Trumpeter 1/72 Hawker Sea Fury FB.11
TommyKillander
Post by TommyKillander »
Hey Guys!
Postie finally showed up with my kit today, so I can start my build-thread;
I will build the Trumpeter 1/72 Hawker Sea Fury Mark 11 (FB.11) with some extra Eduard PE and a masking kit added to the build.
I'm really looking forward to build this awesome aircraft! :banana:
I think the paint-scheme looks amazing - I love the Sky/Dark Grey color combination (hope I can do it justice)
Boxart:
ImageIMG_20170405_183744 by Tommy Killander, on Flickr
Sprues:
ImageIMG_20170405_184441 by Tommy Killander, on Flickr
ImageIMG_20170405_184333 by Tommy Killander, on Flickr
ImageIMG_20170405_184130 by Tommy Killander, on Flickr
Decals:
ImageIMG_20170405_184115 by Tommy Killander, on Flickr
Instruction manual and paint/decal scheme:
ImageIMG_20170405_184005 by Tommy Killander, on Flickr
Hawker Sea Fury:
The Hawker Sea Fury was a British fighter aircraft designed and manufactured by Hawker. It was the last propeller-driven fighter to serve with the Royal Navy, and also one of the fastest production single piston-engined aircraft ever built. Developed during the Second World War, the Sea Fury entered service two years after the war ended. The Sea Fury proved to be a popular aircraft with a number of overseas militaries, and was used during the Korean War in the early 1950s, as well as against the 1961 Bay of Pigs Invasion of Cuba.
The Sea Fury attracted international orders as both a carrier and land-based aircraft; it was operated by countries including Australia, Burma, Canada, Cuba, Egypt, West Germany, Iraq, and Pakistan. The type acquitted itself well in the Korean War, fighting effectively even against the MiG-15 jet fighter. Although the Sea Fury was retired by the majority of its military operators in the late 1950s in favour of jet-propelled aircraft, a considerable number of aircraft saw subsequent use in the civil sector, and several remain airworthy in the 21st century both as heritage and racing aircraft.
Background:
With the end of the Second World War in Europe in sight, the RAF began cancelling many aircraft orders. Thus, the RAF's order for the Fury was cancelled before any production examples were built because the RAF already had excessive numbers of late Mark Spitfires and Tempests and viewed the Fury as an additional overlap with these aircraft. Although the RAF had pulled out of the programme, development of the type continued as the Sea Fury. Many of the Navy's carrier fighters were either lend-lease aircraft and thus to be returned, or in the case of the Supermarine Seafire had considerable weaknesses as naval aircraft such as narrow undercarriages. The Admiralty opted to procure the Sea Fury as the successor to these aircraft instead of purchasing the lend-lease aircraft outright.
The first production model, the Sea Fury F Mk X (Fighter, Mk 10), flew in September 1946. With the completion of flight testing at Boscombe Down in 1946, the trials process was repeated aboard the aircraft carrier HMS Victorious. Carrier testing revealed directional stability issues related to rudder effectiveness during landing, and this was resolved by the adoption of a tail wheel lock, which also improved the wheel retraction behaviour. Several rectifying design changes were made by Hawker in response to feedback from the test pilots, including the adoption of a five-bladed Rotol propeller to greatly reduce overspeed tendencies, a re-designed rudder assembly to increase rudder effectiveness, Dynafocal engine mountings to reduce vibration at low speeds, and an improved undercarriage with greater flexibility; these changes greatly improved the aircraft's deck landing characteristics. Arrestor hook trials initially revealed the Sea Fury to be prone to missing the wires, this was rapidly resolved by modifications to the hook dampener mechanism.
By March 1947, production Sea Furies were already being produced for the Fleet Air Arm. The fourth and sixth production aircraft were used in further trials with Illustrious, and the main change from the earlier aircraft was the adoption of a longer, stiffer arrestor hook. Fifty Mk X Sea Furies were produced. These were identical to the SR666 prototype except for the Centaurus 18 engine and four-bladed propeller; at least 20 of the 50 aircraft performed in the aircraft's intensive trials programme. Following the successful completion of weapons trials at the A&AEE Boscombe Down, the Sea Fury was cleared for operational use on 31 July 1947.
