzer Coelian - anti-aircraft tank project, planned to be armed with twin Flak 43 37 mm AA guns in an armored turret [120]
Postwar and foreign use
Although a technologically sophisticated vehicle for its time, the Panther's design had a very limited influence on postwar tank development. The French postwar AMX 50 tank prototype was directly and significantly influenced by it, but never entered series production. The French did produce a modified version of the Panther's 75 mm KwK 42 L/70 gun, as the 75 mm DEFA and CN75-50 gun. This equipped the first iteration of the AMX 13 light tank as well as the Panhard EBR armored car, and was also used by the Israeli M50 Super Sherman. In his comparison of the Panther with the Soviet T-34-76, military historian Steve Zaloga argued that it could be regarded as an early precursor to the modern main battle tank; a class of tanks that did not appear until some twenty years after the war.
The Panther itself also saw some limited use outside the German military, both before and after 1945.
British officers ride on a captured Panther tank in Italy June 1944, with early "letterbox" hull gun aperture
During the war, the Red Army employed a number of captured Panthers. These were repainted with prominent Soviet emblems and tactical markings to avoid friendly fire incidents. The Red Army still used a few Panthers as late as spring 1945. Unlike captured Panzer IVs and Stugs the Soviets generally only used Panthers and Tigers that had been captured intact and used them until they broke down, as they were too complex and difficult to transport for repair. Panzer IVs and Stugs, on the other hand, were so numerous in terms of spare parts and easy to repair that they could be used over a much longer period in combat conditions.
During March–April 1945 Bulgaria received 15 Panthers of various makes (D, A and G's) from captured and overhauled Soviet stocks; they only saw limited (training) service use. They were dug down, with automotive components removed, as pillboxes along the Bulgarian-Turkish border as early as the late 1940s. The final fate of these pillbox Panthers is unknown, but sources indicate that they were replaced and scrapped in the 1950s.
In May 1946, Romania received 13 Panther tanks from the USSR. They were initially used by the 1st Armored Brigade, but in 1947 the equipment was ceded to the Soviet-organized "Tudor Vladimirescu Division" which was transformed from a volunteer infantry division into an armored one. The Panther tank was officially known as T-5 in the army inventory. These tanks were in poor shape and remained in service until about 1950, by which time the Romanian Army had received T34-85 tanks. All of the tanks were scrapped by 1954. The tanks were different models: Ausf A, Ausf D and Ausf G.[121] They were shown to the public in 1948, during the 1st of May parade in Bucharest, painted with Romanian markings. Until 1950, the T-5 was the heaviest tank available to the Romanian Army.
One captured vehicle (named "Cuckoo") also saw service with the British Coldstream Guards for some time.[122]
Japan reportedly bought a single Panther Ausf. D for reverse engineering purposes in 1943. However the tank apparently never made it to Japan. The Panther's sloped armor and turret design nevertheless influenced the design of Japan's last wartime tank prototypes; the medium Type 4 Chi-To and heavy Type 5 Chi-Ri.[123]
After the war, France was able to recover enough operable vehicles and components to equip the French Army's 503e Régiment de Chars de Combat with a force of fifty Panthers. These remained in service until about 1950, by which time they had all been replaced by French-built ARL 44 heavy tanks.
In 1946, Sweden sent a delegation to France to examine surviving specimens of German military vehicles. During their visit, the delegates found a few surviving Panthers and had one shipped to Sweden for further testing and evaluation. Testing continued until 1961. The tank is currently on display in the Deutsches Panzermuseum in Munster.[124]
The last 'production' Panthers were produced at the factory by German staff just after the end of World War II under the supervision of REME (Royal Electrical and Mechanical Engineers) using available components. A complete Panther and a complete Jagdpanther produced this way were shipped back to Britain for post-war trials. Both vehicles are now at the Bovington Tank Museum, Dorset, with brass plates on them, explaining their history.
