Armstrong Whitworth Whitley Mk.I. 1/72 Fly
Metodi
Post by Metodi »
Hello,
this is my current project and yesterday I uploaded part I of my build video in YouTube, if you are interested please visit the link and don't forget to subscribe: VIDEO BUILD
It has been a so so build do far, while its not Tamiya the kit goes together halfway decent, given it is limited run kit thats ok.
The inbox review is here: INBOX REVIEW
I started the build from the wings and wheel wells assemblies because they seem the most difficult part of the build...time will show
some more work is needed here.
To my knowledge MK.Is had two control columns so I build one myself as there was only one in the kit. I think it'll do the job.
Got the cockpit together
I am going to build the turret-less version but from the bombers window there will be some visibility towards the interior so I installed those parts too. Whats more they'll help with fuselage halves assembly.
I thinned the trailing edges of the horizontal stabilizers
And moved the control surface a bit
I also cut and built the housing for the landing lights
Well that's it for now, all comments are welcome.
Best regards
Metodi
Metodi
Re: Armstrong Whitworth Whitley Mk.I. 1/72 Fly
Post by Metodi »
Hello lads
Thanks dknights
I made some slight progress over the past week so decided to share it.
I primed the interior, the wheel wells and various other parts with AK white primer, then painted them with interior green (mixture of LifeColor interior green and some gray)
Then I highlighted the raised details with lighter shade of the base color and painted the details. Later I did pin wash with MIG dark green-grey panel line wash.
I painted the instrument panel with flat black and then drybrushed it.
I decided to try a new approach to painting the canopy. I always paint the internal part and its almost always PITA. This time painted only a portion which was easy and fast to mask and painted a piece of leftover white decal with the interior color. To "paint" the frames I cut thin stripes of decal and applied them. I haven't done the whole canopy yet but I am happy with the method so far.
That's all for now. All comments are appreciated.
Best regards
Metodi
Metodi
Post by Metodi »
Hello.
Here it is - part II of the video build: http://youtu.be/LKDBx6Sdowg
Hope you enjoy watching it and don't forget to subscribe
Best regards
Metodi
Metodi
Post by Metodi »
Hi there, it's been a while.
Well a lot of boring panel line work and sanding has been done but finally the Whitley is ready for paint.
As I said, quite a lot of work hours went on deepening every single panel line and then sanding the complete model to get rid of the shiny finish and give some grip to help the primer.
I employed almost every filling method I know - regular putty, dissolved putty, milliput, CA glue and plastic strips were used to fill or blend areas of trouble.
Major PITA in this kit is wings to fuselage assembly so I made myself some reinforcement/location pins from paperclips.
The landing lights were scratch-built as mentioned in earlier posts.. I made video tutorial on that:
http://www.mmscalemodels.com/2016/03/la ... orial.html
Part III of the video build is also ready and you can see it here: http://www.mmscalemodels.com/p/armstron ... video.html
Now some pictures:
This picture made me realize that I have misplaced one of the oil coolers... that was remedied later.
It is finally ready for paint
That will be for the next episode.
Best regards
Metodi
Elve1984
Post by Elve1984 »
Nice whitley, your build is comming allong nicely. wonder how she looks with some paint on it.
spock1701
Post by spock1701 »
Looks great so far.
creator
Post by creator »
Looking great so far - I don't remember seeing anyone build one of these beauties before. Look forward to seeing more :)
My scale modelling blog: http://adventuresinscale.blogspot.fr/
Trumpeter 1/35 E-100
HobbyBoss 1/35 Super Pershing
Tamiya 1/35 Sd.kfz.251/9
HobbyBoss 1/35 High Speed Tractor
Metodi
Post by Metodi »
Hello everyone. Thanks for your nice words!
My fourth and final part of the video build log is online and you can see it here:
I had issues with the "primer" I used and if you want to read about them you can do it here:
http://www.mmscalemodels.com/2016/03/ak ... rimer.html
It was not the easiest build but I am pleased with the final result. This build will be featured in MENG AIR Modeller at some point so I will upload just a few pictures here, when it gets published I'll do a proper article on my website.
Here is the finished model:
All comments are welcome.
Best regards
Metodi
