Any ideas
Augustus
Any ideas
Post by Augustus »
How to fix/workaround broken spindle?
Madmattmodels89
Re: Any ideas
Post by Madmattmodels89 »
Hmmm may be drill tru and make a new pin either out of plastic or metal. Might work . I did it on a Sherman never had an issue
OliveDrab
Re: Any ideas
Post by OliveDrab »
Madmattmodels89 wrote:Hmmm may be drill tru and make a new pin either out of plastic or metal. Might work . I did it on a Sherman never had an issue
Agreed, drill out the old and make a new pin as Madmatt suggested :thumb2:
Curt :cheers2:
Nev
Re: Any ideas
Post by Nev »
I broke one on a Tamiya kit last year, used an old thin knitting needle pushed through to fix it. Hope helps
On the Bench...
Re: Any ideas
drill through and a styrene rod replacement as suggested by Madmattmodels89 is the way.
Augustus
Re: Any ideas
Post by Augustus »
I've topped and tailed a small nail. It's got a smaller diameter but I'll try a dollop of Tamiya putty.
HamilkarBarkas
Re: Any ideas
Post by HamilkarBarkas »
Glue it on flush, the tracks are segmented ones on this kit so there is no need to keep it moveable. Getting the position right should not be a tricky thing at all.
chalkyw
Re: Any ideas
Post by chalkyw »
BIn it and move on to another model :jd: :tongue: :tongue: :tongue: ....lol....sounds like you've sussed out a good solution there already mate...how did the tarps turn out??
Sydnoufle
Re: Any ideas
Post by Sydnoufle »
If I were concerned with this problem, my challenge would be to center the hole on the right place. I'd use a piece of metal sheet (a soda can would do) where I'd drill a hole the same diameter as the broken axle, then I'd use the "tool" to center the hole on the model. Once you have drilled the hole at the right place, a small rod will do the task.
Hope it will help
Jose
Augustus
Re: Any ideas
Post by Augustus »
chalkyw wrote:BIn it and move on to another model :jd: :tongue: :tongue: :tongue: ....lol....s
Another German model Chalky?? :pistols:
Re: Any ideas
I'd go with Hamilkars suggestion, most of the time the simplest solution is the best. KISS (keep it simple stupid)
Re: Any ideas
sounds like a plan
Augustus
Re: Any ideas
Post by Augustus »
Well the stupid fits so I might go with the rest of the plan!
Re: Any ideas
Ha ha!