Surviving vehicles
In working order.[125]
Military Vehicle Technology Foundation, USA. Ausf. A
Musée des Blindés, France. Ausf. A
Deutsches Panzermuseum, Munster, Germany. Ausf. A Command Tank
Wehrtechnische Studiensammlung, Koblenz, Germany. Ausf. G. Completed after the war in the Panther factory under supervision by UK REME engineers, used for tests
Friedrich Christian Flick Private Collection, Germany. Ausf. G. Completed after the war in the Panther factory under supervision by UK REME engineers, used for tests
Kubinka Tank Museum, Russia. Ausf.G
Not running, more or less complete.[125]
Wilhelmina park, Breda, The Netherlands. The only known complete surviving Ausf. D. This tank was donated by the Polish 1st Armored Division after liberating Breda. It was restored in 2004–2005 for static display by Kevin Wheatcroft in exchange for automotive components.
Panzermuseum Thun, Thun, Switzerland. Advertised as an Ausf. D/G hybrid, with a D hull and G turret. There are many questions surrounding this vehicle. The turret has a replacement sheet metal mantlet, vaguely resembling a late Ausf. G mantlet, with no ports for gunners sight or coaxial MG. The pistol port on the turret rear indicates an Ausf. An or early Ausf G. The hull with the "letterbox" MG slot indicates an Ausf. D or early Ausf. A. The turret and hull numbers could help identify the correct model designation for the hybrid but neither of the numbers have been made public.
The Wheatcroft Collection, private collector, UK. The collection has three Panthers, one being restored. Early Ausf. A (DEMAG production). Two more to follow, one Ausf. A and one Ausf. A converted to a D.
The restored Panther Ausf A on display at the Canadian War Museum in Ottawa.
Canadian War Museum. In January 2008 a partially restored Panther Ausf. A was put on display. It had been donated to the museum from CFB Borden, which acquired it following V-E celebrations in May 1945. It had spent two years in restoration prior to being put on public display.[124]
Rex & Rod Cadman Collection, UK. Ausf. A
Sinsheim Auto & Technik Museum, Sinsheim, Germany. Ausf. A
Musée des Blindés, Saumur, France. Ausf. A
Mourmelon-le-Grand, France. Ausf. A
Musée des Blindés, Saumur, France. Ausf. G
Bovington Tank Museum, UK. Ausf. G. Completed after the war in the Panther factory under supervision by UK REME engineers, used for tests.[126]
Panther in the river at Houffalize, 1945
Houffalize in the Ardennes region of Belgium. A Panther Ausf. G can be found in the village. It fell into the river during the Battle of the Bulge and was later retrieved as a memorial.
The National War and Resistance Museum, Overloon, in the Netherlands, has an Ausf. G that was knocked out by a PIAT projectile during the battle of Overloon.
U.S. Army's National Armor & Cavalry Museum, Fort Benning, GA, USA, collection consists of the following 4 Panthers:
Pz V Ausf. A; Pz V Ausf. G; Pz V Ausf. G with chin; & Panther II. Several of these were part of the Ordnance collection that was at Aberdeen, MD
Wrecks.[125]
Overlord Museum, Colleville-sur-Mer (ex-Falaise August 1944 museum), France. Ausf. A. Will be cosmetically restored and displayed in the new museum in a diorama representing a field repair unit of the Wehrmacht, along with a Strabo Fries gantry.[127]
Kevin Wheatcroft, private collector, UK. Ausf. A. Will be restored. All components needed are already sourced or remanufactured.
Kevin Wheatcroft, private collector, UK. Ausf. A. Will be restored to an Ausf. D. All components needed are already sourced or remanufactured.
