Yak-52M - 1:72 - AModel
Bogdan
Post by Bogdan »
Yak-52M aircraft is intended for professional selection and primary training of future pilots as well as for aerobatic training of sportsmen.
Yak-52M is a two-seater, single engine monoplane of classical configuration with low wing, retractable tricycle landing gear with nose wheel and the M-14X engine.
The aircraft presents Yak-52 modification and differs from the original by the following:
50% of airborne equipment is renewed that provides for flights in adverse weather conditions at night;
the new canopy is installed to ensure safe bailout with the help of escape system;
the СКС-94МЯ escape system is installed to enhance crew safety;
the integral tanks are embodied in wing structure that increase range of flight up to 900 km;
the rudder area is increased ;
the blind flying cap is installed;
three-blade МТV-9 propeller is installed;
the wing aerodynamics is changed for stall performance improvement. Source: www.yak.ru
It seems like an easy build :eeek:
Bogdan
Re: Yak-52M - 1:72 - AModel
Post by Bogdan »
Operation plastic surgery
Surely not the last one :))))
Bogdan
Post by Bogdan »
Dry fit