Hawker Aircraft continued to develop and refine the Sea Fury Mk X, resulting in the more capable Sea Fury Mk 11, otherwise known as the Sea Fury FB 11. This upgraded model had several improvements, most notable being the hydraulically powered wing folding mechanism which eased flight deck operations and the adoption of new weapons for performing air-to-ground combat. Iraq ordered a two-seat Sea Fury model and the British Admiralty followed suit. During testing, the rear canopy collapsed, leading to a redesign of the type's two-seat cockpit prior to entering service. Designated as the Sea Fury T 20, a total of 60 trainers were manufactured for the Fleet Air Arm between 1950 and 1952. The Royal Navy bought a total of 615 Sea Furies, mostly of the Mk 11 standard.
Specifications:
General characteristics
Crew: One
Length: 34 ft 8 in (10.56 m)
Wingspan: 38 ft 4?3/4 in (11.69 m)
Height: 15 ft 10?1/2 in (4.84 m)
Wing area: 280 ft2 (26.01 m2)
Empty weight: 9,240 lb (4,191 kg)
Loaded weight: 12,350 lb (5,602 kg)
Max. takeoff weight: 14,650 lb (6,645 kg)
Powerplant: 1 × Bristol Centaurus 18 18-cylinder twin-row radial engine, 2,480 hp (1,850 kW) (take-off)
Performance
Maximum speed: 460 mph (400 knots, 740 km/h) at 18,000 ft (5,500 m)
Range: 700 mi (609 nmi, 1,126 km) with internal fuel; 1,040 mi (904 nmi, 1,674 km) with two drop tanks
Service ceiling: 35,800 ft (10,910 m)
Rate of climb: 4,320 ft/min (21.9 m/s)
Armament
Guns: 4 × 20 mm (.79 in) Hispano Mk V cannon
Rockets: 12× 3 in (76.2 mm) rockets or
Bombs: 2,000 lb (907 kg) of bombs
Last edited by TommyKillander on Sat Jul 01, 2017 10:55 am, edited 1 time in total.
jnbattleship
Re: Trumpeter 1/72 Hawker Sea Fury FB.11
Post by jnbattleship »
watching with interest. I like this aircraft a lot.
Google / Youtube - TheRohalla
MightyDraw
Post by MightyDraw »
Great subject choice. Certainly one of the definitive piston powered fighters, and definitely one of my top 5 favorite aircraft. Ive been working on the 1/48 version, originally intending to save it for this SIG but decided to do Canadian markings. I certainly hope the forthcoming Airfix 1/48 Sea Fury is good!
Shove over, I need a good seat to watch Tommy build
jnbattleship
Twokidsnosleep wrote: Thu Apr 06, 2017 6:05 pm Shove over, I need a good seat to watch Tommy build
You may get some overspray in the front row. :dance:
jnbattleship wrote: Thu Apr 06, 2017 7:47 pm
I'll keep my head tilted so the spray covers the bald spot :tongue:
TommyKillander
jnbattleship wrote: Thu Apr 06, 2017 3:17 pm watching with interest. I like this aircraft a lot.
MightyDraw wrote: Thu Apr 06, 2017 5:38 pm Great subject choice. Certainly one of the definitive piston powered fighters, and definitely one of my top 5 favorite aircraft. Ive been working on the 1/48 version, originally intending to save it for this SIG but decided to do Canadian markings. I certainly hope the forthcoming Airfix 1/48 Sea Fury is good!
It's a great looking aircraft and after completing my MiG-15 it feels just right to build this one too :)
Good luck with your 1/48, MightyDraw.
Twokidsnosleep wrote: Thu Apr 06, 2017 8:16 pm
:lol: :lol:
Scott, what colour do you prefer, XF-21 or XF-24 ?
Tommy
Whichever is closest to blondish with a touch of grey...although anything is better than solid shiny bald :D
TommyKillander
Twokidsnosleep wrote: Thu Apr 06, 2017 9:51 pm Whichever is closest to blondish with a touch of grey...although anything is better than solid shiny bald :D
I'll see what I can do :D
Okey... I have finally got some time to sit down and build :banana:
As ursual I have started to clean up the parts for the cockpit and I also sent some time trying to figure out which parts of PE I should use and in which order I need to assemble everything. It's not a complicated kit, but there are lots of PE and some parts needs to be painted and some parts are prepaintede already. :scratch::
I also looked at some pictures to get ideas of what the most prominent details look like.