Grandmenil, Belgium. Ausf. G
Celles, Houyet, Belgium. Ausf. G
Detailed specifications
Crew: 5
Dimensions
Length
including gun: 8.66 m
hull only: 6.87 m
Width:
hull: 3.27 m,
with skirt plates: 3.42 m
Height: 2.99 m
Combat weight:
Ausf. D 43.0 t
Ausf. A 45.5 tonnes
Ausf. G 44.8 t (46.58 t with steel road wheels)
Performance
Road speed: 55 km/h at 3,000 rpm (46 km/h at 2,500 rpm)
Road range: 200 km
Obstacle crossing
Vertical obstacle: 0.9 m
Trench crossing : 1.9 m
Fording: 1.7 m
Suspension and tracks
type: dual torsion-bar
Shock absorbers: on 2nd and 7th swing arms on either side
Track type: Kgs 64/660/150 dual center guide
Track width: 660 mm
Ground contact length: 3.92 m
Track links: 86
Ground pressure: 0.88 kg/cm²
Engine and transmission
Maybach HL 230 P30 V-12, four-stroke internal combustion
Displacement: 23.095 litres
Compression ratio: 6.8:1
Fuel: gasoline, 74 octane
Power: 700 PS at 3,000 rpm, 600 PS at 2,500 rpm
Fuel consumption (road): 3.5 l/km
Fuel capacity: 720 litres
Transmission: ZF AK 7-200 synchromesh manual
Gears: 7 forward, 1 reverse
Steering: MAN single-radius clutch-brake
Main clutch: Fichtel & Sachs LAG 3/70H
Steering ratio: 1:1.5
Armament
Main gun: 7.5 cm Kwk 42 L/70
Breech: semiautomatic
Traverse: 360°, 24°/second
Elevation: +18°/-8°
Rounds carried: 79; Ausf. G: 82
Primary gun sight: Leitz TZF 12; Ausf. A and G: TZF 12a
Magnification: 2.5×/5×
Field of view: 28°/14°
Radio equipment
Fu 5 transmitter/receiver
Fu 2 receiver
Armor
Armor layout
All angles from horizontal.
Hull front, lower: 60 mm at 35°; upper: 80 mm at 35°
Hull side, lower: 40 mm at 90°; upper: 40 mm at 50°; Ausf. G: 50 mm at 60°
Hull rear: 40 mm at 60°
Turret front: 80 mm at 78°; Ausf. A: 110 mm at 78°; Ausf. G: 100 mm at 80°
Turret side: 45 mm at 65°
Turret rear: 45 mm at 65°
Turret, top: 16 mm at 5°; Ausf. G: 30 mm at 5°
Gun mantlet: 100 mm rounded
Here is a blurb on the Infrarot-Scheinwerfer from Acthung Panzer
German Infrared Night-Vision Devices – Infrarot-Scheinwerfer
Panther Ausf G with FG 1250
Panzerkampfwagen V Panther Ausf G with Sperber/FG 1250.
In 1936, AEG was ordered to start the development of infrared night-vision devices and in 1939, first successful prototype unit for use with 37mm Pak 35/36 L/45 anti-tank gun was constructed. In autumn of 1942, unit for use (infrared headlamp with viewer ZG 1221) with 75mm PaK 40 L/46 anti-tank gun was constucted and was also mounted on Marder II (Sd.Kfz.131).
In mid 1943, first tests with infrared night-vision (Nacht Jager) devices and telescopic rangefinders mounted on Panther started. Two different arrangements / solutions were created and used on Panther tanks.
Solution A – Sperber (Sparrow Hawk) was made up of one 30cm infrared searchlight (with range of 600m) and image converter operated by the commander – FG 1250.From late 1944 to March of 1945, some Panzerkampfwagen V Panther Ausf G (and other variants) mounted with FG 1250, were succesfully tested. From March to April of 1945, approximately 50 Panthers Ausf G (and other variants) mounted with FG 1250, saw combat service on the Eastern Front and Western Front. Panthers with IR operated with SdKfz.251/20 Uhu (Owl) half-track with 60cm infra-red searchlight and Sd.Kfz.251/21 Falke (Falcon). This solution could be easily mounted on any type of armored fighting vehicle.
Sd.Kfz.251/20
Sd.Kfz.251/20
SdKfz.251/20 Uhu (Owl).
Solution B – Second more complicated arrangement / solution was "Biwa" (Bildwandler), which provided driver (installed on the front hull), gunner (installed on the mantlet in front of the gun sight) and commander (as in Solution A) each with one 30cm infrared searchlight (with range of 600m) and image converter. Various variants of Panthers were converted and mounted with "Biwa". It was reported that tests were successful, but there is very few combat reports from the Eastern or Western Front. Due to the lack of evidence,existence of Solution B is still questionable and even considered a hoax.
