Hobby Boss 1/48th P-38L-5 Lightning
Ozzie21
Post by Ozzie21 »
I started this kit to be my first all Alclad painted kit. It's nice but simple kit although some of the details could be better. Some of the joint surfaces are in bad spots and may require extra work to remove the seams. Cockpit is very simple tub with a decal for the instrument panel. The instrument panel is recessed for the dials if you wish to paint your own rather than use the decal. I've left the nose off as weight will have to added to keep the nose wheel on the ground. Two decal options are provided, one for the pacific theatre and one for the Indian( far East) theatre.
I'll add seat belts as the cockpit looks empty without them.
Ozzie21
"Keep the CA off the fingers"
1/35th
Re: Hobby Boss 1/48th P-38L-5 Lightning
Looking forward to this mate.
shortCummins
Post by shortCummins »
I'll be following this with interest as the kit is on my (long) wish list
rgds
John
JayCub
Post by JayCub »
Is the instrument panel decals or dry brushed.? looks amazing considering its size, looking forward to the next update
Tom
Ozzie21
Post by Ozzie21 »
JayCub wrote:Is the instrument panel decals or dry brushed.? looks amazing considering its size, looking forward to the next update
Tom
Tom, It's a decal. The instrument panel is recessed with dials so if you want to paint the individual dials you can or if you want to fit individual dial decals you can. Too time consuming for me so I just gloss painted the panel black and applied the decal applying lots of Microset in the process to get the decal to sit down.
Ozzie21
1/35th
Ozzie21
Post by Ozzie21 »
Okay a bit more work on the lightning.
Both props painted and decaled. Still have to apply a clear kote.
Spinner has been painted in Alclad Aluminium and masked for a red band near the hub.
And the result after the mask has been removed.
The under carriage has been painted and dry fitted and the doors and wheel wells painted Aqueous Hobby colour H58 Interior green. Cockpit was done in the same colour. I now have to make a tube of weights for the nose as this is one tail sitter without weight.
Ozzie21
1/35th
AchtungPanzer
Post by AchtungPanzer »
My favorite Yankee fighter :th: .
Ozzie21
Post by Ozzie21 »
Got some more work done on the Lightning. Primed it with Mr Surfacer 1200 then with Alcad II Aqua gloss. Painted with Alcad II Airframe Aluminiumand top coated again with Alcad II Aqua Gloss.
Sorry about the quality of the picture my lights decided to chuck a wobbly and go out on strike so it was normal lighting. I was a bit apprehensive about using the Alcad paint but I found the spray quite easily providing the humidity is right and you choose the right air pressure. I used an Aztek air brush to apply the paint but I don't think it's a good choice so I'll be looking for another airbrush in the new year.
Ozzie21
1/35th
Oh, now you're in my ballpark....loving this one Ozzie! Can't wait to see this completed. great job with the NMF! :) :thumb1: :thumb1: :clap:
heel
Post by heel »
Looking good. Really like how those "spinners" turned out.