The kit itself does not offer much details as it is (it's not like my latest Tamiya or Eduard builds), so part from the PE I will scratchbuild some stuff too... ;)
ImageIMG_20170408_135018 by Tommy Killander, on Flickr
Chiseled and sanded down all details to prepare for the PE sidepanels
ImageIMG_20170408_141219 by Tommy Killander, on Flickr
So, let's make things complicated to begin with... :wtf:
I decided not to use the PE seat-cushion and instead mould a new one using a PE mesh to make an imprint.
ImageIMG_20170408_143220 by Tommy Killander, on Flickr
The "clay" is baked in the oven and after that it will be hard as plastic and possible to sand.
ImageIMG_20170408_143415 by Tommy Killander, on Flickr
This is the result, I'm happy with that - I don't dare to try to sand it thinner. Thge yellow thing on the PE-fret is the one that I'm replacing...
ImageIMG_20170408_155008 by Tommy Killander, on Flickr
One of the instruments (compass?) stand on a small tripod made of PE. I bent one leg too many time and it broke off, so I decided to make a washer from 1mm plasticard to cover up that :shifty: :whistle:
ImageIMG_20170408_185336 by Tommy Killander, on Flickr
More details to the cockpit tub and some of the small parts cleaned up and ready for paint
ImageIMG_20170408_202317 by Tommy Killander, on Flickr
ImageIMG_20170408_204856 by Tommy Killander, on Flickr
We're finally on track with this, I'm very pleased that I could get this started today! :th:
One more thing; I found this great documentary about the Sea Fury; such an awesome aircraft!
Ignore the YT title - it's made by a troll :D
[youtube]VkODOyX6hDw[/youtube]
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 10:59 am, edited 1 time in total.
TommyKillander
Ohai, fellas!
Had some good benchtime today...
I drilled out the holes in the main landing gear support strut with a pin vice and a couple of different drill bits.
ImageIMG_20170409_115726 by Tommy Killander, on Flickr]
A also did a quick dry-fit of the main landing gear to see if I needed to deal with ejection pin marks - I was hoping that they would be covered by the tire, but it seems that I had to do something about them
ImageIMG_20170409_131444 by Tommy Killander, on Flickr
The first one was quite shallow so I could scrape and sand it away, the second one need a drop of dissolved sprue
ImageIMG_20170409_132538 by Tommy Killander, on Flickr
I also started to detail up the main wheel bay, I covered two ugly ejection pin marks with plasticard
ImageIMG_20170409_144744 by Tommy Killander, on Flickr
Adding tubes and wires.... Reference pictures show that it's very busy, but I will only add a couple of lead wires and plasticard details....
ImageIMG_20170409_152254 by Tommy Killander, on Flickr
This is enough I think - It's 1/72 after all... :tongue:
ImageIMG_20170409_155325 by Tommy Killander, on Flickr
Some dryfitting - details looks ok but there are a lot of flash
ImageIMG_20170409_162604 by Tommy Killander, on Flickr
...some gaps are hard to get rid of :?
ImageIMG_20170409_162622 by Tommy Killander, on Flickr
Wing root looks OK
ImageIMG_20170409_162658 by Tommy Killander, on Flickr
...but I will have to rescribe all those small panels :(
ImageIMG_20170409_162806 by Tommy Killander, on Flickrl]
So this kit seems to be a bit of a roller-coaster-ride to look forward to. The tooling is from 2005 so I was hoping for less flash :shifty:
I must admit that I havce started to get spoiled by Tamiya and Eduard kits :lol:
Fueltanks - I tried using Tamiya Cement for gluing the parts together and to have time to make a final alignment before I glued them in place using Tamiya Extra Thin. Worked like a charm! Thanks Paul for that tip!
ImageIMG_20170409_163744 by Tommy Killander, on Flickr
I will leave them to cure overnight so the seams have hardened, before I sand and polish them. The tanks will be quite visible since I will build the Sea Fury with wings in the folded up position. So I can't make a shortcut :tongue: :oops:
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:15 am, edited 1 time in total.
dogsbody
Post by dogsbody »
Regarding the drop tanks, I have read somewhere that the kit's tanks are over-sized. I don't remember just where I read it as it was just after the kit was released.
Chris
"What young man could possibly be bored
with a uniform to wear,
a fast aeroplane to fly,
and something to shoot at?"
TommyKillander
dogsbody wrote: Mon Apr 10, 2017 5:53 pm Regarding the drop tanks, I have read somewhere that the kit's tanks are over-sized. I don't remember just where I read it as it was just after the kit was released.