Various units received IR Panthers including 116th Panzer Division (3rd company of 24th Panzer Regiment, Western Front, Summer of 1944), Sixth SS Panzer Army (Hungary, early 1945), Panzer Division Muncheberg and Clausewitz.One combat report is by a veteran of 1st SS Panzer Regiment of 1st SS Panzer Division "LSSAH", who states that few Panthers equipped with infrared night-vision devices possibly from 116th Panzer Division were used in 1944/45 during the Ardennes Offensive.In April of 1945, Panthers equipped with IR equipment (solution B) joined Panzer Division Clausewitz and in mid April near Uelzen destroyed entire platoon of British Comet cruiser tanks. Also on April 21st of 1945, same Panthers overran an American anti-tank position on the Weser-Elbe Canal.Most of those reports can’t be confirmed and are questionable.
In addition, it is reported but not supported that single unit equipped with Jagdpanthers also received and used infrared night-vision devices.
Now the Really important stuff.... the bits and pieces.
Here is the Kit Review
[youtube]4_c9yVjsBeo[/youtube]
And here is the launch video
[youtube]vrSsgP6dtcI[/youtube]
The real thing :)
Joker56
Malaysia
Post by Joker56 »
Thank you for a very informative history on the wee beastie , I look forward to seeing more
Peter
Peter
PaulAyrey
Post by PaulAyrey »
An excellent thread!
Look forward to your build (I want one)! Loads do good add on's too!
ForbesHutton
Post by ForbesHutton »
alextheblue
Post by alextheblue »
That's a great subject Mike - looking forward to this one :th: :pop:
www.alextheblue.com
:cry: i thought i was the only one with this idea :cry:
But i won't be doing all that interior work that's for sure
And i have a different kit for it altough a dragon aswell
Good luck with you build
i don't know about you but i found very few photo's of the real ir panthers but it makes room for some artistic licence
are you planning any specific vehicle?
Cheers Mark
Thanks dudes.
I really hope that you fellas didn't feel that you had to read all of that stuff.
I put that there mostly for me to use while I work. It's just easier to look for it in one place instead of 5.
MarkVerploeg wrote::cry: i thought i was the only one with this idea :cry:
Cheers Mark
Unfortunately there aren't many photos of the vehicles. The ones that I've posted above are all that I have so far.
There are a lot of rumors, myths, fables, etc about the night hunting panthers but very little solid paper on them.
I'll be trying to build this vehicle.
This is a training vehicle from what I've learned but I'll be building it as one that was put into service near the end of days of the Reich.
I had considered building it as one of the rumoured Ardennes Offensive (Battle of the Bulge) Night Hunting Panthers... I still may do that.
I'll settle more on that when I get further into the build though. It also depends on what you decide to build. I don't want to step on your toes and build exactly the same thing.
I've excluded myself from the prizes so you don't have to worry about the winning thing. :) :th:
It's all so fascinating Mark... how could there only be one of us building one of the Night Hunters? haha
I don't worry about winning mate
I wanted to be the rebel or the outcast :lol:
And build something most don't know about or didn't plan on building
I did find a little bit of info on the unit and 2 of the panthers that where night fighters
But i will post that when i start building
I do have one drawing of the vehicle in color it is from the ak color guide
And it seems that these vehicles where painted in late war colors and not the common tri tonenal scheme in terms of the paintcolors
But i have my sights aimed at one vehicle really
It was present in Berlin but no longer in the night fighting role altough the ir stuff was still on there
But i will reveal my evil (whuahahaha) plan soon
First a other build needs some attention
Cheers Mark
EasyEight96
Malaysia
Post by EasyEight96 »
Nice entry Coen :th: say that figures looks familiar :think:
In -progress
Too many on the bench!!!
Matchbox Kits lover....
EasyEight96 wrote:Nice entry Coen :th: say that figures looks familiar :think:
Hehe.... they should buddy... they traveled all the way from Malaysia to be in my vignette ;)
Thanks for that bud. I knew that I'd find a use for these fellas. I've used this set before on a King Tiger that I've built and I loved them.
