Ism Friday's night live at the bench what have you been working on for *September 22nd*
"WHAT HAVE YOU BEEN WORKING ON THIS WEEK?"
* Open now until 1 hour before the show on Friday, September 22nd*
Re: Ism Friday's night live at the bench what have you been working on for *September 22nd*
Wow, I'm first?!
With the Valkyrie build bogged down in seam line refilling and resanding and my sanity taking a hit, I thought I'd take a breather and recharge the mojo with a Bandai HGUC (1/144) Geara Zulu. Great little kit and only a couple small seams to fill.
Given the very WW I German infantry feel to it, right down to the potato masher hand grenades, I painted with Mr Color German Grey, Dark Grey, and a bright yellow (c329) as a tip of the hat to the yellow nosed 109s. Some Alclad magnesium was used for the joints and hands, Alclad dull aluminum for the thruster bells.
Mainly I wanted to try a reverse wash technique and this was the perfect kit for it; the white markings are Ultimate white primer under a gloss coat, covered with Testors flat black, then the raised details are wiped with mineral spirits to reveal the white again.
No real weathering to speak of, just a "showroom" finish. I did do some panel lining with Tamiya liners and a bit of a gunk wash around the power cables. Ultimate Dark Dirt was used on the weapons.
(Still messing around with a new photo set up, apologies if it's a bit too contrasty...)
A few more photos here: viewtopic.php?f=70&t=23359
BobM
Post by BobM »
My Feline Fever build is starting to look like a Hellcat. It's the Eduard 1:48 F6F-5 ProfiPACK that comes with PE and resin wheel. The cockpit is complete and now installed. The fuselage assembly is coming along, just a bit of cleanup before hitting it with Stynylrez Black primer. That will be followed with an all-over coat of Tamiya XF-17 Sea Blue. Other than a few minor issues, the fit has been real good.
- Bob M.
Portfolio: (on ISM)
Nothing at the moment.
:tw:
Revell (Zvezda) 1/2700 Imperial Star Destroyer.
Finished my submission for the the Summer Sci-Fi GB. Great fun!
Primed in Ultimate Gray, painted 10:1 in Tamiya XF-2 Flat White and XF-55 Deck Tan.
Hope everyone is having an excellent week!
Al MacNeish - Tamiya 1/48 A-1J Skyraider
Progress so far - Ultimate Black Primer, Tamiya acrylic paints and then a complete strip back to plastic using Mr Color Leveling Thinner. Was going to abandon and use as a paint mule but carried on:
Re-primed and first use of MRP paints. Really screwed up putting the decals on (one of them disintegrated in the water) so it's a mix and mash of what was left. Still got to clear coat then it will be used as a weathering mule - I need the practice.
Thanks for looking and cheers to Dan for surviving yet another submission by the stroppy Jock from way up north :thumb1:
ImageSkyraider_MRPs by Alan MacNeish, on Flickr
exmoor
Post by exmoor »
finnaly finnised with 3 coats of 1k gloss one of the best kits i have built
Image20170916_135540 by Paul Shapland, on Flickr
paul shapland
JonMW
Post by JonMW »
Been trying to get my Fujimi 1/20 Kart done, have been working on this on and off for about a year. I've removed most of the molded in details from the frame and replaced them with scratch build parts like the brake caliper, spindles and the carburetor. Paints so far has been Ultimate black primer, a bunch of Alclads and Badger gremlin green. Still need to do the body panels and add a few more details.
ScaleModelJedi
Post by ScaleModelJedi »
This week I have been working on my Bandai 1/72 Perfect Grade Millennium Falcon. The cockpit is all assembled minus the fitting of the canopy. The figures were painted using Vallejo Model Color paints and the cockpit detail picked out using some ultra fine tip paint pens. I messed up the decals for this as I found them extremely difficult to get them to sit down over the raised detail. So far a great build and looking forward to continuing with it.
Continued to work on the Feline Fever Puma - the interior (not currently visible) was completed with Ultimate Red Oxide primer (the old stuff) followed by a general coat of Vallejo ModelAir Ivory, detailing and weathering. The turret hole (?) was then masked off before the two hull halves were joined and the fender sections added. There's a few minor seams/gaps to deal with along the main join but overall still enjoying the build. Hoping to get the main build done this weekend and then ready for priming.