Chris
There are a couple of known issues with this kit according to this review http://hyperscale.com/2007/features/sea ... nggp_1.htm . It doesn't mention the droptanks, but that does not mean that they are correct in size, right ;)
I cant find any aftermarket replacement parts so I will leave it at that I think. Scratchbuilding those is "next level" for me... :crazy:
Okay.... did some more work this evening...
I have fitted the small circular window on the left side of the fuselage. I have no idea what this is - someone suggests a recce camera lens port, but I haven't found any reliable source for that. I have covered the backside with some kitchen foil so it will not be completely dark.
ImageIMG_20170410_190434 by Tommy Killander, on Flickr
This is how it looks.
ImageIMG_20170410_190510 by Tommy Killander, on Flickr
I have primed up most of the small parts and the inside of the fuselage, so I will start painting and assemble the cockpit tub tomorrow :)
ImageIMG_20170410_194432 by Tommy Killander, on Flickr
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:16 am, edited 2 times in total.
Willem
Post by Willem »
Looking great mate. Some fabulous added details in 1/72.
Will
Edward R Murrow
MightyDraw
Looking good so far. One thing I can say this kit has over its 1/48 counterpart; it is not afflicted with the over the top rivet detail the 1/48 has.
Joesdad
Post by Joesdad »
Loving this Tommy :pop:
Tim (Ted)
British Aviation In Scale
TommyKillander
Thanks guys! :D
I have continued to work on the cockpit:
The tub, sidewalls and IP have been painted with a dark blue/grey colour (XF-63 German Grey) and the seat with a Dark Yellow (XF-59 Desert Yellow with a couple of drops of XF-3 Yellow) and the chair with XF-1 Black
ImageIMG_20170411_203506 by Tommy Killander, on Flickr
And it's time for some fun PE-bending :crazy:
ImageIMG_20170412_122611 by Tommy Killander, on Flickr
I need to add a short piece of 0.5mm rod for the throttle handle
ImageIMG_20170412_123631 by Tommy Killander, on Flickr
Finished - but it will hardly be seen when the fuselage is closed up :shifty:
ImageIMG_20170412_135145 by Tommy Killander, on Flickr
I have applied som Abt 502 oilwash in the cockpit to make the interior become more "visible". The cockpit is very dark so I need to do everything I can to enhance the contrast.
ImageIMG_20170412_201848 by Tommy Killander, on Flickr
The droptanks have been resting for a couple of days so I thought it was time to sand and polish the seams. I don't think that I will need any filler, but I'll make a final check after the primer have been applied.
ImageIMG_20170412_195803 by Tommy Killander, on Flickr
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:20 am, edited 1 time in total.
Sweet :thumb2:
Loving the details and scratch building.
Wings folded will look great...and a bit different too
I am positive she will be a beautiful bird
ps Happy Easter
Technophobe
Post by Technophobe »
Enjoying your build and brings back memory's of my trouble free build! :thumb1:
I know that a lot of Trumpeter kits get a knocking but I think that the Sea Fury makes for a good kit!
I used Eduard PE, the Pavla cockpit and brass tube to replace the exhausts (only as I have an inability to build of of the box) and the I only thing that I would say that needs to be replaced, is the kit prop blades which just don't look right so also used Pavla's replacement set and whilst I can't put my finger on the problem, I think that these may also be suspect!
...and pray that there's intelligent life somewhere up in Space cos there's bugger all, down here on Earth!
RossiM1
Post by RossiM1 »
Great looking subject Tommy and the Eduard etch will really liven the detail up. Love that seat cushion you made will borrow that sometime if you do not mind looks so much better than just the flat etch. Look forward to seeing this come together. Good luck :th:
Gary aka RossiM1
jnbattleship
Moving on pretty fast with this beauty. I am not a rivet counter so there is absolutely nothing that can make your model any lesser than good. The plastiformed cushions are a special treat.
Great work Tommy.
TommyKillander
Twokidsnosleep wrote: Thu Apr 13, 2017 5:29 pm Sweet :thumb2:
ps Happy Easter
Thanks Scott, likewise!
Tommy
TommyKillander
Technophobe wrote: Thu Apr 13, 2017 5:51 pm Enjoying your build and brings back memory's of my trouble free build! :thumb1:
Wow! That looks awesome !
Love details like the rocket-rails (are those scratchbuilt?) - great job overall I think.
Yeah, I must admit that I have been eyeballing the Pavla resin upgrades (props and cockpit) and I was very tempted to buy them, but since I bought the Eduard PE Zoom set I didn't really need it and I thought that the Pavla props didn't look convincing on the photos so I decided to skip them.
I would love to have a set of Dowty Rotol decals on the props, but they are not included in the kit :violin:
Regarding Trumpeter: I would rate this kit as a good kit - it's not fantastic. Trumpeters modern jets in 1/72 in new toolings are fantastic. I got the MiG-29SMT and the SU-33 Flanker D (sofar) in my stash :)
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:22 am, edited 2 times in total.
TommyKillander
RossiM1 wrote: Thu Apr 13, 2017 9:37 pm Great looking subject Tommy and the Eduard etch will really liven the detail up. Love that seat cushion you made will borrow that sometime if you do not mind looks so much better than just the flat etch. Look forward to seeing this come together. Good luck :th:
Thanks, Gary!
No problem, steal whatever you want - it's up for grabs ;)
jnbattleship wrote: Fri Apr 14, 2017 5:40 pm Moving on pretty fast with this beauty. I am not a rivet counter so there is absolutely nothing that can make your model any lesser than good. The plastiformed cushions are a special treat.
Thanks, the kit have been good to me sofar...
Avgas wrote: Fri Apr 14, 2017 5:58 pm Great work Tommy.
Thanks Dave! :)
Tommy
Technophobe
TommyKillander wrote: Fri Apr 14, 2017 8:21 pm Wow! That looks awesome !
Tommy
Thanks Tommy and yes the rails were scratch built!
martin57
Post by martin57 »
:jd: looking great
TommyKillander
Technophobe wrote: Sat Apr 15, 2017 3:16 pm Thanks Tommy and yes the rails were scratch built!
Thanks Technophobe, I might copy that detail, if you don't mind.
martin57 wrote: Sat Apr 15, 2017 7:19 pm :jd: looking great
Thanks martin57 :)
Okey, I have spent the Easter sofar assembling the cockpit and putting the fuselage halves together, Yay! :banana:
ImageIMG_20170414_171829 by Tommy Killander, on Flickr
ImageIMG_20170414_171906 by Tommy Killander, on Flickr
ImageIMG_20170414_172029 by Tommy Killander, on Flickr
ImageIMG_20170414_172743 by Tommy Killander, on Flickr
ImageIMG_20170414_172815 by Tommy Killander, on Flickr
The control-stick in this kit is really not to scale.... :lol: :tongue:
I have also painted the main gear bay and the "engine" in Vallejo Metal Colour "Dull Aluminium", the oil-cooler intake is painted with a darker metal tone (Steel).
ImageIMG_20170415_153847 by Tommy Killander, on Flickr
Fuselage halves glued together :dance:
ImageIMG_20170415_154118 by Tommy Killander, on Flickr
Unfortunately I had a lot of fit issues caused by the PE (IP and sidepanels), I managed to squeeze the fuselage together, but I didn't use enough clamps so it moved while the glue cured. So I got quite soft seams that "eroded" when I sanded and polished them. It's not the end of the world - I can fix this with some CA-glue as a filler/bonder, which I will sand and polish. I might have to do it a couple of times to get the result I'm looking for.
ImageIMG_20170415_154344 by Tommy Killander, on Flickr
ImageIMG_20170415_184456 by Tommy Killander, on Flickr
This is an example of a seam that have been excavated as a result of the glue issue mentioned above
ImageIMG_20170415_195622 by Tommy Killander, on Flickr
I have filled all defect seams with CA-glue and it will cure overnight. I have noticed that the styrene in this kit is quite soft and I might have used too much Tamiya Extra Thin - and as a consequence I softed the styrene too much... Well well, you learn as long as you live (and live as long as you learn ;)
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:26 am, edited 1 time in total.
RossiM1
Post by RossiM1 »
The cockpit detail is looking really nice Tommy, that's a real shame about those seams have you ever tried the baking soda and super glue method its great for building up the seam and is rock hard and sands and polishes very nicely.
Gary aka RossiM1
TommyKillander
RossiM1 wrote: Sat Apr 15, 2017 8:47 pm The cockpit detail is looking really nice Tommy, that's a real shame about those seams have you ever tried the baking soda and super glue method its great for building up the seam and is rock hard and sands and polishes very nicely.
Thanks for the tip, buddy :th:
I have heard about using baking soda, but I thought it was used primarily as a "kicker".
No worries I will fix those seams tomorrow, they look worse than they are due to the magnification.
...but I have to rescribe a lot of panel-lines and I'm not looking forward to that :?
Tommy
TommyKillander
Hey Guys!
I have been able to get rid of those small seams and indentations using a second round of CA-glue, so the surfaces are ready for rescribing. There are 4 or 5 panellines that are lost so it's not a crazy amount of rescribing needed. But it's enough for me to feel anxious about it - for me this is the least enjoyable party of modelling (or to be more correct the only part that I do not enjoy) :cry:
But it has to be done and I just have to be very careful doing it.
ImageIMG_20170416_174607 by Tommy Killander, on Flickr
ImageIMG_20170416_174643 by Tommy Killander, on Flickr
Main landing gear bay, the engine and oil cooler intake have been weathered using AK and Tamiya washes.
ImageIMG_20170416_173955 by Tommy Killander, on Flickr
I will seal those parts with flatcoat today so I can proceed with the assembly of the engine cowling and main wing.
Last edited by TommyKillander on Sat Jul 01, 2017 11:27 am, edited 1 time in total.
jnbattleship
Spiffy! Fantastic work on these details.
martin57
Post by martin57 »
Liking the cockpit Tommy , this is going to be a stunner :th:
Technophobe
TommyKillander wrote: Sat Apr 15, 2017 8:33 pm
Please, feel free it's your hobby as well as mine :thumb1:
British cockpits of the time may well have been dark and drab but you've done an excellent job of bringing this one to life :clap:
Tony
TommyKillander
Thanks guys! :)
Okey... I have started to assemble the main wingsection and engine cowling now
ImageIMG_20170417_134949 by Tommy Killander, on Flickr
ImageIMG_20170419_183646 by Tommy Killander, on Flickr
ImageIMG_20170419_185258 by Tommy Killander, on Flickr
I hate when the clamps snap and fly all over the workbench, so I used a small pad of foam to get a better grip for the clamp - it worked great!
I decided not to use the styrene parts for the Hispano Mk V 20 mm guns, because I think they look ugly and need a lot of cleaning up. I will scratch build them from a styrene rod instead, it's much easier and the end result will probably be better.
ImageIMG_20170419_193250 by Tommy Killander, on Flickr
I can't postpone this any more, so I rescribed the panellines on the fuselage.
I prepared myself by bring out every tool I got.... :lol:
ImageIMG_20170419_165645 by Tommy Killander, on Flickr
However, I only used Dymo tape and the Trumpeter rescriber for straight lines. For the smaller panels I used a scribing template and an old airbrushneedle in a pin-vice. The result is not perfect but it will suffice. I sanded and polished the surfaces and cleaned out the dust with IPA and a cotton bud.
ImageIMG_20170419_174334 by Tommy Killander, on Flickr
The Main wing section snapped firmly into place and the wingroots looks fine, so there is no need for any filler here... :thumb1:
ImageIMG_20170419_192051 by Tommy Killander, on Flickr
But there is an ugly seam on the bottom side that needs some attention... :bash: :wall: :violin:
ImageIMG_20170419_192114 by Tommy Killander, on Flickr
That's all for today - cheers!
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:33 am, edited 1 time in total.
TommyKillander
Hey guys!
I worked on the underwing navigation lights yesterday, using this picture as a reference:
First I had to clear the parts from flash
ImageIMG_20170422_095926 by Tommy Killander, on Flickr
I sprayed XF-60 Dark Yellow on a piece of kitchenfoil where I had masked the "lenses" for the red and green lights.
ImageIMG_20170422_105431 by Tommy Killander, on Flickr
I tinted the lenses with X-25 Clear Green and X-27 Clear Red
ImageIMG_20170422_110347 by Tommy Killander, on Flickr
I used Tamiya tape to affix them to the inside of the wing, since I wanted a distance between the clear lens on the wing and the lamps. Hope that makes sense...
ImageIMG_20170422_111708 by Tommy Killander, on Flickr
The dissolved sprue that I used to fill the gap between the fuselage and the main wing had been left for a couple of days to cure, so it was time to sand down the excessive material and polish the seam.
ImageIMG_20170422_152808 by Tommy Killander, on Flickr
Seam have been polished and is smooth now, but there are a couple of airbubbles that needs to be taken care of, so I will clean out the dust with some IPA and fill them with CA-glue. But I'm happy with the result, I managed to preserve most of the panel-lines :)
ImageIMG_20170422_155037 by Tommy Killander, on Flickr
Stay tuned!