MarkVerploeg wrote:I don't worry about winning mate
Cheers Mark
I really can't wait to see what you chose Mark.. I know that it will be a really exciting piece. Yours always are. :D :th: :th:
EasyEight96
Malaysia
:jd: :jd: glad to see it in good hands
In -progress
warpedcrisis
Post by warpedcrisis »
looking nice and looking forward to watching this build up
and thanks for all the info
This going to be interesting. Looking forward to it mate.
mick
Post by mick »
:pop: :pop: :pop: :pop: :pop: :pop: :pop: :pop: :pop: :pop: this is like heaven
NAMBiohazard
Post by NAMBiohazard »
Mike, you chose a rare and interesting version to build....
And with your skills this build its gonna be beyond expectations :th:
Good luck
Keep the glue on the Sprue
Bjorn
Cheers Mark
Thanks it will be a dragon kit but not the same as yours
But the panthers that dragon made the last few years are very good even without upgrades
But by the time you see this it should be posted
cheers Mark
JohnP
Post by JohnP »
SO MANY LONG POSTS
generalgrog
Post by generalgrog »
Interesting stuff there. Amazing that they were able to use IR in 1939.
GG
Fascinating actually. That war drove forward so many modern ideas. Most have no idea what it's roots were.
Some don't want to know.
How is the build going ?
Should take forever with the interior
Oh and about my choise
I found a short bit of info in a book about the battle of Berlin
It was confirmed that Panther 121 was there but they mentioned that Panther 100 wich was the platoons command vehicle had a few days of action before it was knocked out
So i will go for the command vehicle as i have the antenna set from aber and more then enough spare antenna mounts
The only thing that needs scratch building is the armored mount for the star antenna but that is easy with some styrene tube , a saw and a sanding stick
So i guess i will have a dio going
Now it is time to show your evil plan Darth Coen
Cheers Mark
Haha! Mark... I'm not your father.... (Insert scary breathing)
:eeek:
I haven't even started mine yet actually. I've been wanting to for days, but I want to get these three DAK vehicles up to weathering before I start.
I'm nearly there now.
Possibly tomorrow.
I plan a full photo and video build of it, so it will take some time.
As for evil plan.... I'd tell ya but I'd have to kill ya. :pistols:
Aaannnnnnd... We're off!!!!!! :thumb2:
I can't stand it any more. After looking at some of the builds going on I had to start working on this thing.
To many hoopy froods doing hoopy things!!!
I started by doing away with the instructions for the most part and replaced the barrel and the breech assembly that came with the kit with the Lion Roar barrel..... which is GORGEOUS!!!!! and the slavaged parts from a previous panther build.
It took a lot of doing but headway was made.
I can't to a complete interior as I don't have enough usable parts that survived the salvage operation, I do have enough for a "Through the Hatch" view.
Before I install them I'll have to prime and repaint them.
Here's where I started out...
All the assorted bits for this session
This is the turret basket that I'll be using to complete the through the hatch effect... it's a bit more than I need, but I don't want to waste it.
This is the cupola interior piece that I'll be using to do the upgrade.
The breech upgraded and replaced
I've done a video that I'm editing now as well. I'll post that later today.
Nice Mike, thats gonna look awesome with the interior :cheers2:
PaulAyrey
Post by PaulAyrey »
Looks like a great start, love the full interior. Can't wait to see how it turns out.
mick
Post by mick »
great work :pop: :pop: :pop: :thumb2:
Thanks... Here's the video of the work if anybody is interested.
:th: :D
[youtube]W6uTpjX-reI[/youtube]
PaulAyrey
Post by PaulAyrey »
Great video! Excellent progress too.
AchtungPanzer
Post by AchtungPanzer »
:crazy: . Thanx for sharing. Well done Michael :)
Muzrik
Post by Muzrik »
:jd: Absolutely amazing the level of detail it's :crazy: Awesome just Awesome!
Cheers Steve
On The Bench:
Academy 1/72 Tempest Mk V
JohnP
Post by JohnP »
Awesome progress, Mike.
