Filter technique in Painting
rodrant
Post by rodrant »
Sorry about bringing this topic to here , do not know if it is the right place in the forum , but I heard a lot about using 'filters' in painting , as example , after using some dark color we aplly a filter using the same color but more diluted or mixed with a lighter one ... when we use this technique the color should be diluted or mixed with some weathering product/lighter color ?
Does anybody know this technique that can give me some tips ? :scratch::
thank you
Cheers ,
António
a lot of stuff right now :-)
galileo1
Re: Filter technique in Painting
Post by galileo1 »
In progress:
  • N/A
rodrant
Post by rodrant »
Thank you for the tips , think it is understood and more or ess ( actually less ... ;-) ) the idea that I had on what was this , I will try to practice some in my SiG Nightfighter build , let's see if it works ok as the plane is an all black and I will do some post shading using a very light gray and then apply a filter using the dark color but very diluted ...
I apreciate your help and tips very much ! :th:
Cheers ,
António