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:35 am, edited 1 time in total.
Fridgy
Post by Fridgy »
Love your work Tommy :thumb2:
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
TommyKillander
Fridgy wrote: Sun Apr 23, 2017 9:30 am Love your work Tommy :thumb2:
Thanks Mick ! :bow::
Tommy
jnbattleship
Nice work, especially in the detail preservation department :). It should save lot of mojo-killing minutes later.
martin57
Post by martin57 »
There is some fantastic detail going it this kit Tommy .
I am not keen on doing panel lines either , but thay turned out well.
Keep up the good work :th:
TommyKillander
jnbattleship wrote: Tue Apr 25, 2017 3:41 pm Nice work, especially in the detail preservation department :). It should save lot of mojo-killing minutes later.
martin57 wrote: Tue Apr 25, 2017 5:11 pm There is some fantastic detail going it this kit Tommy .
Many thanks, martin57 and jnbattleship ! :)
Can't agree more about the mojo-killing stuff :D
I rather spend a couple of hours dryfitting parts to minimise the gaps before i glue them together, than spend a single minute rescribing... :shifty:
Tommy
RossiM1
Post by RossiM1 »
Great progress Tommy, those seams disappeared nicely, :thumb1: it's coming together very nicely mate
Gary aka RossiM1
TommyKillander
RossiM1 wrote: Wed Apr 26, 2017 8:13 pm Great progress Tommy, those seams disappeared nicely, :thumb1: it's coming together very nicely mate
Thanks Gary!
I have fixed the small indentations caused by the airbubbles using CA-glue now, so the seam is completely gone now. :thumb2:
Okey... Today I have fixed the gunsight.
This sorry piece of plastic is the gunsight in the kit
ImageIMG_20170427_125652 by Tommy Killander, on Flickr
I decided to scratch build a GGS Mk IV based on this picture
This is the result
ImageIMG_20170427_130213 by Tommy Killander, on Flickr
I painted it with XF-1 Black, added the projector lenses with X-11 and a small transparent PET "screen"
ImageIMG_20170427_152417 by Tommy Killander, on Flickr
ImageIMG_20170427_153026 by Tommy Killander, on Flickr
And it's time to close up the cockpit and start masking stuff for painting :dance:
ImageIMG_20170427_172226 by Tommy Killander, on Flickr
ImageIMG_20170427_184557 by Tommy Killander, on Flickr
More masking fun will follow soon - stay tuned!
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:39 am, edited 1 time in total.
Willem
Post by Willem »
Oh yes. A scratch built gun sight at 1/72? You're making us all look lazy. Nice work mate. The kit part did look a bit rubbish!
Will
Edward R Murrow
TommyKillander
Willem wrote: Thu Apr 27, 2017 10:11 pm Oh yes. A scratch built gun sight at 1/72? You're making us all look lazy. Nice work mate. The kit part did look a bit rubbish!
Thanks Will! :)
Tommy
TommyKillander
Hey Guys!
It's been a busy weekend at the bench. Good stuff! :th:
I'll continue with the masking of the fuselage and starting to prep the kit (and myself) for paint.
Lets cover up those wheel wells; I'm using a piece of paper to protect the small details and the weathering from the sticky side of the masking tape.
ImageIMG_20170430_104043 by Tommy Killander, on Flickr
One down, one to go...
ImageIMG_20170430_104801 by Tommy Killander, on Flickr
I am not happy with the seamline in the air intake for the cooling radiator... That part of the leading edge of the wing will attract the eye.
ImageIMG_20170430_110342 by Tommy Killander, on Flickr
So I decided to add inner walls of plasticard to cover that
ImageIMG_20170430_111231 by Tommy Killander, on Flickr]
I also took the decision to scratchbuild the pitot tube, since the kit part is difficult to clean up - sometimes it's less work involved and it will give a better end result to scratchbuild stuff instead of spend time fixing moulding issues ;)
ImageIMG_20170430_113213 by Tommy Killander, on Flickr
I used a 0.75 mm styrene rod and a gauge 11 guitarstring for the pitot tube
Ready for primer!
ImageIMG_20170430_120715 by Tommy Killander, on Flickr
...and there you go! :dance:
ImageIMG_20170430_133038 by Tommy Killander, on Flickr
I sprayed up a couple of spoons to experiment with Dark Sea Grey and Sky colours
Main wheels painted
ImageIMG_20170430_142328 by Tommy Killander, on Flickr
There are a couple of yellow insignia marks on the propeller. I always use Pink as a base when I paint yellow, to get that stark Insignia Yellow tone.
ImageIMG_20170430_144744 by Tommy Killander, on Flickr
And I can use standard Tamiya XF-3 Yellow.
ImageIMG_20170430_162157 by Tommy Killander, on Flickr
I will leave it until tomorrow to cure before I mask the tips of the blades and the ring on the spinner
Cheers!
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:42 am, edited 1 time in total.
pourquoi61
Post by pourquoi61 »
Yep, you do make me feel like one lazy model maker.
Brilliant. :bow:: :bow::
TommyKillander
pourquoi61 wrote: Sun Apr 30, 2017 6:10 pm Yep, you do make me feel like one lazy model maker.
Thanks, pourquoi61 :D
You shouldn't feel like a lazy modeller - it's me being broken and spending too much time on my builds :lol:
Okey... Painted the prop using XF-85 Rubber black, just to give some variation to the standard black. I think this black/blue tone will look nice with the Dark Sea Greay and Sky.
ImageIMG_20170501_153027 by Tommy Killander, on Flickr
Speaking of Dark Sea Gray and Sky... Let's paint some spoons:
ImageIMG_20170501_190822 by Tommy Killander, on Flickr
I started by painting some colours that looks Sky-ish from the Tamiya range, just to compare. I soon came to the conclusion that XF-14 and XF-76 should go back into the paintrack ASAP. The difference didn't look that big when I compared them in the paint-jars, but when painted on a larger area it's another story.
The spoon with the XF-21 has 3:1 mix of Sky and XF-2 White. I think it looks correct.
The gray spoon is painted with Gunze H331 Dark Sea Grey and the top has a 15% mix of White in it. I could barely see the lighter color when I mixed it but it came out way way too light. :bash: So I have to be very careful with that.
I came to the conclusion that I will use Gunze H331 straight from the jar and XF-21 Sky + XF-2 White (3:1) - I think it will look OK in this scale. I will, however, buy a jar of H333 Extra Dark Sea Grey as a backup if I need to make the gray darker.
Also I will premix all paints in a separate jars so I avoid any surprises ;)
I looked a little closer at the decals, and it looks like the transferfilm is damaged or very rough :wtf:
Also decals 1-4 needs to be cut if the wings are folded :wtf: :wtf:
ImageIMG_20170501_200243 by Tommy Killander, on Flickr
So I need to paint the invasion stripes :roll:
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:44 am, edited 1 time in total.
TommyKillander
Hey Guys!
I decided to take the bull by the horn and make the black and white ident stripes:
First I spray the XF-2 White paint as a base
ImageIMG_20170502_205058 by Tommy Killander, on Flickr
I measured the decals and found that the stripes should be 4 mm wide. By reducing the width of a 6 mm Tamiya masking tape with approx. 1 mm at each side I will get masking stripes that have a sharp edges. I cut the tape on a sheet of glass to avoid deformation.
ImageIMG_20170503_181729 by Tommy Killander, on Flickr
White stripes taped. I had to use Tamiya curve-tape for the fuselage stripes, since the shape of the dorsal made it impossible to use stripes of kabuki tape.
ImageIMG_20170503_194618 by Tommy Killander, on Flickr]
Black stripes painted.
ImageIMG_20170503_201137 by Tommy Killander, on Flickr
I will leave that to cure and put some tape over the black stripes to protect them before I continue with the Sky colour.
Tommy
Last edited by TommyKillander on Sat Jul 01, 2017 11:46 am, edited 1 time in total.
RossiM1
Post by RossiM1 »
You have been real busy by the looks of things Tommy, some great progress look forward to seeing the paint job, brave call with the invasion stripes :th:
Gary aka RossiM1
TommyKillander
RossiM1 wrote: Wed May 03, 2017 9:58 pm You have been real busy by the looks of things Tommy, some great progress look forward to seeing the paint job, brave call with the invasion stripes :th:
Thanks! :)
Unfortunately I haven't had time to do anything for a while, I was on a trip to Faroe Islands this weekend - it was great, but I haven't had the time to do anything for more than a week. But I hope to get something done this weekend.
Tommy
Return to “Build Threads”