I have yet to start on my panther :crazy: :crazy:
felisbarcinonensis
Post by felisbarcinonensis »
That cat is gonna look really dangerous :o
Mind the goat though :eeek:
Last edited by felisbarcinonensis on Tue Jun 17, 2014 2:43 pm, edited 1 time in total.
Tonnes of work done on her now... Tonnes of screw ups and things I had to fix too.
That's what happens when you film, hangout, and talk with friends while trying to build haha.
I started with installing all of the resin interior bits and pieces that I had left over. Not all of them fit and I still need to adjust the turret ring as it's too big for the opening on the lower hull.
This resin set was made for a Tamiya kit and I installed it (badly) in a dragon kit years ago. It was my first attempt at such a thing.
The kit is long ago tossed away and the parts recycled, but the resin was too valuable to toss (at least I thought so at the time... it's so badly built that I should have tossed it. Ah well, good enough for "through the hatch")
I build up the cuplola with the intention of adding the resin interior but there wasn't a chance in hell that it would fit. So I used the kit parts. They turned out to be just fine. Once the IR gear is on and the crew figure is in you won't see it anyway.
The resin breach assembly is very badly beaten up. It's better than the kit part though and good enough for what will be seen of it.
The rear hatch installed and interior painted
The Lion Road/Great Wall IR gear built and installed. Small and very fiddly, but the parts reflect the actual device very well.
If you're wondering what the sanding and filling is on the turret top, I realised that this panther shouldn't have the chemical agent detection plate and the IR hub armoured mount in front of the turret. So I had to remove both.... that was a RIGHT PITA!!!!
It's in the video that I'll add later.
I'll be adding the reflective blue film to the outside of one piece of the lens, and I'll add it to the inside of the other. Then mask it all off with Maskol.
I also started the construction of the lower hull and the interior bits. They all need to be primed and painted. These aren't the final colours. I put most of the interior gear where it's supposed to go, then I added a lot of filler to dress it up a bit. I'll probably add a wiring harness for the radio and the gages before I paint. It depands on how much I can see through the hatches when it's closed up.
Here's the other Panther G that I have, it's essentially the same kit. A few changes during the build but for the most part the kits are the same.
I'm in the process of editing a video with some silly bits about some members of the community and a build of everything above.
It's long so it will be a while yet.
EasyEight96
Malaysia
Wow the interior is stunning Coen can't wait to watch your video
In -progress
Here's the vid... The silly bit, waffle and shout outs are at the beginning. The build is at the end.
[youtube]QWeyCS9dteI[/youtube]
HotziSlayer
Post by HotziSlayer »
i really like your panther, the interior is awesome.
mick
Post by mick »
great work ,glad there's a video as well :pop: :pop: :pop: :pop: :bow::
JayCub
Post by JayCub »
Absolutely awesome Mike, i haven't built a panther as of yet and it will be my next purchase, fingers crossed, and i really like the extras you have on this one.
Tom
PaulAyrey
Post by PaulAyrey »
This is coming along really nicely, very much enjoying it.
Here kitty kitty kitty!!!
:pistols:
So... anyway... I've been pretty busy with this monster lately.
I've got the interior primed, hull exterior detailed a bit, wheels sanded and dry fitted, tracks assembled.
Next I have to paint the interior of the lower hull so that I can button her up then finish the build.
Then on to paint.
Turret primed...
Interior primed...
Various hull top assembies completed...
The Rear Plate completed except for the glass in the convoy light.
Dry fitting the main assembly and the wheels installed for track construction...
I was originally going to us Fruil tracks but I only had enough to do one side from my spares box. Looks like I'll need to order more if I build another panther.
there's even a video... :eeek:
Muhahaha!
[youtube]R54iXrIWA1g[/youtube]
PaulAyrey
Post by PaulAyrey »
Superb, coming along nicely
wolfpack2000
Post by wolfpack2000 »
You are incredibly talented! I love the WWII cats as well. I wish I had found this site sooner. I would love to try my hand at joining. keep the updates coming!
:bow::
Looking great buddy, coming along nicely :thumb2:
AchtungPanzer
:th: :th: :th: Really nice model Michael - awesome work. Which is your Panther ?:) I want one in 1:72 !!!!!. :thumb2:
