Revell 1:48 Bell UH-1 "Huey Hog"
gaz45
Post by gaz45 »
This is my entry for this GB
Forever associated with its ubiquitous role in the Vietnam conflict in the 1960's, the Bell UH-1 Iroquois or Huey as it became universally known is one of the most widely used and famous helicopters of all time.
The Korean war of the early 1950's saw the military helicopter come of age in the artillery spotting, light transport and casualty evacuation roles, in 1956, experiences in Korea led the U.S. Army to conduct trials of armed helicopters, which laid the foundations for future developments in this role.
By this time, Bell aircraft was developing a new turbine powered utility helicopter, the model 204 with the military designation XH-40 the first of these flying on 22 October 1956; two more XH-40s were followed by six YH-40 and six initial production HU-1s by 1959, when a production order was placed for 173 HU-1As followed by the improved HU-1B which first flew in 1960.
Many A models were used for training but in 1962 the first HU-1As were deployed to South Vietnam in the air ambulance and utility roles; that year, in common with a general redesignation of US Army types, the Huey became the UH-1. In September 1962 the first armed UH-1As were deployed to South Vietnam with the UTTHC (Utility Tactical Transport Helicopter Company) to test these under operational conditions: they were typically armed with two Browning M-2.3 (7.62mm) belt fed machine guns and 80mm rocket tubes, all attached to the skid supports.
They provided protective fire support for other unarmed helicopters and the ground forces, forming an integral component of each tactical unit. With the arrival of the UH-1B and C models, the weaponry became more potant and typical was a hydraulically powered M-6 quad mount for four 7.62mm M-60 machine guns with heavier rocket armaments such as the M-200A-1 pods. Other options included machine gun armament for the rear cabin and a nose mounted ball turret with a machine gun or a M-5 40mm grenade launcher; the latter item giving rise to the nicknames "Thumper" and "Huey Hog".
The interim UH-1C model was the main armed version for the army pending the arrival of it's successor the Bell AH-1 Hueycobra which was a dedicated gunship. The US Marine corps and the Navy also operated large numbers of Huey's in the Vietnam theatre, and all three services operated them in many other theatres; the Marines UH-1E was basically a B model with a largely aluminium structure and other upgrades.
The Royal Australian Air Force also used Huey's in Vietnam; development of more advanced versions was rapid and from the mid 1960s militay and civilian versions were being sold worldwide.
Power plant: one 1,100shp Lycoming T5311 turboshaft giving a maximum speed of 193km/h (120mph) at sea level.
gaz45
Re: Revell 1:48 Bell UH-1 "Huey Hog"
Post by gaz45 »
Opening of the box
1 bag of sprues
Main body there is a lot of nice detail and also some flash
The clear parts are very clear with no distortion
The decals look good and sharp
The instructions with paint callouts for revell
Thank you for taking a look I hope to get started on this very soon.
Willem
Post by Willem »
Nice choice Gaz. Good luck with your build buddy.
Will
Edward R Murrow
5Craven
Post by 5Craven »
Good luck with your build. I know from experience you will need it. :crazy:
Joker56
Malaysia
Post by Joker56 »
Gaz mine went straight into the bin of despair, didn't even make shelf of doom, be very careful pull both halves of fuselage together as fit is crap , mine broke just behind the cabin area, also not flash more like trash
Good luck matey you're gonna need it
Peter
robertw
Post by robertw »
Good luck, I've heard less than positive things about this kit.
Is it just me or is the Huey a bit neglected in the modelling world? Nobody seems to make a good kit in 1/48. Shame really.
Well if it isn't working out, you could do a crash scene or battle damage
Just have plan B ready, it will work out
gaz45
Post by gaz45 »
Thanks guys i'll keep that in mind
gaz45
Post by gaz45 »
1st update the begining
I've got all the parts cleaned up for the cockpit
then assembled
engine parts cleaned up and assembled
next up cleaned the pilot and copilot along with the fuselage
hopefully ill get these primed tonight
MikeyKb
Post by MikeyKb »
What a Piece of *$%# kit. I wish you the best of luck, and may the force be with you. :bash: :wall:
Here's a link to my attempted build thread... http://www.intscalemodeller.com/viewtop ... =37&t=2817
Just like everyone else, mine is currently sitting in my box of doom... that's where models go after the shelf of doom... headed to the garbage. I'm keeping it around though, who knows when I might want a little dose of extreme frustration.
It would feel great to conquer this kit though.
I'll definitely be watching this!
:thumb2:
Mikey
gaz45
Post by gaz45 »
thanks for the heads up mikey mate i'll take a look at your thread for ideas i wont give in i just hope i can finish this within the time
Omi
Post by Omi »
Good luck with this, this is the only kit I've thrown away over the last 7 years, the fit of the roof part and general fit of the glass is shocking, but you might be able to beat it in to submission, good luck.
gaz45
Post by gaz45 »
So a small update i got the above parts primed using for the first time Ammo primer and my new airbrush ( neo for iwata cn ) really great to use and to clean out and the primer is ace ( thanks paul for suggesting it )
Next update will have some colour on these parts.
gaz45
Post by gaz45 »
next up painting of the cockpit here i used revell 47 mouse grey, revell 09 anthracite, revell 66 olive grey, revell 45 light olive, revell 76 light grey, revell 92 brass metallic and tamiya xf-16 alluminium.
while that dried i painted up the engine and rotor here i used revell 09 anthracite, tamiya xf-16 aluminium, revell 330 firey red and a mix of revell 91 steel metallic and revell 84 leather brown.
once dry i gave it a wash with Ultimate rust
when the cockpit had dried i applied the two instrument decals and gave the floor a wash with Ultimate light dirt
next up were the pilot and co pilot using revell 05 white, revell 09 anthracite, revell 35 flesh, revell 381 brown, revell 45 light olive, revell 371 light grey then a little detail to depict shoulder badges using tamiya xf-3 yellow and finished off with a Ultimate light dirt wash.
these were then fitted in the cockpit along with the engine
now it was time fo fit these to the fuselage this presented a small problem with the co pilots arm so i decided to cut the clear piece in half so his arm was pionting out the window.
the fit of the fuselage was not too bad and required a little filler in places
while the filler dries i put together the two rocket pods with machine guns, the nose section, front cannon, roof section and the two side doors and got these primed up
thats it for now thanks for looking
Coming along nicely, you are flying!!
gaz45
Post by gaz45 »
next up i fitted the engine cover and rear fins
the landing gear together with the rocket/machine gun mounts
next up the roof section and as pointed out to me it was not a good fit so filler was needed
needed to add a little weight to stop it sitting on its tail using blue tac
attached the nose which was not a good fit either so out came the filler again
while the filler was drying i cleaned up the rest of the parts the rotor blades and the tail rotor need filling of the ipm
thanks for looking and for your comments
You are tackling those problem areas nicely
Good to have a heads up like that to know what to expect and be ready to solve it
Great work!
gaz45
Post by gaz45 »
Got the base coat on using revell 46 Nato olive also the outer rotor parts in tamiya XF-16 Aluminium and a coat of revell bronze on the bullet belts
m0gb0y74
Post by m0gb0y74 »
I've got this kit and 'was' looking forward to build it. After reading all the warnings I'll be following your progress closely :-)
m0gb0y74 wrote:I've got this kit and 'was' looking forward to build it. After reading all the warnings I'll be following your progress closely :-)
It is a nice kit for the price
But it still is revell so not the best of kits
Altough with a little bit of work you can make a very nice huey from it
As you can see
Eric
Post by Eric »
Great progress! After being out of the game for so long, I'm learning some good stuff watching your build. Looking forward to the finished product!
On another note (and I don't want to hijack this thread...seriously), I always thought Revell was the clear choice in model-building. It's all I EVER built when I was building. Now, I'm starting to see that occasionally Revell doesn't match up well with the other manufacturers.
gaz45
Post by gaz45 »
Thanks for the comments it was true once but again once you build kits from other manufactuers you get to know that there are more better kits out there
gaz45
Post by gaz45 »
After laying down the base coat there were a few joints that i was not happy with so i used some mr surfacer to sort these out
While this was drying i masked up the main rotor and painted the tips with Tamiya XF-3 flat yellow and a band of white with Tamiya XF-2
There have been a few issues with this kit regarding the fit but i have found working through these make you a better modeller
Thanks for looking comments always welcome
grover
Post by grover »
Yup, looks like you've put in a lot of work Gaz but shes looking a lot better than when she first started going together. :thumb1:
gaz45
Post by gaz45 »
Not too much done touched up the few seams that i filled with mr surfacer. i got the engine vents and a couple of smaller pieces on the roof painted up with revell 09 anthracite and the red light with revell 330 fiery red and got it clear coated ready for the decals
the main rotor blades i used revell 46 nato olive tamiya XF-2 flat white and tamiya XF-3 flat yellow for the tips. The underside was painted in revell 09 anthracite.
the rest of the rotor assembly painted up in tamiya XF-16 flat aluminium. The tail rotor in revell 09 anthracite and the ammunition belts using revell 92 brass metallic and tamiya XF-1 black
The next update i hope to have the decals on and the rotor assembled
thanks for taking a look
That looks fantastic!
You did a wonderful job sealing those joint openings up
Nice work :thumb2:
gaz45
Post by gaz45 »
Right ok only managed to get the decals on this week
gaz45
Post by gaz45 »
Finished up the decals and added the nose cannon along with the remaining windows and attached the rotors.
Also attached the munition belts
appologise for the picture quality hope they get better for the reveal section after some weathering
thanks for looking
gaz45
Post by gaz45 »
So here it is all finished
There were a few fit issues with this which i think i over came one thing i will say about this kit if anyone is going to do this ignore the instructions when placing the figures they show them in the wrong positions thats why i have the co pilot with his arm out of the window which is different to the box art
Thanks for looking and for all your comments
ChubberLang
Post by ChubberLang »
Reall good stuff.
Enjoyed reading through this, top bombing. :dance:
Filmman586
Post by Filmman586 »
Looking good so far!
Lou
My YouTube Channel
gaz45
Post by gaz45 »
cheers guys
Great job Gaz:) :thumb1: :thumb1: :clap:
