Ism Friday's night live at the bench what have you been working on for *April 14th*
* Open now until 1 hour before the show on Friday, April 14th*
Re: Ism Friday's night live at the bench what have you been working on for *April 14th*
Taxi-ing this thread back up to the top and moving swiftly along :shifty:
I am away from my iMac Friday, so will watch later but no chat pour moi
Happy Easter to everyone!!!
Meng egg plane B-17 G for the ISM egg plane build
Bare metal foil (BMF) everything and felt pen coloring on wing tips. Kit decals added plus some rub on letters
Clear acrylic spinning propellers I made on makeshift Dremel lathe
Brass/aluminum chin guns installed
Last edited by Twokidsnosleep on Fri Apr 14, 2017 2:48 am, edited 1 time in total.
TinyMoore
Post by TinyMoore »
This is my entry to the Da Costa G.B.
The SU-100 is from Zvezda and the Figures are from Trumpeter All painted with Tamiya paint's and weathered using oil and enammel washes. The base is made from 2 cheap kids black boards joined together and the cobblestones are cast from Diorama Debris molds as too are the wall and foot path all cobblestones individually laid. The fire is made up of a poundshop flickering T light dismantled and fitted under fire it can be changed from underneath. Full Vid on my You Tube Channel John Moore's Scale Models.. Thank you :-) J
TinyMoore wrote: Wed Apr 12, 2017 4:44 pm Image
Looks awesome John very well executed :jd: :jd: :jd: :th: :th:
AdamLuscombe
Post by AdamLuscombe »
The Academy M-18 Hellcat 'Battle of Nancy' Vignette
The hellcat was painted in H78 Olive Drab and weathered using Mig Ammo Pigments and a Ultimate Dark Dirt Wash. I also scratch built some stowage using milliput.
The Miniart US Tank Crew figures were poor as they were covered in flash and out of proportion (Huge arms, small head). I replaced the heads with some spare Tamiya ones.
The base is a block of wood painted in Ultimate Black primer, covered in Clay and then Tamiya Texture Paint, Pigments and scatter grasses for the groundwork. The Tree is a WWS Seafoam tree :)
Dragon
1/35 Jagdpanzer IV L/48
Italeri
1/24 Ford Escort Mk. II
MakingModels
Post by MakingModels »
MENG Kint Tiger with Henschel turret
Still under construction. Great kit so far and for the most part a perfect fit.
Still have to build the tracks..
Thanks
Howdy all!
Throwing this together for fun. Starting to look like an airplane.
Tamiya 1/48 J2M3 Raiden "Jack"
No aftermarket (whole kit cost me $12 and is completely out of box.)
XF-70: Dark Green 2 for the top.
XF-80/76: Royal Light Grey/Grey Green IJN for the bottom.
Various details in MM Acrylic range and Tamiya XF-range.
Tons of Microsol.
Hopefully I can finish this by Saturday morning as I plan to enter it into a model contest held locally.
Slick J, man.
RustyWarrior
Post by RustyWarrior »
This weeks update...
Revell 1:48 AH-64D/WAH-64D Longbow Apache - It's an oldish kit with a lot of flash issues on the older sprues with the worst culprits being the rotor head and the cockpit seats. Anywhere where there was tiny details with gaps between.
Building it as the AAC WAH-64D even though the rocket pods are the wrong ones. Paint is almost exclusively Tamiya on this one and not much in the way of colour variations. It's green(ish) XF-51 Khaki Drab and black(ish) XF-69 NTAO Black.
Just putting the last few lumps and bumps on, a few touch ups of paint required in places and then it's gloss coat time.
Cheers,
Brian
I just added another one to the, "What the HELL was I thinking list..."
BobM
Post by BobM »
Continuing on with my Eggplane SIG build of the Hasegawa P-51 Mustang. All primed with Stynylrez and ready for Tamiya paints. Got a start on the pilot and he's looking egg-cited to get flying!
Thanks!
Friday April 14 Update by Bob Mortensen, on Flickr
- Bob M.
Portfolio: (on ISM)
Nothing at the moment.
:tw:
More work on my Winter is Coming Dio. The house is from the Miniart Budapest set, and I finished the shell back in Jan-Feb - walls are all painted with Vallejo modelair, and the roof is Ultimate red oxide primer just washed with a grime wash. This week I've been working on the woodwork, the frames are all brush painted with Andrea blues, and the glass is cut from a blister pack. The bicycle is from Masterbox and after a Ultimate black primer has been brush painted brush painted with the frame picked out in Andrea field grey (shade 2), the spokes in Vallejo metalcolor steel, the leather is Scale75 brown leather washed with Vallejo black wash and the tyres are Tamiya rubber black. The front lamp was drilled out and had a couple of dabs of Vallejo water effect dropped in to form a lens (hadn't tried this before and it may need a couple more dabs to bring it out properly). Figures, rubble and snow to be added.
SergioSolo
Post by SergioSolo »
I know it's a little late but when I tried to post earlier today the site had some problems
Anyway! I present you my new project: Hasegawa's 1/35 ZAXIS 135US (Hitachi Excavator)
I've wanted a construction vehicle in 1/35 scale since a long time, but for some reason they're hard to find. I hope manufacturers tackle this market, because there's enough (if not a lot) of interest, IMO
This is what I've done so far:
More updates (and detailed video) coming soon! :cheers2:
