Panzer Selbstfahrlafette conversion from Sdkfz 251 and Pak40
hansolo
Post by hansolo »
Hi guys,
Here’s the building process of my next ‘oddling’.
I saw this picture:
I didn’t know what it was. Had never seen it before.
I asked the guys on this site.
Art17847 helpt me out. Told me all about it.
Here’s the info:
The Panzer-Selbstfahrlafette II, or in full, 7.5 cm Kanone L/41 auf Zugkraftwagen 5t (HKP 902), was a half-track German tank destroyer used during World War II. Only two prototypes were built and sent to North Africa for troop trials. Neither survived the experience
Development began in 1936 when Büssing-NAG was given a contract to develop an advanced half-track chassis with a rear-mounted engine specifically designed for use as a tank destroyer. Four prototypes of the HKP 902 chassis, No. 9009-2012, were built, two of which had Rheinmetall-Borsig's 7.5 centimetres (3.0 in) L/40.8 gun mounted in an open-topped, low-profile turret.
The gun could depress 8° and elevate 20°. It fired a 6.8 kg (15 lb) K.Gr. rot Pz. (APCBC) shell with a muzzle velocity of 685 m/s (2,250 ft/s) and a 5.85 kg (12.9 lb) Sprenggranate (HE) shell at 485 m/s (1,590 ft/s). It carried 35 rounds on board. The armor protection, designed to be proof against armor-piercing 7.92 mm (0.312 in) bullets, was 20 millimetres (0.79 in) thick on the vehicle front, 14.5 millimetres (0.57 in) and 10 millimetres (0.39 in) on the sides, 10 millimetres (0.39 in) on the rear, 10.5 millimetres (0.41 in) on the superstructure roof and 5.5 millimetres (0.22 in) on the belly.[1]
The two prototypes were completed in 1941 and they were organized into a platoon for troop trials with Panzerjäger-Abteilung ("Anti-Tank Battalion") 605 of the Afrika Korps. The first vehicle was reported received on 17 January 1942 by Panzerjäger-Abteilung 605, but the second wasn't reported as arrived in Tripoli until 23 February 1942. The platoon was transferred to the Kampfstaffel des Oberbefehlshaber Panzerarmee Afrika (Rommel's personal battle group) on 8 March 1942. Only one vehicle was reported operational on 25 May at the start of Operation Venezia during the Battle of Gazala; the other had been captured by the British, shown in undated photographs. Shortly afterwards, on 5 June, the Kampfstaffel reported that the other vehicle had been lost after knocking out three tanks. No further references were made to the Pz.Sfl. II.
Hamilcar Barkas even pointed me to a manufacturer of a full resin kit of this panzer (which cost € 149,-!)
I still wanted to build one my self. Mainly because it’s way more fun and also because that only cost me 2 cheap kits to comprise it from (and a truckload of scratch building ;-) ).
I looked for more pictures and found these:
I looked for suitable kits to comprise it from and thought I’d be best of with these two kits:
The Sdkfz251 from Tamiya:
And the Pak 40 from Tamiya:
I made some calculations in order to be able to build the turret the right size.
I compared photo’s of the Hanomag 251 to the Selbstfahrlafette. And by that comparison I got to the right size for the turret.
Turret construction:
Hull construction:
The fenders of the Selbst are largely different to those of the 251, but I could use most of them after cutting them up.
Heard thing; buying a new kit and starting of by cutting it to pieces. ;-)
I could use the lower part of the hull, but had to cut a lot of it off.
I glued the fenders to a bottom plate to create a solid base for the upper hull to sit on.
The front ends of the fenders of the 251 have a sharp edge, but those of the Selbst are round.
But I was able to bend them that way
Time to construct the upper hull
Detailing of the upper hull
Jerry can holders
More detailing
And finally the completed build!
Later on I’ll add some stowage and the rope hanging from the front. :th:
That's all for now folks.
Next up: Painting!
Hansolo
rcfanuk
Re: Panzer Selbstfahrlafette conversion from Sdkfz 251 and Pak40
Post by rcfanuk »
Ace job so far mate, great scratch building.
Steve
Holy crow Han! This is beyond anything that you've done before. It's damned spectacular my friend.
Totally excellent example of fine scale modelling. More please!!!
Beautiful!
hansolo
Post by hansolo »
rcfanuk wrote:Ace job so far mate, great scratch building.
Steve
Stanks Steve :th:
cheers
Hansolo
hansolo
Post by hansolo »
Coen wrote:Holy crow Han! This is beyond anything that you've done before. It's damned spectacular my friend.
Beautiful!
Hi Coen. Thanks so much for your very kind words!
Yep this was a challenge, I'll tell yah!
And lots of fun to put it together in this way.
Quite satisfying! :D
cheers
Hansolo
privatepete
Post by privatepete »
Hi nice to see someone making parts and not just buying them, proper model making, great scratch build very good indeed will be looking forward to see it in paint. Pete :thumb2:
hansolo
Post by hansolo »
privatepete wrote:Hi nice to see someone making parts and not just buying them, proper model making, great scratch build very good indeed will be looking forward to see it in paint. Pete :thumb2:
Thanks, Pete! :th:
cheers
Hansolo
gustavlekstal
Post by gustavlekstal »
:jd: :boom: not surprised anymore with the level of work you do, but this still blows my mind. The hinges looked great and this oddling is already top shelf! :clap: :pop: :pop: I take my hat off and just get inspired.
Regards Gustav
Dragon t-34/85 premium mod 44
viewtopic.php?f=29&t=10747
viewtopic.php?f=29&t=12313
hansolo
Post by hansolo »
gustavlekstal wrote::jd: :boom: not surprised anymore with the level of work you do, but this still blows my mind. The hinges looked great and this oddling is already top shelf! :clap: :pop: :pop: I take my hat off and just get inspired.
Thanks. You're quite welcome. :th:
cheers
Hansolo
Hillbilly
Post by Hillbilly »
WOW,Han your scratchbuilding skills are amazing. :jd: You have captured the lines and look of a Selbstfahrlafette perfectly in my opinion. :clap: I can't wait to see this beast in paint. :th:
Steve
hansolo
Final Update!
Post by hansolo »
Hi guys,
Here's my final update.
The panzer grey base color
After the hairspray layer the final color
Chipping and detail painting
Oilpaint rendering
Pigments
Stowage made from toilet paper soaked in white glue and water. And strapped with sewing yarn for ropes.
Added a towing rope
Frankensteined a soldier from several parts.
And here are the final pics!
That's all folks!
I hope you've enjoyed watching.
I'm now looking for a new 'oddling' to build.
An unorthodox vehicle, a sole contraption, a weardling.
If any of you guys have any suggestions, I would welcome them.
And maybe I will build the vehicle you never thought, would come to life in one to thirtyfive!
cheers
Hansolo
Though I can't really suggest any new builds to you Han, I will compliment you on this one.
Such a simple looking piece completely hides the huge amount of conversion work that you've done. You did such a good job you can't even tell.
Amazing work buddy. First rate.
hansolo
Post by hansolo »
Coen wrote:Though I can't really suggest any new builds to you Han, I will compliment you on this one.
Thanks Coen! I had lot's of fun with it.
I guess I'll be roaming the internet for odd ww2 contraptions.
That's where the fun begins, anyway. :th:
cheers
Hansolo
Nige1940
Post by Nige1940 »
Stunning scratch building Han! very clean and precise .
Looks amazing what a super looking vehicle... now ,build another, cast it in resin ,sell it and I'd definitely buy one ! :thumb2:
hansolo
Post by hansolo »
Nige1940 wrote:Stunning scratch building Han! very clean and precise .
Thanks Nige,
I'll keep that tip in mind! :-)
cheers
Hansolo
