Tamiya 1/35 Panther Ausf A.
T3hGuppy
Post by T3hGuppy »
So here is my entry.
This is an old kit but I am planning on brining it up to date with some detail parts.
My entry video of the kit.
[youtube]JmKPDYThIEo[/youtube]
Pictures of the sprues
The extras I am adding.
Bronco workable tracks.
Eduard zimmerit set
This has some great detail.
Also will be adding Eduard PE upgrade set.
And a metal barrel. Not sure of the manufacturer but the finish is really nice.
The decals also have some Eduard German number masks this means I can do any vehicle number.
I will cover what I am planning for this one in the next update.
Too much to list. !!
Re: Tamiya 1/35 Panther Ausf A.
Nice gups :banana:
Schoof
Post by Schoof »
Looks like your lower hull isn't too happy :nena:
NAMBiohazard
Post by NAMBiohazard »
lol Schoof
Guppy..... talk about a facelift
this build is gonna be interesting
Keep the glue on the Sprue
Bjorn
Well that is a pile of pe there
Is the eduard zimmerit any good ?
I ordered a set but i never used it
Good luck with the facelift of this kit
And tell the hull a joke maybe it will smile :tongue:
PaulAyrey
Post by PaulAyrey »
Wow, some really nice stuff there, can't wait to see it progress!
mick
Post by mick »
:pop: :pop: :pop: :pop: , will be watching your build,best of luck with the bronco tracks ,in the end the ones i build had to be all stuck together ,the pins were very weak to make them moveable
Post by Rob »
Nice! You've set yourself a challenge though! The bottom of the hull looks like a gloomy Cyberman! :th:
trekfanj
Post by trekfanj »
No-one likes a frowny face! :(
I actually have this kit, too, but I've read that there aren't enough road wheels on either side...Armor Research Co. makes a set of white metal roadwheels to add the extra layer, enabling AM track sets to be used.
Hope that didn't make me sound like a rivet counter; just trying to help. :th:
Looking forward to the finished build. :cheers2:
Jarod
-Ralph Waldo Emerson
martin57
Post by martin57 »
nice looking kit , good luck with it :thumb1:
T3hGuppy
Post by T3hGuppy »
Update number one.
Started with the upper hull.
Lots of bits to add. Also made a mistake an misread the intructions for the vision slots the PE parts fit inside.
I will need to replace these with some plasticard.
Also made a start on the rear plate.
Cleaned up on set of tracks these clip together and are workable. Four attachment points on each! (the pins to clip them together are a little fragile so care is needed when construction them)
trekfanj wrote:No-one likes a frowny face! :(
Cheers dude will look into that.
mannloon
Post by mannloon »
Amazing how different that kit looks even just with the PE zim. As I've said that was my first armor kit.
As to the wheels, it is true that kit has simplified wheels with a very thin single wheel where it should be double.
I bought some of those Bronco tracks for my Jagdpanther so I can't wait to see how they look on the tank. Any info on the barrel construction or further info on the track assembly would be very useful.
Upper hull looks great so far.
Cyber-Hobby Tiger I Kursk
Rye Field Tiger I w/ Interior
T3hGuppy
Post by T3hGuppy »
Ill make sure to do some detailed pics for you. :th:
I gotta say Ben, you're a brave man trying to build those tracks. I tried twice and tossed both sets in the bin. I nearly went batty with the clean up and dealing with those pins.
AchtungPanzer
Post by AchtungPanzer »
:crazy: Amazing and great set . :clap: Good work & well done buddy . :cheers2:
martin57
Post by martin57 »
great start , i have a pile of single tracks to put together myself , :scratch::
PaulAyrey
Post by PaulAyrey »
Great start, should be fantastic!
mick
Post by mick »
good progress
T3hGuppy
Post by T3hGuppy »
Update time.
Progressing on this slowly but surely.
been doing a small amount at a time the PE really is alot of work so little and often for me.
Drilled out the exhausts to add some more detail.
Still so much PE left :(
More to come
Great progress dude
Did you use burnishing fluid on the pe?
As it looks kind of black
Cheers Mark
T3hGuppy
Post by T3hGuppy »
MarkVerploeg wrote:Great progress dude
Cheers Mark
No just the lighting I think. Also a fair bit of superglue residue on the parts.
Russ72
Post by Russ72 »
Looking real good Gup.
PaulAyrey
Post by PaulAyrey »
That is looking good, excellent stuff so far!
Post by Rob »
Nice work Ben, l feel your PE pain! Looking pretty smart though :th:
That's a brutal load of work Ben!!!
It looks excellent. All that hard work is really going to pay off.
The zimmerit PE on the glacis plate MG must have been a complete paint to do.
I think that I would have just looked at that and wimped out, then did it by hand.
You're a brave dude. :)
You'res and Marks will be the heavy weights of this SIG I think. Haha.
It would be cool to see a weigh off at the end. ;)
Looks sweet Ben. The zim really adds to the model. I tend to find that with PE on armour I don't use all of it. Some times I just cut my loses and keep a kit part in order to keep my sanity! Or because I can't make the PE bit so I would rather have a straight kit part than a bent and glue marked PE bit.
T3hGuppy
Post by T3hGuppy »
Yeah Im trying to use as much as I can as good practice as still only used small amounts of PE in the past.
martin57
Post by martin57 »
:thumb1: thats a lot of work , but it looks fantastic
felisbarcinonensis
Post by felisbarcinonensis »
Wow! That's quite a challenge! Looking great! :o :shock:
