Tamiya 1:35 sd kfz 232 8-rad
gustavlekstal
Post by gustavlekstal »
Here is my entry :welcome:
Boxart
Eastern front and balkan
Dak
Early panzercommander and packing the spruces together...
Crisp and clean!!!
Addons. Alpine dak figures, mg34, distance rods
Some photoetch from tamiya. The barrel is to short!!! :scratch:: :bash: Tamiya when you add a barrel get it right!
Gonna give you a introduction of its history and plan of attack for the weathering later on.
Ill hope it will not go completely pete tong and happy modelling :cheers2:
Last edited by gustavlekstal on Fri Oct 24, 2014 12:56 pm, edited 1 time in total.
Regards Gustav
Dragon t-34/85 premium mod 44
viewtopic.php?f=29&t=10747
viewtopic.php?f=29&t=12313
gustavlekstal
Re: Tamiya 1:35 sd kfz 232 8-rad
The chassis were built by Bussing-Nag, Deutsche Werke of Kiel made the assembly of the preseries and series I with Schichau (at Elbing)
German Sd.Kfz 232 (8-Rad)
Type Armored car
Place of origin Nazi Germany
Specifications
Weight 8.3 tons
Length 5.9 m (19 ft 4 in)
Width 2.2 m (7 ft 3 in)
Height 2.9 m (9 ft 6 in)
Crew 4 (commander, gunner, driver, secondary driver)
Armor 8-15 mm (.31-.59 in)
Main
armament
2 cm KwK 30 L/55
Secondary
armament
7.92 mm MG34 MG
Engine 8-cyl petrol
155 hp (115.58 kW)
Suspension 6 or 8 wheels
Operational
range
300 km (186 mi)
Speed 85 km/h
Source: wikipedia
The tactical role of these machines were to provide additional firepower as heavy armored car, a squadron of these beeing attached to each motorized reco unit (Aufklärungs Kompanie) attached to the Panzerdivizionen. Other vehicles of these units included by 1939 Kübelwagens and Schmimmwagens, Zündapp or BMW sidecars, Sd Kfz 141 light armoured cars, and several Schwere Panzerspähwagen.
In each company, there was also a 232 variant equipped with a powerful long range radio apparatus. Later on, it appeard that a more heavier armament was needed inside the reco unit
The 231 and radio-version 232, introduced before the campaign of Poland soldiered well until the end of the war. They were seen on nearly every front, from the Mediterranean to Russia and North Africa and most of Europe. With the DAK (Deutsche Afrika Korps), they proved invaluable and fitted perfectly with Rommel's combined arms tactic and unique vision of desert warfare. The flat ground of the wide desert expenses allowed this armoured car to give its full potential, although it has never been conceived for a hot environment and never properly "tropicalized". The engine, notably, suffered badly under this climate.
Poland
Greece
since the original armour was never intended to sustain more than small arms fire and shrapnells fragments, the platoons tried to evade clashes with other AFVs when possible. However in many cases, these machines were seen providing infantry support and destroying light tanks and enemy armored cars alike. Speed, combined with surprise, could bring very efficient results thanks to the rapid-fire and devastating HE rounds of the 20mm at short range. Their superior agility also helped them to steer backwards and evades quickly a superior force if needed. In other cases, many served as ad hoc police patrol vehicles, dealing with partisans in the Balkans and Russia.
Source: http://www.tanks-encyclopedia.com/ww2/n ... _8-rad.php
Photos: Books
Regards Gustav
That's a nice looking kit with all the extras you have. Will you be putting the vehicle and figures into a diorama setting? :thumb1:
gustavlekstal
UKguyInUSA wrote:That's a nice looking kit with all the extras you have. Will you be putting the vehicle and figures into a diorama setting? :thumb1:
My plans are to do a late dak 8-rad whit this camo. Changing the aerial and bits and bops?
And thinking that this looks like a good dio. Stoney and dusty settings of Tunisia
Regards Gustav
FlyingCoffin
Post by FlyingCoffin »
Looking forward to this one!
Per Ardua ad Astra
"In the end, this thing has earned its morbid moniker. This "flying coffin" lends a war which they call great, a glamour that it simply does not have."
On the Bench: On Deck:
  • Eduard 1:72 Fokker Dr. I
In the Aerodrome:
  • Nothing, yet!
Tiger131
Post by Tiger131 »
love these just think they look cool so look forward to seeing your come along
AchtungPanzer
Post by AchtungPanzer »
Nice model - and super choice of camo for - Will be great :th: Good luck mate :cheers2:
Yevgeny
Post by Yevgeny »
What a beast of a vehicle!
Sir, we're surrounded!
Working on:Trumpeter (00204)
wappynutter
Post by wappynutter »
This is gonna be an excellent piece......
Good luck my friend...
All the best.. :thumb1:
:pop: :pop:
Regards Andy...Image
gustavlekstal
Thank you all for the kind words. This model is almost a one dayer
But I love the little car of fast fury :cheers2:
Easy happy build for any beginner and someone who wants a quick fix of tamiya heaven
Its not detail crazy. I would love to do dragons puma that is made around same time as this, to compare.
Good night! :ooops:
Last edited by gustavlekstal on Sat Oct 25, 2014 6:56 am, edited 3 times in total.
Regards Gustav
Yevgeny
Post by Yevgeny »
Finish date is in January not this month :mrgreen:
rwsmith14
Post by rwsmith14 »
Great subject. Camo should be interesting along with the dio.. Good Luck should be terrific ! :cheers2:
Russ72
Post by Russ72 »
Very cool vehicle, and nice camo choice.
gustavlekstal
Thank you :cheers2:
Little update. The späwagen is finished and starting to add stowage.
Antenna is from a dragon kit. Drilled out the old antenna mounts. Mg34 and distance rods.
Now for some stowage!
Dryfitted and then a rolled out blanket of milliput white is fitted over the "stowage". Pressed and wiped down with a cottonbud dipped in some water.
Rolled the milliputty out with some flouer
Result
Gonna fit it to the späwagen with some canvas stuff from am works
If you want to be able to take the canvas off you put some thin plastic wrapping in between. I didnt cause I can work around it on this wagen and it lifts the canvas during the work
Good night!
Regards Gustav
Deacon
Post by Deacon »
Nice start and a tempting buy for me who is looking to start 1:35 AFV building. :thumb2:
Tiger131
Post by Tiger131 »
God im working slow everybody is steaming through there builds...love what you've done so far
gustavlekstal
Deacon wrote:Nice start and a tempting buy for me who is looking to start 1:35 AFV building. :thumb2:
:cheers2: im to clumsy for the 1:72 :ooops: but tamiya is good first.
Tiger131 wrote:God im working slow everybody is steaming through there builds...love what you've done so far
Thank you! I took a day off work, with no wife away on work until next day. That was my secret! :tongue: :D
First tamiya kit. I just pointed and plastic just jumped together. Not the same detail as dragon but I still loved it.
Regards Gustav
hansolo
Post by hansolo »
Great work on the tarp! The buckles are a very nice detail!
Hansolo
FokkerDXXI
Post by FokkerDXXI »
interesting subject. the kit looks quit nice. I really like the canvas part. :thumb2:
Jos
Its DUTCH, not DEUTSCH!!!
Very cool! I'm beginning to fall in love with these wheeled armoured cars.
I love that stowage. Nice work on the trap and buckles.
fly1ngdutchm4n
Post by fly1ngdutchm4n »
Nice nice nice!
This looks like a cracking kit :thumb2:
Great progress, keep it up :cheers2:
gustavlekstal
Thank you all! :cheers2: :bow::
Small update. Have had little time for play and just alot of work and wife duty :thumb1:
Added camonettinh. Cheese cloth, cut into shape and rolled up with white glue and water. Wrap in plastic
"Rope" is towing cable that im gonna make look like rope
Gonna look smaller when it dries. Broke off the antenna :ooops: but I knew that I would do that, so I had already orded a replecment :tongue:
Oxidrot, yes going for hairspray. Have to improve my hairspray teq after seeing han solos work. Grey and oxidrot looks terrible but im adding one more color to the camo.
Last edited by gustavlekstal on Tue Nov 11, 2014 12:55 pm, edited 1 time in total.
Regards Gustav
Very... Very cool!!!!! :th: :th: :th: :th: :th:
gustavlekstal
Coen wrote:Very... Very cool!!!!! :th: :th: :th: :th: :th:
Tnx Coen. Means alot.
Quick update
Went to town with hs chipping and added stencils from am works. Little tribute to the sig. Ism 6w sig license plate. Oxidrot vallejo cavalry brown 70.982 then matt varnish, dry, hairspray, base tamiya german grey.
Painted rubber! Base xf77
Shadows thinned base + xf1
Highlights base + xf2
Drybrush over shadows panzer aces light rubber 305
wheel rims tamiya german grey. Stencil from am works
Thoughts on how to continue.
1. Finish camo with hairspray method
2. Rust exhaust.
3. Orange filter to make it look desert hot. Grey looks very cold.
4. Oildot fading and create shadows by using light and dark tones
5. Finish chipping and build on the hs teq
Last edited by gustavlekstal on Tue Nov 11, 2014 11:18 am, edited 1 time in total.
Regards Gustav
Russ72
Post by Russ72 »
Nice work. It took me a couple of looks to work out what was going on with the plastic wrap. I understand now. Look forward to seeing how it comes out. :thumb1:
gustavlekstal
Russ72 wrote:Nice work. It took me a couple of looks to work out what was going on with the plastic wrap. I understand now. Look forward to seeing how it comes out. :thumb1:
Haha, sorry. No time for writing
Regards Gustav
rodrant
Post by rodrant »
Just great !
I'm doing a diorama with this Tamiya kit , will present it here in the forum soon as it is almost ready !
Your build is looking great , like a lot the way as you did that chipping with the red primer .
Cheers ,
António
a lot of stuff right now :-)
Deacon
Post by Deacon »
Looking good.
gustavlekstal
Deacon wrote:Looking good.
rodrant wrote:Just great !
Thank you, gonna look for it and get some inspiration.
Started figure painting today. Its my 3 and 4 figure. My eyes are bleeding.
Reference for my tanned dak little fellows of death
Base
Highlights
Shadows. The photo makes em a little darker than they are. But they are well tanned =). Ive been to Tunisia and for the desert rat soldiers I recommend base + alot of scarlet :whistle: :tongue:
Regards Gustav
gustavlekstal
Update "bases done" now Im gonna give everthing a black outline. Zuhälter everything :tongue:
Figures base painted and flesh done
Diorama base done! Maped and cut out on building foam
Given some structure with flower wood stuff from gardenshop
Clay rolled out with water
Happy times brushed with water then leave for dry
Stuff ill be using. Grassrots, sand, granite, large brush, winsor newton sandtexture gel, green line grass and so on.
Sand texture gel (winsor newton) cut grassrots and put sand on hights.
Given a stone wall with swedish granite that im gonna use the diffrent colors to make it look like eyecandy.
Späwagen finished hairspray teq. Gelbbraun stripes airbrushed tamiya 4parts dark yellow 2parts redbrown 1part buff. Ratio 60% thinner and retarder 40% paint at 1 bar.
Glossed up and ready for pinwash
Rust added not finished! Bases done!!!
Plz ask if you want to know more. Alot of work and other engagements makes my time infront of the model valued. I may miss some info cause lack of time and tired little swede.
Regards Gustav
gustavlekstal
Update diorama going sand yellow on this one!
Primer ammo black
Base
Shadows base+darker sand color. ultimate shadow english uniform. Why? Cause it rained alot during the tunisia action.
Highligts base+ light light light sand color
Close up
Picked out the stones
Wash it on! And tomorrow i know if its gone pete tong wrong or great. Thanks for me and good night.
Regards Gustav
Tiger131
Post by Tiger131 »
Looks superb love the colour spot on
gustavlekstal
Tnx mate. Think I'm gonna crap yellow after looking at so many yellow shades.
Regards Gustav
rodrant
Post by rodrant »
Looking very nice , your diorama base :th:
Cheers ,
António
JayCub
Post by JayCub »
Interesting and enjoyable build log, I like seeing this come together and might have a go at one of these.
Tom
Nev
Post by Nev »
Great use of the oils on the base very realistic! Going to be a very nice dio when completed :thumb1: :cheers2:
On the Bench...
gustavlekstal
rodrant wrote:Looking very nice , your diorama base :th:
:cheers2: thank you for the kind words
JayCub wrote:Interesting and enjoyable build log, I like seeing this come together and might have a go at one of these.
Tom
Thank you! As I said before my time is limited, so if anything is unclear send me pm of just ask on log.
Nev wrote:Great use of the oils on the base very realistic! Going to be a very nice dio when completed :thumb1: :cheers2:
Thanks! It turned out really well. Gonn do a update when the diorama is finished. Not far now :banana: :dance:
Regards Gustav
gustavlekstal
Update
Drybrushed sandcolor + white. Thinned to skimmed milk. Sry for the bad light
Played with vegetation, the roots are grassrots and rots from a plant at the beach. Glued with pva glue mixed with water.
Close up
Close up and started the work on a rusted barrel with gloss yellow
Last steps is tiny bits of pigment here and there. The same as Im gonna use on the späwagen and seal it in with matt varnish. Waiting for balsawood to arrive. Happy modelling!
Regards Gustav
Tiger131
Post by Tiger131 »
looks superb the little bits of grass really work well
Deacon
Post by Deacon »
That base is just superb mate, I'm going to have to go through your thread over and over to try to replicate what you have done there.
Wonderful. :thumb2:
gustavlekstal
Deacon wrote:That base is just superb mate, I'm going to have to go through your thread over and over to try to replicate what you have done there.
Wonderful. :thumb2:
:cheers2: tnx mate! I was down on the beach with my minions, collecting more roots and turf today :D pm me if you lack information!!!
Regards Gustav
gustavlekstal
Diorama done! Happy with it! Just waiting for balsawood.
To bad that the späwagen looks like :boom: :-|
The pigments used. Gonna use em on the späwagen too to make to 1 :tongue:
Closeups sealed with matt varnish and then satin on the "lowpoints"
Next update. How I do rust.
Regards Gustav
Tiger131
Post by Tiger131 »
looking real good that barrel looks quality the rust colour is spot on
gustavlekstal
Tiger131 wrote:looking real good that barrel looks quality the rust colour is spot on
Thank you!
Little rust update on how I like to do rust.
Primed then GLOSS yellow
Use 4 diffrent aqrylics
Wash on. Brown for dark rust and yellow for light rust
Pigments mig rust pigments. Focus the dark color on edges
Speckling oilpaint with a stiff brush to give the rust a 3d effect. Flick the first load on papper. Check the sieze of the spots. More paint=bigger spots.
Result
Regards Gustav
Tiger131
Post by Tiger131 »
Superb technique on the oil drum..
Russ72
Post by Russ72 »
Great stuff mate. The rust work looks spot on. :clap:
rodrant
Post by rodrant »
This Drum is SUPER !!! Great Technique , and thank you for showing this interesting paint job , very, very nice , a great Diorama on the way !
Cheers ,
António
Fabulous work so far mate and the oil drum looks the Dogs Danglies! :thumb1: :thumb1: :clap:
Yevgeny
Post by Yevgeny »
That rust is amazing! :jd:
gustavlekstal
Thank you all. Warms my cold scandie heart. I forgot some info. Its good to do the aqrylic wet to get some more colors. For more yellow rust thin the aqrylic more. Rest is complete drying and fix the pigments or the oil speckling will no give the 3d effect.
I like ott weathering. Sometimes its go pete tong wrong and sometimes its dog's dangly bits
Once again thank you all for taking your time to watch my work. :cheers2: :bow::
Regards Gustav
