Raised rivets
hamish
Raised rivets
Post by hamish »
Hi all, can raised rivets be replaced? Due to sanding I have lost quite a lot of raised rivets and was wondering if they could be replaced.
Gb64c
Re: Raised rivets
Post by Gb64c »
Never have done it, but have seen it done, use Evergreen octagon plastic rods cut to thickness
They make all different dimensions of that stuff
gb64c
Fait Accompli
hamish
Re: Raised rivets
Post by hamish »
Thanks for the reply but these are minute, on 1/72 scale and there are loads. The lost detail is where fuselage halves come together and need sanding to get rid of the join. I would have thought it to have been a common problem.
I have seen a video where Paul shows (didn't actually use it) a tool with a wheel, which can be changed for various scales, to replace rivets, these would therefore be sunken. Surely others must lose raised detail.
JonMW
Re: Raised rivets
Post by JonMW »
Archer has some really nice decals with resin details like welds or rivets. The rivets come in a lot of differrent sizes and with a few different spacings. You just cut them off and apply like normal decals.
http://www.archertransfers.com
NAMBiohazard
Re: Raised rivets
Post by NAMBiohazard »
I just use white glue on a cocktail stick, make little drops where the rivet should be.
I also use this method for making nails on planking
Hope this helps :th:
Keep the glue on the Sprue
Bjorn
Re: Raised rivets
There are peoples that SAND the rivets completely off on 1/72 models .... and go without...
some airplanes have a combo of stand off Rivets and flush rivets.... ?
Good luck !
How old is the kit ?
hamish
Re: Raised rivets
Post by hamish »
Thanks for the replies, I now have a few very useful ideas. Although I would like to retain as much detail as possible I certainly like the idea of removing some surface details. I always thought modelers wanted to keep as much detail as possible.
One kit, an Airfix 1/72 Handley Page Hamden was very bad in regards of flashing and especially the fitting of parts, fuselage halves and wings to fuselage . It is along these joins where there has been the the heaviest loss due to poor fit, I will certainly be removing some detail on this one. I also have on the go three 1/72 Airfix Lancasters. Two Bl/lll, converted to Bll, before the Bll came out, and the other is the recent Bll.
A lot of one of the converted Bl/llll detail has been removed along the fuselage join, I'm not sure yet what I will be doing about this, I have not glued the fuselage halves together on the other Bl/lll conversion. It is the recent Airfix Bll which I want to keep as much detail as possible. As this is a new kit the quality is very good so I expect it to go together much better, we shall see.
Once again thanks to all for your help, any more tips will be greatfully received. :cheers2:
Re: Raised rivets
NAMBiohazard wrote:I just use white glue on a cocktail stick, make little drops where the rivet should be.
Tucking this idea away for future use
Thanks :thumb2:
