Question about Ultimate washes
qeialto
Post by qeialto »
Hi all,
Do you know if it's ok to spray the Ultimate whashes with an airbrush? If yes, do you know the thinning rate (I suppose not needed).
Finally, to clean the airbrush, is the Ultimate cleaner good for that?
Thanks all,
Antonio
George S. Patton
Work in Progress:
AMT Klingon battle cruise
On the stash?
Timplastic
UN
Re: Question about Ultimate washes
Post by Timplastic »
When you spray the washes you can spray them straight out the bottle.
Just use a needle bigger than 0.3
and umps too clean it is perfect
I spray them with my .4mm needle and nozzle set, unthinned, at 22-25 psi. It will clean up with water or with Ultimate thinner if you like.
The wash particles won't dissolve so you need to be thorough when cleaning to get all of the wash out. So flush well with water to be sure.
qeialto
Post by qeialto »
Thanks for the tips Mates,
It worked perfectly.
Cheers,
Antonio
George S. Patton
Work in Progress:
On the stash?
MGL
Post by MGL »
Hello Together,
I need some help. I'm working on a airplane model and everything went well so far. It's build and painted. Now I put on a gloss varnish (from vallejo) and uses the Ultimate dark dirt wash.
But now is super hard to get the wash of. I tried thinner and turpentine, work a bit better but it's still hard to get off and the whole model gets sticky.
What did I do wrong, to less or the wrong varnish?
Best Michael
Vleugelmoer
Post by Vleugelmoer »
MGL wrote:Hello Together,
Best Michael
As Ultimate washes are clay based acrylics water should be your ticket to remove them. If you left it long and it has gone hard you can try to revive it with a plant mister over several hours.
Using thinner will reactivate the paint underneath and turn it into a gunky mess
Hope it works out for you.
Best Michael
Sadly vallejo gloss is not very good at all, if its not a good gloss coat it will make the wash difficult to remove. If you have one of our green white buffers the green side will take it off.
MGL
Post by MGL »
Hi Paul,
Thank you for your quick answer. Do you have a varnish you can recommend? I already did a quick research and it's seems "Alclad II - Aqua Gloss" must be pretty good.
Best Michael
MGL wrote:Hi Paul,
Best Michael
yeah a few good coats of that will be perfect.
MGL
Post by MGL »
Cool i already ordered it :-) Do you know what the difference between the "Alclad II - Klear Kote Gloss" and "Alclad II - Aqua Gloss" is? I guess this is a really stupid question but i just started with model making.
Best Michael
MGL wrote:Cool i already ordered it :-) Do you know what the difference between the "Alclad II - Klear Kote Gloss" and "Alclad II - Aqua Gloss" is? I guess this is a really stupid question but i just started with model making.
Best Michael
Ones water based the other is enamel i believe :thumb2: Stick with the Aqua gloss
MGL
Post by MGL »
Super thanx. Looking forward to finally use the Ultimate washes.
Best M
lv2bf111
Post by lv2bf111 »
Best Michael
Klear Kote Gloss is enamel based and Aqua Gloss is acrylic. I have had mixed results with the Klear Kote so I would stick to Aqua Gloss in this case. Not sure what I am doing wrong with the Klear Kote it just has been staying tacky on me.
Current builds: Shinny things: Revell 1/48 B-17 with a 1:48 Tamiya P-51B Mustang Blue Nose | Revell 1/48 Apache
Return to “Weathering”
